STICKY M key on lap top keyboard - Computers & Internet
  • 36 Answers
Do You think its a physical problem with the key
whats make and model?
Posted on Jul 17, 2008
Re: Microsoft wired 600 keyboard/sticky keys... Wanting to know how do I enable sticky keys on my Microsoft wired 600 keyboard pls?
Sticky Keys is a software function. I am assuming you are using Windows - open the Control Panel, select the Ease of Use Center, select Make the keyboard easier to use. In here, you can turn on and setup Sticky Keys.
Dec 21, 2016 | Microsoft Computers & Internet
Dell inspiron n4030 keyboard not working
Shapsog,
You may need to turn off the Filter Keys option. Follow the steps below to turn them off.
Go to
1. Control Panel
2. Ease Of Access Center
3. Make the keyboard easier to use
4. Uncheck the "Turn on Filter Keys" option
You also may need to Check to be sure you don't have Sticky Keys enabled.
BY PRESSING THE SHIFT KEY FIVE TIMES
Without pressing other keys, press the SHIFT key five times to enable Sticky Keys. A window will be displayed asking you if you wish to turn on Sticky Keys Clicking Yes will enable Sticky Keys or click No.
If none of these steps work you may need to replace the keyboard or plug in an external USB keyboard.
Thank You,
Dell-Jesse L
Dell Social Media and Coimmunities
Oct 19, 2015 | Dell Inspiron N4030 14 Inch Notebook...
How to remove keys from mk700 keyboard?
This works for most keyboards:
Take something sturdy and hard but not sharp, such as a butter knife. Insert it under the front of the key just a little way, don't force it. Pull upwards gently. The key should pop off. You can clean them with gentle dish soap and wait until they completely dry, then put them back on. If the key is still sticky, take it off again and use a cotton swap dipped in alcohol (not dripping--rub against the inside of the bottle so it's just moist) and gently swab the area underneath the key. I have cleaned numerous keyboards because I have kids who share my desk tops and kids are frequently sticky. :)
Jul 09, 2014 | Dell 0Y3740 Keyboard
Shift key is not working
You might consider using, at least tempory, a external usb keyboard with a touchpad, you can get get them at Wal-Mart for around $20.00
Otherwise consider taking it to a computer shop and have them test the keyboard and if need be order you a new one. If this computer is still under warranty then I would would talk to the support team that you purchase it from. Good Luck.
Mar 28, 2014 | Computers & Internet
My lap top Computer keyboard keeys leep sticking
it might be dust effect or inside the rubbers got over its life time.. clean it or change the keyboard..
Jan 31, 2014 | HEWLETT-PACKARD Computers & Internet
How do I fix sticky keys on netbook?
Physically sticky keys because you spilled something on them or sticky keys keyboard shortcuts?
The first you don't really unless you want to dismantle the keyboard and clean the entire thing (do-able but it would take you a long time and you risk breaking the pieces under each key) I would just buy a new keyboard on ebay for $15-30 and have someone replace it.
Second, keyboard short cuts you can disable under Control Panel > Ease of Use > "Make the keyboard easier to use" and uncheck sticky keys.
Comment if you need more assistance and please rate the solution if you found it useful.
Thanks,
Justin
Nov 07, 2011 | Acer Aspire One Netbook 8.9" Notebook
Shift key not working
You have 2 Shift keys on the keyboard. If the other shift key is working then the shift key that is not working is defective. You should consider replacing the keyboard on your laptop. There is no setting on Windows that can disable the shift key.
**Note : If both Shift keys are not working, Try to check if sticky keys feature on windows is on. Sticky keys should be disabled. To disable sticky keys, Click on start and Go into control panel > Accessibility Options, and under keyboard there is sticky keys. Remove the tick and click apply and OK.
**If "Use Sticky Keys" is unchecked, that means sticky keys is disabled.
May 29, 2010 | HP Compaq nc6000 Notebook
I have a hp laptop model no dv 2046 tu...the problem i m facing is that my keyboard's ctrl key is stuck...whenever i press any key....a combination of that key wid ctrl is is taken...example....if i press...
This solution is for Windows XP.
If you see no physical sticking, then you may have "Sticky keys" on.
To look to see what your "Sticky Keys" Settings is at do the following:
In "Control Panel" double click "Accessibility Options"
A new window will pop up. The first tab is "Keyboard".
The first box at the top is "Sticky Keys" make sure that is unchecked.
"Sticky Keys" can be automatically turned on if you hold down certain keys for a predetermined length of time. Usually a box will pop up asking if you want to turn it on.
Thank you.
Please rate me.
Jan 27, 2009 | Computers & Internet
Dell lap top keyboard keys "s" and "a" are messed up
Ok, first try looking under the A,S & D keys and see if there is anything stuck in there by those keys.
You can then try blowing with mouth or a can of pressured air to clean it out.
If nothing stuck in there, does the keys feel sticky, if so, then there might have been some liquid spilled on it. Try to dry it out with a hairdryer set on medium to see if that helps.
keep me informed
Dec 13, 2008 | Dell Inspiron 6400 Notebook
Computers & Internet Logo
29 people viewed this question
David Payne
David Payne
