I have a Series CX4800---when printing a copy the size of the print is only about a third of a full page .Will you please give me directions on how to make the print fill a page?
  • 26 Answers
Download an updated driver from Epson (http://support.epson.com/).
Posted on Jul 17, 2008
After document is scanned, and I need to print out a copy, the copy is much smaller, not full size.. What causes that to happen
On Print Properties tab uncheck Fit to Page and let it print full size. If that fails, resize to above 100%
Dec 06, 2017 | The Office Equipment & Supplies
I have a laser printer 8150n. when i gives 20 print on it. on sheet print after another sheet vacant and third print fourth sheet vacant.. what is the reason
Might be page size mis match> Check paper size in system as well as in printer.> Remove tray &check for paper size.> Clean paper path sensors.
Dec 18, 2011 | HP LaserJet 8150n Printer
When I print pictures on the 3210 HP all-in-one, they come out very small even though I choose the 4X6 in paper size for the photo tray. I've tried everything I can, but the pictures keep printing wallet...
First thing that comes to mind is that a 4x6" print could print four wallet sized photos; be shure your are not printing more than one copy.
If you are trying to print more than one,it will print the actual picure you have and leave space for the number of other nonexistent prints selected.
See page 75 of the Manual. for directions on how to set up photo printing.
If you have photoshop, you can resize your documents using the menu item, Image / Image size, (Alt + i then i again)
Set the resolution to 300, then the document size width to 6 or 10 inches.
This will guarantee that your document is full size, (though the printer should be able to resize it to fit on the page no matter what).
Give these a try. It's really a shot in the dark, but it's my best guess.
Cheers.
Richard.
Oct 13, 2009 | HP LaserJet 3200 All-In-One Printer
Canon mx850, paper jams when reloading for two sided copies. once the 1st side is printed the paper is released, recaptured and starts to feed back into the prt. 1/3 into the feed it jams, paper is...
Mel, this is what I found in the online manual:
Set the Ink Drying Wait Time longer.
Doing so gives the time enough to dry the printed surface so that paper curling and ink blots are prevented.
(1) Make sure that the machine is turned on.
(2) Open the printer properties dialog box.
See Opening the Printer Properties Dialog Box Directly from the Control Panel.
(3) Click the Maintenance tab and then Custom Settings.
(4) Drag the Ink Drying Wait Time slide bar to set the wait time, and then click Send.
(5) Confirm the message and click OK.
Make sure that the actual size of the paper is suitable for automatic duplex printing.
The sizes of media suitable for automatic duplex printing are A4, Letter, A5, B5, and 5" x 7".
Load paper of suitable size and then press the OK button.
Make sure that the Page Size or Paper size setting matches the actual size of the paper with a size suitable for automatic duplex printing.
First, check the Page Size or Paper size setting in the application software you are printing from.
Then, check the Page Size setting on the Page Setup sheet in the printer properties dialog box (Windows) or the Paper size setting on the Page Setup dialog box (Macintosh).
Note
Depending on the version of the application program, the automatic duplex printing may not be supported.
Make sure that the type of loaded paper is suitable for automatic duplex printing on the Main sheet (Windows) or the Quality & Media sheet on the Print dialog box (Macintosh).
Note
To switch to manual duplex printing, follow the procedure below.
Open the printer properties dialog box, clear the Automatic check box on the Page Setup sheet, and reprint.
When performing manual duplex printing, note the following.
If you are printing three or more pages of a document with manual duplex printing, one side of all sheets of paper will be printed first. Turn over the paper and reload the paper in the machine, and then the reverse side of all sheets of paper will be printed. Be careful not to change the order of paper in the stack.
The procedure for reversing the paper varies depending on the staple side and printing orientation. Follow the on-screen instructions.
MX850 series On-screen Manual for Windows:
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=334&modelid=16279
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Mar 11, 2009 | Canon PIXMA MX850 multifunction InkJet...
Qms 2200 paper mismatch error
Initial Thoughts
The problem seems to be a fault in a paper feed sensor. This would explain the size mismatch, since these sensors are how the printer detects the paper size. And, it would explain why printing starts two-thirds down the page, since these sensors are also used in timing where on the page to start printing.
However, a document passes through three software applications before it actually prints. And, any one of them could be causing the paper size mismatch.
Insight
Although paper sensors are usually low-tech and easy to remedy, they are often difficult to find and can sometimes be difficult to get to. Most such sensors are simple switches (toggles) and others are optical sensors that work like the electric eye of a garage door opening system. And, the solution may be as simple as a tiny piece of paper stuck on one of them. However, sensors such as these are quite numerous on this printer and can be hidden anywhere.
The three software applications I referred to are:
1. The document rendering application, such as Adobe Reader, Microsoft Word, etc.
2. The print writer. This is part of the device driver software package. It breaks up a print request and converts it to a standard format that the printer will always recognize and manages transmission of each page to the system spooler or directly to the printer.
3. The printer firmware. I'm not sure of everything this does related to the print stream. But, part of it must manage resources, such as ensuring the right size paper is being fed.
Jan 23, 2009 | Minolta magicolor 2200 EN Laser Printer
Printing Problem
My first copy comes perfect second copy the yellow color is getting shake
Nov 20, 2008 | Xerox DocuColor 12 Printer
Epson cx4800
How is the printer connected to your computer?
What is the operating system of your computer?
What are you printing specifically?
May 24, 2008 | Epson Stylus CX4800 All-In-One InkJet...
Computers & Internet Logo
22 people viewed this question
David Payne
David Payne
