Question about Zanussi 24 in. DE6844ALU Free-standing Dishwasher
Zanussi DE 6854 dishwasher.
My problem is,I close the door press the power button in (which lights up ) press the programme button and nothing happens,none of the other lights work
5 Suggested Answers
MNfisherman
  • 11896 Answers
SOURCE: De Dietrich dishwasher model DVF300JU2
try pressing stop or cancel button for 10 full seconds. If this does not work, unplug the machine for 10 minutes. While unpluged, press and hold cancel or stop but for 10 seconds, then plug machine back in. If it still does not work, test the door switch with an ohmmeter to make sure the door switch is not faulty.
Posted on Jul 12, 2010
  • 174 Answers
SOURCE: Got a zanussi dishwasher zsf6160, lights working
if you can here the drain pump run at the start the fault is with the water valve or blockage in the side tank on the lh side. if you dont here the drain pump it possibly the heater thats down to earth. the electronics can detact it and not start the prog if heater faulty.
Posted on Jul 22, 2010
SOURCE: Zanussi Aquapulse DE6854 dishwahser programe lights not working
hi
got same probleme with my aquapulse 4744 slimline
Posted on Sep 25, 2010
mc1bean
  • 3053 Answers
SOURCE: my zanussi dishwaher de 6854 is stuck in cycle and
Hello, edwin
I was trying to help you out here. I am not sure if this well help you? But here is a link to about everything you want to know about your dishwasher, from repair to trouble shooting on most common dishwashers. If you go to this link and click around, I am sure you will find out so much about your Dishwasher, you will know more that the company that made it.If you already solved the problem this is good for future problems. Here Is the link for you to click on.
http://home.howstuffworks.com/dishwasher.htm
Please if this helps you at all, and if you can find the time to rate my help and some kind words written would be appreciated for my free help. Here is also my direct link to my own pages of other areas of my expertise for other problems you might have in Automotive,Appliance, and Electronics. Drop In anytime for my help. Thanks So Much, Mike :)
http://beta.fixya.com/users/mc1bean
Posted on Oct 27, 2011
Zanussi dishwasher ZDF601M 1 in 3 red light comes on and programme doesn't work through
26269906-aipk5px1bmfkdpsmrgevaqwn-3-0.jpg "3 in 1" function
This appliance is equipped with the "3 in 1" function, that
allows the use of the "3 in 1" combi detergent tablets.
This function can be selected with all washing programmes.
With the selection of this function the inflow of rinse aid and
salt from each respective supply container is automatically
deactivated and also the indicator lights for salt and rinse aid
are deactivated.
Select the "3 in 1" function before the set of a washing
programme.
Once this option is selected (indicator light illuminated) it will
remain active also for the following washing programmes.
With the use of the "3 in 1" function, the cycle durations may
change. In this case, in the digital display, the indication of the
running time of the programme is automatically updated.
NOTE: Once the programme is running, the "3 in 1" function
can NO longer be changed. If you want to exclude the "3 in 1"
function you have to cancel the programme setting (see
chapter "Starting a washing programme" - "Cancel a washing
programme in progress") and then deactivate the "3 in 1"
function.
In this case you have to set a washing programme (and
options) again.
Activation/deactivation of the "3 in 1" function
(The dishwasher must be switched off)
1. Press the On/Off button. The On/Off indicator light
illuminates (setting mode).If a programme button indicator light is on, this means that a washing programme is set. The programme must be cancelled: press simultaneously function buttons 2 and 3
for about 2 seconds. All the indicator lights will turn off (except for the On/Off indicator light and eventually salt and rinse aid indicator lights) indicating that the set programme has been cancelled and the machine is now in setting mode.
2. Press simultaneously function buttons 2 and 3, until the
indicator lights of function buttons 1, 2, 3 and 4 start
flashing.
3. Press function button 4, the indicator lights of function
buttons 1, 2 and 3 turn off while the indicator light of function
button 4 goes on flashing.
4. Press function button 4 again, the "3 in 1" indicator light
illuminates, indicating that the "3 in 1" function is active.
To deactivate the function press function button 4 again, the
indicator light turns off.
