Question about GE Spacemaker JVM1640SJ Microwave Oven
Ge spacemaker JVM140H001
Hi ,
I have an old spacemaker. It is slopped on the bottom. I need to replace it under my counter. Is there a compreable one to buy. How many cubic feet would it be? Is the GE profile a same fit?
Please help?
maureen
  • GE Master
  • 9,086 Answers
Are you sure yours might be economical to repair? What's wrong with it?
Please write back with more details if you need further help.
GE Customer Service should be able to take your current model and recommend comparable replacements. Contact them here.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Jul 18, 2008
I need the specs for GE Spacemaker XL JVM1339BW002 and need to know since I am replacing this unit w/another GE what type of venting do I need, and will I need to purchase a new trim kit?
The GE Answer Center can answer those questions. 800.626.2000
Give them your full model number.
I regularly repair these.
Feel free to contact me via my site with your full model number and FCC ID number as shown on the tag in or on the oven for more free help.
Nov 26, 2016 | GE Microwave Ovens
I have a GE OTR microwave JVM1460 spacesaver xl1400. I am trying to take it down. I unscrewed the two top bolts from inside the cabinet. I thought it should just swing down on the mounting strip, b
remove-ge-spacemaker-800x800.jpgRemove a GE Spacemaker
The GE Spacemaker series of microwave ovens are designed to be installed above an oven range, freeing up counter space in your kitchen. Some of these Spacemaker models are connected to an outside venting system to carry kitchen vapor and odors outside. Other Spacemaker models utilize a ductless system to do this. Removing a GE Spacemaker microwave oven isn't a difficult task, but, because of the size of some of the oven models, it is a two-man operation. Have a question? Get an answer from an appliance repair specialist now!
Other People Are Reading
Things You'll Need
  • Assistant
  • Sharp knife
  • Phillips screwdriver
Instructions
    • 1 Open the cabinet above where the Spacemaker microwave oven is installed. If you see a vent in the cabinet leading to the Spacemaker oven below, your Spacemaker is vented. This vent needs to be disconnected before continuing with removal. Disconnect the vent either by loosening the duct clamps or by cutting the duct tape away with a sharp knife. Pull the vent out of the top of the oven.
    • 2 Have an assistant support the oven from below. Loosen the mounting screws connected to the Spacemaker through the cabinet bottom. Loosen the screws by turning counterclockwise with the Phillips screwdriver.
    • 3 Unplug the Spacemaker from the socket in the cabinet.
    • 4 Continue loosening the screws while your assistant holds the oven in place. Once the screws are removed, have your assistant slowly lower the Spacemaker down by lowering the front face at a 45-degree angle.
    • 5 Feed the power cable for the Spacemaker through the hole in the bottom in the supporting cabinet.
    • 6 Help your assistant slowly pull the Spacemaker forward and out of the mounting brackets on the rear wall. Once the Spacemaker is cleared of the mounting cabinet and rear wall, set it down.
    • 7 Remove the mounting bracket from the rear wall by loosening the screws.
Read more : http://www.ehow.com/how_7344250_remove-ge-spacemaker.html
Nov 26, 2014 | GE Microwave Ovens
How many cubic feet is a GE spacemaker model l# JVM240WL001
you must ask some vendor Online via chat with GE, they offer many Sales, and good opportunity. Get in tourch with them.
God bless you
Aug 03, 2012 | GE Profile Spacemaker 1.8 Cu. Ft....
Need to replace both might lights under microwave.
Remove the screw from the lens cover and open lens. Turn light bulb counter clockwise and remove. Repeat this on other side. The bulbs or 40W appliance bulbs. Take the old one with you to hardware store to match it up. Reverse your steps to put new ones in.
Jun 18, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Do you have a door handle for a ge model #jvm140h001,serial # DD921459S, MANUFACTURED in February ,1990?It works well and I would like to replace the broken handle.
I can't find a parts breakdown for that door anywhere, and I am using extensive resources. All that is shown is the complete door, which is no longer available. If the handle was available, it would be nearer $100.00 than $50.00. So, it's time for you to get creative. Are you a woodworker, can it be glued, spliced, splinted,...
Good luck.
fil
Mar 02, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
My counter top GE Spacemaker microwave oven's door handle is broken. Is there a replaceable door handle part?
Hi!!
Yes, there is. The part # for the HANDLE,DOOR -L is WB15X10119 and costs $15.25. You can order it from this site https://www.geapplianceparts.com/GEApplianceParts/Dispatcher?REQUEST=ACCESSORY use your oven's model # to make sure you have the proper handle.
Good Luck!! A HELPFUL - 4 THUMBS - rating for this solution would be greatly appreciated. Thank you for using FixYa.
Feb 15, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Just wanted to know the size of the GE profile microwave model JVM1660BB005. Is it 1.5 cu ft? Looking at a new model JVM1540LNCS to replace it and want to use the same mounting hardware.
In GE microwaves, the first 2 digits of the model number are the cubic footage. 1660 is 1.6 cubic foot, 1540 is 1.5 cubic foot. Take care trying to use the existing hardware, the exact placement of hardware and upper installation screws may vary from year to year or model to model..
Mar 09, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
GE spacemaker not heating
the magnatron has gone bad and maybe still under a warranty need to check with ge.if it is not then in most cases it is cheaper to go buy another microwave than to have it replaced.
Feb 23, 2010 | General Electric Microwave Oven
GE profile spacemaker XL1800 undercabinet microwave - how do you change the 2 lightbults under the microwave. I can't get the bulbs out.
There are several screws on the bottom panel that can be removed. After you remove them, the metal plate can be removed or just lowered at an angle. Using a flashlight, you will see the two bulbs that probably need replacing. Pull the wire down, and they can be easily removed and replaced.
Hope this helps.
Nov 14, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
362 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
