I have svic s700 series it doesnt want to turn on .the lights are on one is a sleeping mode and the second one the green one is for the lamp i thing Please help
5 Suggested Answers
  • 29 Answers
SOURCE: Samsung HL-P5063W/ Please Help
Could be a main board or a DMD board .
Posted on Mar 15, 2008
SOURCE: Intermittent lamp turn off
I was told by the repair service to unplug the power cord for about 5min. This resets the internal computer. I think this helps but does not cure the cause. Good luck.
Posted on May 26, 2008
  • 16 Answers
SOURCE: WD-52525 - No picture, green status light then turns to red lamp
check the lamp
Posted on Jun 26, 2009
  • 115 Answers
SOURCE: mitsubishi wd-62525 sound will come on but no picture.
Your tv would turn on if you replace the only two 3300µf@16v capacitors on the power board . You wil notice they are bad by the way they bulge up at the top and may be leaking electrolyte a little from the tops . But the rolling lines would still remain but much less noticable.Then other symptoms will eventually appear. Truth is many many many many other capacitors need to be replaced inside the electrical chassis. Your TV would need to go to a repair shop that is expierienced in that repair because it is so extensive.
Posted on Oct 06, 2009
JULIANFIX
  • 975 Answers
SOURCE: tv turns on for about 5 seconds then turns off
this is a very common problem with rear projection tv,
check the POWER SUPPLY SECTION , depending where you live , theres humidity that affects the connections that comes out of the power supply , I suggest to open the back and remove & reinstal every flat connector like a ribbon cable ,to make sure its making good contact . good luck AJ
Posted on Nov 06, 2009
Blinking lights router
The POWER lamp should be green, 100% of the time.
The WIRELESS lamp should blink, as it "pools" many times per second, chatting with (or looking for) wireless devices.
The INTERNET lamp should blink, whenever any wired/wireless device tries to access the Internet.
For each WIRED device, the lamp should be green, 100% of the time, whenever the device is responding (maybe even when the device is "sleeping").
Jul 15, 2014 | SonicWALL TZ100 UTM Appliance
Tip
Power saving mode officejet 6500 series
did you know that officejet 6500 series doesnt have any configuration about power saving mode (sleep mode).
it will turn to sleep mode after 1 hour.
if it is wireless, you need to turn off/on the product for you to use it again
on Mar 21, 2010 | Office Equipment & Supplies
Asus k50 will not start
If the light on the pc, not the power supply is orange this usually means the pc is not comming out of sleep mode. Try the obvious and restart it. If that does not work, attempt starting in safe mode and go to your control panel and turn off all power saving, screen saver, and sleep mode options.
Sep 24, 2012 | ASUS K50 Series K50IJ-G1B NoteBook Intel...
I have a philips dlp 55pl9773 has one red flashing led on the front when i do a hard reset tv boots up lamps lites led goes from flashing yellow to green for about ten seconds and then back to red flashing...
MY philips tv model number 55PL9773/17 WAS TURNING OFF THE SCREEN AND LEAVING THE AUDIO ON FOR ONE MINUTE. THEN THE YELLOW LIGHT STAYED ON. THEN THE LIGHT TURNED OFF. thEN I TURNED ON WITH THE REMOTE AND THE YELLOW LIGHT TURNED ON AND A FEW SECONDS LATER CHANGED TO THE GREEN LIGHT AND THE TV TURNED ON. AFTER A FEW MINUTES, BETWEEN 10 AND 30 IT DID THE SAME THING. NOW IT IS OFF WITH A BLINKING RED LIGHT PERMANENTLY ON. TO TURN IT OFF I HAVE TO UNPLUG IT FROM THE WALL. I REPLACE THE LAMP A FEW WEEKS AGO AND IT IS FINE.
Dec 01, 2009 | Philips 55PL9773 55" Rear Projection...
Green Screen
Not bulb related, it is related to the i/o board on the back of the projector. Something is shorted or making poor connection
Apr 29, 2009 | Dell 3400MP Multimedia Projector
Sharp light turns green thern turns yellow screen goes black
it is going into sleep mode, good luck with this.... i am currently asking how to get my hard drive to quite putting my monitor into sleep mode.
although it hasn't worked for me because my screen stays black, one of the options given to me is to try to start in safe mode and then adjust your settings to "never" on the energy/sleep/hibernate mode
some one else suggested that i remove and reseat the video card
hopefully one of those will work for you
Feb 14, 2009 | Sharp LL 172A-B 17" LCD Monitor
Samsung aircon cuts off. lights green/yellow flashing
lg air cond.multi split led lamp blink power 1 times,good sleep 2 times
Feb 11, 2009 | Heating & Cooling
Monitor keeps going i to sleep mode
Check the cable it's not connected correctly or check you CPU is it working fine.
Dec 08, 2008 | HP Pavilion F1503 15" LCD Flat Panel...
Won't come out of sleep mode
Have you tried getting a second monitor ? then using it to get to the desktop and go to power options and set your monitor to never turn off? after that is done try your monitor again and see if that works.
Feb 07, 2008 | KDS Radius RAD-7 17" Flat Panel LCD...
Televison & Video Logo
60 people viewed this question
Top Televison & Video Experts
Electro Med Services...