5. To memorise the operation, switch off the dishwasher by
pressing the On/Off button or wait about 60 seconds after
which the dishwasher will automatically return to setting
mode.
Dado
Aug 29, 2016 | Zanussi Dishwashers
How to reset Zanussi zdt6252 dish washer
To reset a programme in progress, open the door and press the push button of the programme under way for more then 1 second, until the corresponding indicator light goes out. The dishwasher is now reset and you can select a new programme.
Dado
Mar 03, 2015 | Zanussi 23 in. ZDT6252 Built-in Dishwasher
What do these mean on a zanussi dishwasher model DE 6854
The top light is apparently to indicate that the salt (!) has run out.
The bottom light is apparently to indicate that rinse aid has run out.
For the record, that seems to be a Zanussi DE-6854 dishwasher, and I found the manual here: (link)
"Special salt can be added in one of two ways: 1) If you are using dishwasher detergent that already contains salt, the detergent including the salt is placed in the detergent compartment. - In this case the water softener must manually be set to 1 and electronically to 1 to ensure that the special salt is taken from the detergent container only. 2) If you are using dishwasher detergent and salt separately, the special salt is to be put into the salt container. - In this case the water softener must manually be set to 1 or 2 and electronically between 1 and 5 (depending on the water hardness in your area) to ensure that the special salt is taken from the salt container only. Only use salt specifically designed for use in dishwashers. All other types of salt not specifically designed for use in a dishwasher, especially table salt, will damage the water softener. Only fill with salt just before starting one of the washing programmes. This will prevent any grains of salt or salty water, which may have been spilt, remaining on the bottom of the machine for any period of time, which may cause corrosion." (Page 6)
"Only use branded rinse aid for dishwashers. Never fill the rinse aid dispenser with any other substances (e.g. dishwasher cleaning agent, liquid detergent). This would damage the appliance." (Page 7)
The manual also explains how to turn the Rinse Aid light off permanently if you do not wish to use rinse aid.
Mar 23, 2013 | Dishwashers
My zanussi dishwaher de 6854 is stuck in cycle and will not run through programme. water does not heat - presumably because it sticks in first component of any cycle.
Hello, edwin
Jul 10, 2011 | Zanussi 32 in. DE6755 Dishwasher
I have a F&P dishwasher model DW60CDX1 (around 5 years old) which we cannot start a cycle. The dishwasher turns on (power button and all programme indicators light up) but when you press a programme...
The micro switch in the door which senses the door closing has probably failled. This is accessible once the inner door cover is removed. Switch should be under $10 from electrical store. Or buy through appliance manufacturer.
Jan 17, 2011 | Fisher and Paykel Dishwashers
Zanussi ZWF1437W washing machine - wont start
The error message "Err" usually indicates that the wash program and option are not compatible. 40 degrees and 900 rpm Spin should be o.k.. I would try another wash program with no special options and see if the problem goes away.
Jan 24, 2008 | Zanussi ZWF1430W Front Load Washer
Zanussi Washing machine
when any of the buttons are pressed ERR is displayed.
Jan 24, 2008 | Washing Machines
Zanussi FLE1416W Front Loader
Most possible reasons that the door switch or timer unit is defective. The dishwasher should heat the water to about 55 C as the heating cycle starts. In these cycle, the dishwasher pauses after has filled with water and wait for the water to reach the temperature. If the water isn't being heated (because of a problem with the heating element or thermostat), after the unit stops at the heating cycle, it never continues. if you think that a user manual may help you more, it can be downloaded ($8.95) at url: http://www.download-manual.com/shop/Zanussi-FLE1416W-User-Manual-pr-8261.html
Jan 22, 2008 | Zanussi FLE1416W Front Load Washer
INDESIT DW S 60
check and make sure the door switch is activating
Jan 03, 2008 | Indesit 23 in. DV62 IX Built-in Dishwasher
Zanussi 24 in. DE6844ALU Free-standing Dishwasher Logo
57 people viewed this question
Top Zanussi Dishwashers Experts
Paul Carew
Charles T Nevin
Charles T Nevin
Are you a Zanussi Dishwasher Expert? Answer questions, earn points and help others
