Question about Whirlpool Calypso GVW9959K Top Load Washer
FL ERROR CODE - Machine is about 5-6 yrs. old.
Never a problem until now, and it's completely my fault. I washed two little bathroom rugs. The rubber backing came away in tiny bits and pieces. A lot of it is jammed in the pump housing and probably seized the pump impeller. How do I take the machine apart, find the pump impeller and clean it out? If I know how to get in there, I know I can fix the problem.
Do you enter the machine from the back? Or, take off the front panel? How do you do this? Thank you.
lamoret9@aol.com
  • 3 Answers
I just had this issue two days ago. You have to take the back off the machine. If you have water then drain manually. I did this by taking the drain hose, pulling through the housing, unclipping the hose from the inside of the machine. This will get the hose to ground level, and using a bucket dip the hose down to fill, and up to drain into a bucket. This was time consuming, but it did almost fully drain. I then tipped the washer on its front, and took the bottom cover off. You will see two hoses, going to the pump motor. Remove the hoses, and you will have access to the pump impeller. I removed the entire pump and motor to clean it out. If you do this be careful. I had to find the wiring diagram to reconnect the wires. After pulling out a draw string from a swimming suit, and putting the machine back together it all worked. The repair sheet for this machine is taped to the front panel of the machine. This has all error codes, diagnostic modes, and anything else you will need to know to fix this machine. To get to the sheet, pry off the whirlpool emblem with a flat head screw driver. Remove the screw and lift up the top cover just enough to get the sheet. The sheet is in a plastic bag attached to front panel on your left as you are looking at the machine. Good Luck with the repair. Also check the actual drain hose for a clog. I found a piece of a sock in mine.
Posted on Jul 23, 2008
Fault saying no, press start for 5 seconds to clear, then it goes to nrO, press and hold again it goes back to no. Please help.
Whirlpool Calypso Washing Machine diagnostics & Error ...
applianceassistant.com/Washer-Repair/Calypso/Calypso-Diagnostics.php
Whirlpool,Calypso,washing machines,repair,troubleshooting,PF,FL,Er,LF,CE,Ld,CA,CI,ob,Sr,LS,SL,error code,problem ... within five seconds while the machine is in Standby Mode. ... The washer does not flash"PF" when it is first plugged in. Press START to continue the cycle from the moment that power was lost -OR-
Washing Machine Fault Codes « Tips, Tricks & Recipes
www.appliancefactoryparts.com/blog/.../washing-machine-fault-codes/
Feb 20, 2010 - Drain pump error, Water level does not decrease to reset point .... If after 30 seconds the control does not detect water entering .... Press START to continue the cycle from the moment that power was lost ... Check pins 1 and 5 of P16 of the machine controller and pins 1 and 2 of P1 of the motor controller.
[PDF]Fault Code Bible v1.2.pdf - ResearchGate
Dec 02, 2015 | Washing Machines
Error code f 50 stop and keep beeping
washed to small bathroom rugs.. on bulky items. low suds stopped at F code and can not get to rinse and drain and whole dial lit up. Tried removing one rug of 2 to lighten the load. still not working. Tried unplugging it and waiting. have had about 2 years. HELP.. read the directions.. it appears using bulky items was not wise. over did the agitation.. made too much suds?
Jul 29, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
Washer now shows OE on progess window after i tried to wash bathroom rug. Would not spin/drain excess water and door won't open.
The LG error code OE simply means “the pump is blocked”. Presumably the water isn’t being emptied properly. As with all error codes it is possible that there is a cause other than the exact description in the error code explanation but basically this error means as far as the washing machine is concerned it thinks the water isn’t pumping out. A pump, or filter blockage is the most common cause but it could be caused by other faults such as a faulty pump, or even a blockage in the drain hose or somewhere else in the system etc.
LG themselves have some information on this error code Washing machine that has an OE error code.
http://lgknowledgebase.com/kb/index.php?View=entry&EntryID=6273
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Sep 11, 2010 | LG WM-2077C Front Load Washer
Error code FL and does not drain completly
most probably needs the water pump replaced.  not hard to do if you are a little handy..  there were a lot of problems with this machine regarding the water pumps.
Jul 22, 2010 | Kenmore Washing Machines
Washer keeps beeping Fl
Your pump is clogged , It is a very bad Idea to put rugs in that machine either to fibers or the backing on the rug gets stuck. I hope you know someone handy. take out as much water as you can from the top with a cup or something. You are going to have to go under the bottom of the machine remove the 3 screws on the bottom plate. the pump is on the right you have to disconnect the black and the yellow hose very slowly there is a lot of water that you can't see from the top . then take down the pump and clean it out . Good luck remember no rugs.
Jan 11, 2009 | Kenmore 24032\24036 Top Load Washer
FL error on my Whirlpool washer
The FL error code means:
Flood Condition:
FL flashes if any overfill condition occurs. This condition occurs when excessive water in the tub causes the overfill switch to trip. The control must realize that the trip was due to an overfill condition instead of a suds lack condition in order for FL to be displayed
With an overfill condition, the beeper repeats a warning every 10 seconds with no time-out. The pump is cycled in drain mode for 30 seconds on, 30 seconds off until the overfill switch resets or power is discontinued to the unit.
Press STOP/CANCEL to clear the display.
This problem I see on these are the water pumps getting clogged with lint or other things, causing the pump not to pump all of the water out at times.
There is a check "valve" in the drain assembly that seems to sometimes cause problems with the FL error code. You can remove this piece, and might avoid changing the pump.
Calypso Service manual: https://docs.google.com/leaf?id=0B5If-wTgYWH5MTQ0OGIxZTAtZjQyMy00MzEzLWJkMzYtZTdmOTY2OTk3YTA4&hl=en
Dec 06, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Small rug washing in front end loader washer
its problably not able to balenbace the load of rugs, if the machine cant balance itwont go to high speed spin. in actuallity your probalby better off bringing the rugs to the laundry mats, especially if the are rubber backed, the rubber backing will come off clogging your pump assy, then your looking at replacing hte pump for a few hundred dollars, for a clean set of $30 bath rugs.
Nov 30, 2008 | Frigidaire GLTF2940ES Front Load Washer
Whirlpool/Kenmore Calypso Washing Machine FL code - (Overfill problem, and yes, there is water laying in the washing machine. This problem was caused by washing an old bath rug. Bits of the rubber...
not overfill since no water overtop just switch detecting too much water...lean washer back remove 3 screws holding bottom panel on newer pumps have torx screws in bottom id any way possible remove a much water as possible first may try leaning washer foward after removing bottom panel remove the screws in bottom of pump and clean..older pumps were harder to clean and replacement was easier but more expensive..new style comes with motor attached
Jul 17, 2008 | Washing Machines
Whirlpool Calypso GVW9959K Top Load Washer Logo
113 people viewed this question
Dan Webster
Dan Webster
Sal De
