Question about Microsoft Windows Server Standard 2003 for PC
Registry files Sir Could u please tell me what are registry files and the usage of it.
  • 282 Answers
Go here .. http://en.wikipedia.org/wiki/Windows_Registry
Posted on Jul 17, 2008
Sir, I use the window 7 home basic in my laptop. but the problem is internet via wire do not work properly for the last few days. please tell me solution. thanks
It seems that there is a virus infection in the computer.
Please remove the connectors at the computer and the Router as well and replace it.
Please check the Internet connection using a different browser.
Please reset the Internet Explorer and check the issue.
Run ccleaner application to tuneup, this will remove all unwanted files like temporary files and other unused files and run registry cleaner.
This should resolve the issue.
If problem persists, please check if you can connect to the Internet using different computer.
May 25, 2011 | Computers & Internet
R6002 floating point support not loaded
Hi
R6002 is a run time error which can occur in your system.This happens when there are some files missing or corrupted in the registry..Nothing to worry about though because this specific error hardly affects your usage as you will be able to use all the applications normally.But in some cases errors in the registry can also cause serious damage to your pc.So my suggestion will be to install a registry fixer or cleaner software and run it once a week or month depending on your usage.But beware not all registry cleaners are genuine and will ask you to pay for it. So the best program to fix your registry will be CCLEANER from PIRIFORM which is free.Following is the link to download ccleaner-:
http://www.filehippo.com/download_ccleaner/download/81bb508f8b3bb99cd1e6670e7cbfa38b/
Copy and paste this link to the address bar and download the setup file.After downloading install the software and run the software.As soon as it opens up you will see four options on the left hand side ie.CLEANER,REGISTRY,TOOLS AND OPTIONS
Select registry and click on SCAN FOR ISSUES.Now when the scan is complete click on FIX SELECTED.
Restart your computer and it will not give the same error again
Hope this fixes your problem if not please reply
Thanks & Regards
LonG LIVE tHe GeEKs!!!!!
Dec 09, 2010 | Computers & Internet
Error code 39 missing driver or corrupted
Hi chillango1,
It is required to edit the registry files to fix this issue. Editing the registry incorrectly may cause series software issues in the Computer. Hence, please backup the registry before proceeding for editing.
To backup the registry, please open the run window and type regedit. Then in the Registry Editor window, please click File and click Export. Please select a location to save the file.
After saving the file, please proceed to edit registry.
Please click the "+" symbol next to HKEY_LOCAL_MACHINE, System, CurrentControlSet, Control, Class and click on the {4D36E965-E325-11CE-BFC1-08002BE10318}.
Then you can view the UpperFilters and LowerFilters values on the right pane of the Registry Editor window. Please right click on UpperFilters and select Delete, then select LowerFilters and select Delete.
After that close the Registry Editor window and restart the Computer.
This should fix it.
Good Luck
Please post back if you require further assistance.
Thanks for using FixYa.
Oct 24, 2010 | NEC ND-3540A DVD RW Dual Layer Burner
Hello sir , my problem is that i
ok ,you can download the registry mechanic version 9.0.0.129
after the download the software requires a name and key
you can enter this key for that version
Name: Team CRD Serial: 0VGB9A-4FF5YV-Q2U4U3-FNEBY2-4APDY9-YF6YRQ copy and paste this to the portion.
if this information was helpful please vote for me and write a comment for it. please.......
Sep 02, 2010 | Aladdin Systems Allume Systems ShrinkWrap...
Computer is very very slow, also takes for ever to get on the internet
Hello Sir,
I can suggest you a software that can maintain your computer stable and smooth. Try the download link if you would like to..
LINK
http://www.auslogics.com/en/software/boost-speed/
Thank You
Aug 09, 2010 | Gateway Computers & Internet
Pc working slow. i have done disk clean up deleted temp files .scanned pc with 3 antivirus but none detected any threat .i have 1 gb ram and 80% free hard disk space.i have downloaded ccleaner and fixed...
