Question about Freezers
Fridge freezer door alarm continuously beeping
I have just swapped the doors of my hotpont ff 200e firdge freezer to open the other way and now cannont get the alarm to stop beeping. have followed instruction of turning onto off and then removing the plug but to no avail. any ideas
  • 93 Answers
Make sure gasket is sealing also make sure light is going out.
Posted on Jul 18, 2008
How can i stop the door ajar alarm when door closed and 0 f
Hey friend, thank you for your post!
In order to stop the door ajar alarm from beeping when the door is closed you would need to reset the alarm. If you have done that and it continues to beep it could be an issue within the switch or panel of your Frigidaire freezer. I would recommend having a professional come out to properly diagnose your appliance. -Matt
Sep 19, 2014 | Frigidaire Freezers
Bosch Fridge Freezer (KAN62V40GB)suddenly started beeping and the temperature has increased. The normal alarm whent he door is not shut correctly is a continuous tone, however this is beeping like an
Check the condenser is clean and the fan running normally, Any excessive heat from under or behind is a sure sign the fan may need replacement.
Apr 28, 2014 | Freezers
Freezer alarm
Hi Clair, thank you for allowing me to assist you.
When the refrigerator is beeping or buzzing, it may be a warning sign of a possible malfunction or an unsafe, interior temperature. To silence the buzzer, you can depress the ALARM OFF button. However, if you have already done this, try unplugging the unit or flipping the household circuit breaker for about ten minutes.
If the alarm continues, it could possibly be experiencing a communication problem with the temperature control/board or wiring failure. I would recommend connecting with a professional appliance tech for a clear-cut diagnosis.
Sep 06, 2013 | Electrolux Freezers
Fridge door Magnet does not work
do you mean the door seals,if so you may need new ones or you have lost the vacuum in your ff, they are not magnets they feel like it but it is vacuum sealed,,try a ff second hand shop
Mar 27, 2013 | Kenmore 17.5 cu. ft. Top Freezer...
My Miele freezer the alarm bell is bleeping but it is not defrosting what could be the problem please.
The beeping could be a low temperature warning. Check to make sure the temperature is staying cold enough and then check the door seal. Use a store bot fridge/freezer thermometer. Use a dollar bill to check seal. If you close door on the bill it should hold the bill tight but still let you pull it out. If it is loose then you need to adjust the door to fit tighter.
Sep 21, 2010 | Miele Freezers
The alarm keep beeping and when I turn it to off (the reser alarm) the freezer will not keep food frozen. Please Help!
Sounds like you have a bad door switch. Depending on the age of the fridge, it might still be under warranty. If it's not, then you might be able to access the door switch yourself and pull it out & replace it.
This is common. Unplug it or turn off the circuit breaker for a full 5 minutes. Things will be good
Aug 09, 2010 | Frigidaire 20.3 cu. ft. Upright Freezer...
Hi, i have a whirlpool american style fridge that beeps etc.
its the compresor packed up,,,if this compresor is not pumping freezer gas around the pipe work the freezer wont work sorry but a new compresor is not a cheep thing to have fitted as it will need a re-gas as well
Jun 29, 2010 | Freezers
Westinghouse fridge freezer alarms keep going off
Try a different web site, where are the solutions on this one????? Great site..... not
Dec 30, 2009 | Freezers
Firdge freezer
This is caused by one of several things:
  • door left open
  • bad gasket
  • open liquids in fridge
  • dirty condenser radiator...clean it
  • low gas in refrigerant system
Defrost the unit completely and restart. If it happens again, suspect the last and get a service person in.
May 27, 2008 | Freezers
Freezers Logo
381 people viewed this question
Top Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Freezer Expert? Answer questions, earn points and help others
