Question about Microsoft Windows Server Standard 2003 for PC
Bad sectors What are badsectors. How to detect the bad sectors in harddisk.
  • venugopal_i Jul 18, 2008
    Thanks a lot for your valubale information giving to us.
  • 52 Answers
Use the following link to download the software, which helps u to detect as well as completly remove badsectors, but before u do tat, here is the answer for wat is bad sectors..
Hard disk drive is an integral part of every computer. It stores all your information. One of the most prevalent defects of hard drives is bad sectors on the disk surface. Bad sectors are a part of the disk surface which contains not readable, but frequently necessary information. As a result of bad sectors you may have difficulties to read and copy data from your disk, your operating system becomes unstable and finally your computer may unable to boot altogether.
When a hard drive is damaged with bad sectors, the disk not only becomes unfit for use, but also you risk losing information stored on it. The HDD Regenerator can repair damaged hard disks without affecting or changing existing data. As a result, previously unreadable and inaccessible information is restored.
ths is the software
A powerful hard disk tool that can detect and repair physical bad sectors on a hard disk drive surface and regenerate hard disk.
http://www.4shared.com/file/49739096/5f24d2c2/HDD_Regenerator_151_Full.html?s=1
Posted on Jul 17, 2008
  • ABHILASH V R
    ABHILASH V R Jul 18, 2008
    oh thank u , but, please rate me and indicate me the depth of satisfication
I need to do a low level format for my hard disk. Bad sector problem. Do you guys have any application for that particular kind of formatting?
Bad sector on hardisk there two kinds of that is software and physical. physical badsector caused from plate of hardisk damage is caused by dirt, fallen down, collided, to be incised, etc. While software badsector can be caused when hardisk busy sudden die, cause of usually broken electrics current.
For the bad sector damage of physical of hardisk, we require a really of expert to repair the hardisk. While damage of software we can repair xself use software or tool. One of the software which can be used to repair bad sector on hardisk that is HDD Low Level Format Tool.
Using this software hardisk can be low level format. Require to be paid attention that using low level format on a hardisk, causing all data in hardisk will lose and cannot be recovery again. But this way will be more effective eliminate sector bad.
HDD Low Level Format Tool Support Hardisk SATA, ATA or SCSI, can is also used on removable media like flashcard, flasdisk and etc. To run this software is very easy, that is :
  • Download HDD Low Level Format Tool from the link above and install it till finish.
  • Run HDD Low Level Format tools
  • Select a hardisk which will repair then click continue.
Select LOW-LEVEL-FORMAT tab", if you sure To format the hardisk click "format this device" button and await till finish. ad for hardisk repaired hence required time will longer.
HDD LOW format level can be download from following link,
http://hddguru.com
note : If on hardisk have detected badsector, before doing above steps, first step to backup all existing important datases
Premium experts are not paid for free questions so require your appreciation in form of a 4 thumbs rating
THANKS
Oct 03, 2010 | Computers & Internet
Badsector on disk, need drivers for creative labs,
http://support.creative.com/Products/Products.aspx?catid=218
Apr 29, 2010 | Creative Labs WebCam Live!
HDD Maxtor 80Gb IDE: Harddisk error! At boot it say's Primary harddisk error. Press F1 to continue. *When I press F1 nothing happens. *When I go to the bios at IDE Configuration and hit refresh at Primary...
OK the only shot you got is to geta USB to SATA/IDE converter dongle, connect to another PC's USB port. Hopefully, you will be able to read it. Otherwise still plugged in you may be able to use recovery software and get you DATA back. Recover my files is one,
http://www.recovermyfiles.com/
Other freeware data recovery software GL.
http://www.freebyte.com/filediskutils/
Feb 15, 2010 | Maxtor Hard Drive
Bad sectors on hard drive HP model number BD0728856A 72.8GB 10K rpm Can I get another HDA to replace this one?
yes better u have to change the HDD. Else u have to remove the badsector using dos os. Its an long process. after u have removed the badsector then also its running slow. Better u have to change the HDD.
Cheers
Sep 19, 2009 | HP SCSI Hard Drive
How to remove bad sectors laptop hdd
Sir,
Bad sector removing is difficult task to remove /find. u can't solve bad sector harddisk. first go to run and type CHKDSK and check how the disk was or % of bad sector. the chkdsk command will solve badsector automatically. if not solves better to buy a new one or using the hdd with bad sector it not a problem
Jul 11, 2009 | Computers & Internet
Find badsector
the bad sector cannot recover... is continuing increasing the bad sector... you need to replace your hard disk...
Apr 09, 2008 | Computers & Internet
Bad sector
i have problem whit my harddisk-bad sector
Apr 07, 2008 | Televison & Video
BAD SECTOR
sorry your question will have to be put in english
Nov 17, 2007 | Computers & Internet
Harddisk Bad sector & not detecting
Hi, If your partitioning and/or formatting program is already reporting "bad sectors", then your best bet is to replace the hard drive. The mere presence of bad sectors indicates drive problem which in the normal course of time/usage would increase and eventually make the drive inoperable. Using such a drive as your "C" and/or to contain mission critical files may not be to your advantage. Hope this be of some idea/help. Good luck and kind regards.
Sep 28, 2007 | Seagate ST3250820A 250 GB EIDE Hard Drive
Microsoft Windows Server Standard 2003 for PC Logo
250 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