Dear Sir,
go to hyttp://xviruslab.blogspot.com and go to System Utilities find PC Booster download and install and run a auto run it will clear all your problems
bye bye
keerthy
Sep 29, 2009 | Computers & Internet
Sir i have downloaded a game from net i installed it and tried to open but it gives a message "this application was faiiled to start because mss32.dll file is missing" plse help me to start the game
Mss32.dll Error is a common Windows error message. Mss32.dll Error is usually caused by a missing system files, wrong system settings or a corrupted registry file. Use CTRL+ALT+DEL to get the task manager, if there is anything listed with [Not Responding] end task it. Next, run a registry scan to check for registry errors & other system problems. 96% of the time this will fix the cause of the error
It is best to clean your registry in order to optimize system performance & Fix the cause of many Windows Errors.
Apr 14, 2009 | Computers & Internet
How to remove manually Malwarrior rootkit malaware please help
Sir,
Manual removal of any spyware can be difficult. When you try to manually remove MalWarrior 2007, you risk destroying your PC. It’s highly recommended you use an automatic spyware scanner to determine you’re infected with MalWarrior 2007. It’s also recommended you backup your system any time before editing your registry.
Your Windows registry is the core of your Windows operating system, storing information about user settings, system preferences, and software, including which applications automatically launch at start up. Because of this, spyware, malware, and adware will often bury their own files into your Windows registry so that they automatically launch every time your start up your PC.
Because your registry is such a key piece of your Windows system, you should always backup your registry before you make any changes to it. Editing your registry can be intimidating if you’re not a computer expert, and when you change or a delete a critical registry key or registry value, there’s a chance you may need to reinstall your entire Windows operating system. Make sure your backup your registry before editing it.
  1. Select your Windows menu “Start,” and click “Run.” An “Open” field will appear. Type “regedit” and click “OK” to open up your Registry Editor.
  2. Registry Editor will open as a window with two panes. The left side Registry Editor’s window lets you select various registry keys, and the right side displays the registry values of the registry key you select.
  3. To find a registry key, such as any MalWarrior 2007 registry keys, select “Edit,” then select “Find,” and in the search bar type any of MalWarrior 2007’s registry keys.
  4. As soon as MalWarrior 2007 registry key appears, you can delete the MalWarrior 2007 registry key by right-clicking it and selecting “Modify,” then clicking “Delete.”
Computer acting funny after you’ve edited your registry and deleted MalWarrior 2007 registry keys? Just restore your registry with your backup.
How to remove MalWarrior 2007 DLL files: Like most any software, spyware, adware, and malware may also use DLL files. DLL is short for “dynamically linked library,” and MalWarrior 2007 DLL files, like other DLLs, carryout predetermined tasks. To manually delete MalWarrior 2007 DLL files, you’ll use Regsver32, a Windows tool designed to help you remove DLL and other files.
  1. First you’ll locate MalWarrior 2007 DLL files you want to delete. Open your Windows Start menu, then click “Run.” Type “cmd” in Run, and click “OK.”
  2. To change your current directory, type “cd” in the command box, press your “Space” key, and enter the full directory where the MalWarrior 2007 DLL file is located. If you’re not sure if the MalWarrior 2007 DLL file is located in a particular directory, enter “dir” in the command box to display a directory’s contents. To go one directory back, enter “cd ..” in the command box and press “Enter.”
  3. When you’ve located the MalWarrior 2007 DLL file you want to remove, type “regsvr32 /u SampleDLLName.dll” (e.g., “regsvr32 /u jl27script.dll”) and press your “Enter” key.
That’s it. If you want to restore MalWarrior 2007 DLL file you removed, enter “regsvr32 DLLJustDeleted.dll” (e.g., “regsvr32 jl27script.dll”) into your command box, and press your “Enter” key.
Thanks
Good Luck
"Don't forget to rate the solution"
Jun 21, 2008 | Computers & Internet
Windows 98 explorer wont start due to ibm0000.exe file is missing or currupt
Those registry mechanics are notorious for screwing up your registry. Unless you have a backup of your registry that you can load, you'll have to reinstall windows.
Dec 09, 2007 | Microsoft Windows 98 for PC
Microsoft Windows Server Standard 2003 for PC Logo
22 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
