Question about LG LRM1250 Microwave Oven
Oven won't heat even though each component seems to be functional.
I have an LG LRM1250 that won't heat. I have 115VAC to the primary of the transformer and 3-4VAC across the filament taps. Resistance is less than 0.1 ohm across the magnetron terminals and infinity from each terminal to ground. HV transformer tap to ground is ~90 ohm. Diode is ~50Kohm/infinity. Resistance between each capacitor terminal and the case is infinity. The ohm meter deflects then returns to infinity as I switch the leads back and forth across the capacitor terminals. Energizing the transformer while the magnetron is disconnected results in the capacitor holding a charge.
The oven is only two years old and the cooking power never decreased before it just stopped heating. I suspect the magnetron, but it appears to test ok and it appears to be in good physical condition. Anyone have any ideas?
  • plastic Jul 19, 2008
    Thank you for your 99% certainty and your concern for my safety. Rest assured I am experienced with HV AC/DC. I think the possibility that the magnetron is the problem is high enough for me to try a new magnatron, and is certainly high enough for me to give you a FIXYA! Thanks.
  • LG Master
  • 8,858 Answers
Even though the magnetron passed the continuity tests, it can still be bad. In fact, most of them fail in ways that do not show up in continuity tests.
And I am 99% certain yours is bad, especially since you have proven that the filament voltage and high voltage DC is being produced and sent to the magnetron.
I must say that the testing you have done is not recommended for people without plenty of experience, but apparently you did it safely. Please don't press your luck, since the high voltage can be instantly lethal.
For Goldstar / LG / L.G. parts, call 1-800-243-0000 (M-F, 7am-8pm CT, Sat 8-5 CT) and choose the appropriate prompt from the menu or visit here.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Jul 18, 2008
How to troubleshoot a Magichef md# MCD1611ST microwave that is not heating anything at all.
Most Frequent Causes for Microwave not working Thermal Fuse
The thermal fuse cuts off power to the microwave if the microwave overheats. To determine if the thermal fuse has blown, use a multimeter to test it for continuity. If the fuse does not have continuity, replace it. The thermal fuse cannot be reset-if the fuse is blown, it must be replaced. (Caution: The microwave oven can store thousands of volts of electricity in its high voltage capacitor, even after the microwave oven has been unplugged. Due to the potential for electric shock, it is extremely dangerous to replace the electronic components in a microwave. Only a licensed technician should replace the thermal fuse The thermal fuse cuts off power to the microwave if the microwave overheats. To determine if the thermal fuse has blown, use a multimeter to test it for continuity. If the fuse does not have continuity, replace it. The thermal fuse cannot be reset-if the fuse is blown, it must be replaced. (Caution: The microwave oven can store thousands of volts of electricity in its high voltage capacitor, even after the microwave oven has been unplugged. Due to the potential for electric shock, it is extremely dangerous to replace the electronic components in a microwave. Only a licensed technician should replace the thermal fuse
Sep 28, 2016 | In Microwave Ovens
How can I access the switch for the hi low off light?
The cabinet has to be removed, BUT removal exposes you to hazardous and potentially fatal voltages even with primary power disconnected.
Oct 22, 2015 | LG LMVM1935 Convection/Microwave Oven
Lg micro wave turns on but doesn't heat
A word of caution.......if you are familiar with microwave ovens, you know how to discharge the big capacitor in the seconday-circuit, and what can happen if you don`t! BE CAREFULL!
If your microwave oven runs normally, but won`t heat, suspect a primary-circuit fuse. Always replace with a fuse of the same voltage and amp rating. Also, check all electrical connections. Again, be sure to discharge the big capacitor so as to avoid dangerous shock.
Another common problem and simple check is the power diode. Simply check for continuity. If you get continuity in both directions with a volt-ohm meter, replace the power-diode.
If you have the proper meter, check the secondary-circuit capacitor. The capacitor can be a little pricey if it is bad.
If that doesn`t do it, the problem is likely the primary-secondary transformer. Unfortunately, the cost of the replacement part is probably more expensive than buying a new microwave oven.
Mar 03, 2015 | LG Microwave Ovens
Panasonic NN-H965WF Microwave oven
We recommend the microwave is evaluated by an authorized service center by using www.panasonic.com/repair Welcome to Panasonic Online Repair
Apr 13, 2014 | Panasonic Microwave Ovens
Heating element does not shut off even when microwave is off
All electronics that have relays have a problem with the relays arcing shut. Hit the back of the relay firmly to release it.
Nov 28, 2013 | LG LMVM2277ST Microwave Oven
Machine is working but not heating
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Basic Microwave Oven TroubleshootingTips
heatman101/././.
Jul 08, 2010 | LG LMV1314 Microwave Oven
Just replaced the magnetron in my Panasonic NN-S543BFR. I still don't get any heat from my oven. Everything works as set but still no heat in oven. Need suggestions on repairs.
When you say "Everything works as set" do you mean the microwave appears to function properly, but then doesn't heat?
If the magnetron is new, then the magnetron must not be receiving the required high voltage (2000V or more) from the HV circuit. Make sure you've got 120V to the PRIMARY (don't attempt to measure secondary voltage of the HV transformer without special equipment) of the HV transformer. After that check the HV capacitor and diodes. If these components test OK, then either your HV transformer is bad or your new magnetron is faulty. My experience is that the problem is usually in control circuitry, preventing 120V to the HV transformer, or opens/shorts in the HV components (diodes and capacitors).
Mar 15, 2010 | Panasonic NN-S543BFW Microwave Oven
Micro wave not heating
Hello jrsnelus,
The main purpose of a microwave oven is to generate microwaves to heat food in the compartment so if it doesn't do that, then chances are that a component has failed. The fact that everything else seems to work suggests that you at least have ac power getting to the controls. You more than likely have a bad magnetron tube , filament transformer or high voltage capacitor that failed as part of the microwave generating system and it is not something that the untrained person should attempt to fix. Even unplugged, the high voltage capacitor remains charged up sufficiently enough to cause serious injury to someone. I've always been an advocate of the good old saying that if the cost to repair exceeds the cost to replace...then simply replace it. Even if you get an appliance tech to examine it, chances are his fee and the components that he finds defective will more than offset a replacement appliance.. I wish I could have suggested a better alternative for you..
Regards,
Rick
Nov 25, 2008 | KitchenAid KHMS155LSS 1000 Watts Microwave...
Not heating intermediately
If you have plug-in type watt meter, you can check the power draw of the oven when it is heating and it isn't. The magnetron is the primary power consumer of the unit, and by comparing the difference of power you can tell if it is the magnetron. Most likely your intuition is correct.
Jun 09, 2008 | GE JVM1542 Microwave Oven
LG microwave no longer heats!
It sounds as though you may have run the microwave while empty, which can damage the magnetron.
Not that I'm optimistic, but the first thing to try is a "hard reset". Unplug it from the power line for a few minutes, plug it back in, set the clock, then try again.
Let us know if the hard reset doesn't fix it.
Otherwise it likely needs a new magnetron.
Apr 06, 2008 | Microwave Ovens
LG LRM1250 Microwave Oven Logo
233 people viewed this question
Top LG Microwave Ovens Experts
William Miller
William Miller
sonic boom...
sonic boom...
Are you a LG Microwave Oven Expert? Answer questions, earn points and help others
