Question about KitchenAid Refrigerators
How do i change the water filter... its at the bottom front of the fridge in the grill part. I tried twisting but i dont want to break it
  • 93 Answers
Push in and twist. If it is stuck you may have to use a little force. Make sure water is off before you use any force, because if you break the filter housing water will go every where
Posted on Jul 17, 2008
My Kitchenaid French door fridge's water filter
If I remember correctly it requires a quarter to half turn to disconnect in the counter clock wise direction. May take some grunt to free it. If that fail try channel lock pliers and be careful to not break it. once turned it should pull straight out. Try that as maybe its not twisted into place properly to start and just needs to be pulled straight out.
Oct 13, 2013 | KitchenAid KFCO22EVBL - French Door Bottom...
How do I change the water filter in the refrigerator?
down in the front grill at the bottom of the fridge you will see the filter and just the the left of it you will see a button. push the button in and that will pop the filter out a bit. pull it out and put the black cover that was on your old filter and put on your new one. then just push it in
Mar 26, 2010 | Whirlpool GC3NHAXVY Stainless Steel Side...
Water filter won't come out when I push the button
Push button? It should be a turn to the left to remove if it is a whirpool located at the bottom. These are twist out not push to release. The only push to releases are made by electrolux.
Mar 07, 2010 | Whirlpool ED2FHEXN Side by Side...
Where is the water filter
Depending on the model, it is inside the fridge.
Some other models the filter is on the bottom grille, twist kind.
Look for your manual or look for those clues
Feb 18, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Sounds stupid, where is the water filter
it is in the grill at the bottom of the front of your unit. you can see it when you open the freezer door.
start by removing the lower plastic grill by grabbing the grill and twisting outwards on it.
then the filter can be removed by turning the filter, top to the right.
when you put the new filter in in place, it should sound like water is running into the unit.
then replace the grill.
Jan 07, 2010 | Refrigerators
Where is the water filter located?
Look at the bottom of the fridge in the grille for a round trimpiece that is removeable.
It is behind the twist - off trimpiece.
SEE THE DIAGRAM/LOCATION HERE
SEE THE FILTER HERE
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Aug 21, 2009 | Kenmore Refrigerators
Trying to remove the water filter and front grill
To change the filter rotate counter clockwise. To remove the grill at bottom grab bottom lift up and out. also here is the manual.
http://shared.whirlpoolcorp.com/product_literature/search_results.jsp?searchTerm=ET1FHTXMQ04&siteCd=WHRCOM
Good Luck and please rate FixYa!
Apr 11, 2009 | Whirlpool 21.8 cu. ft. Side-By-Side...
Need to replace water filter, can't locate where.
Look down at the grill at the bottom of the frig under the freezer door will be a section of the grill the looks like the grill but has a ring around it twist it counter clock wise and the filter will twist out and the grill front slide off the old filter on to the new filter good luck.
Apr 02, 2009 | Kenmore 57029 Side by Side Refrigerator
Remove the water filter
Yes if it is the filter that is located where the bottom grill is..... It rotates 1/4 trun counter clockwise. If you cant seem to break it loose try removing the grill by pulling it towards you (it clips on) take not of the tabs on the grill and the clips on either side of the fridge. Now you can get a better grip. Also its a good time to look and see how dirty coil is under refrig.
Jan 19, 2008 | Whirlpool 21.8 cu. ft. Side-By-Side...
Refrigerators Logo
184 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
mike cooper
Todd Arndt
Todd Arndt
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
