Question about Cuisinart DGB-600 Coffee Maker
Water leaking from the base of the unit.
Water leaks from the base of my Cuisinart DGB-600 coffee maker.
  • 3 more comments
  • Anonymous Mar 12, 2014
    I need a coffee maker to work in 220-240v. I am specifically interested in the "Cuisinart DGB-900". Do you know where I can find one or a different brand with similar capabilities? Thanks!
  • Anonymous Mar 19, 2014
    my SS-300 leaks when I turn it on
  • Anonymous Mar 20, 2014
    CDC 1200
  • Anonymous Mar 21, 2014
    I have the Cuisinart Compact Single Serve Coffee Maker SS-300 Model. The water won't dispense & all I hear & see is the water bubbling.
  • Anonymous Mar 28, 2014
    Leaking hot water spout, how do I fix
    Problem Solver:
  • 6 Answers
Water leaking in the DGB-600 is mainly caused by heated water escaping from its proper path. There is a rubber grommet on the underside of the upper part of the coffeemaker. (It contacts the lid over the filter basket when the front door is closed.) The design in this area is very poor; the grommet does not seat properly in the fixed part of the coffeemaker, and heated water seeps out. Also, the heated water tube that comes up through the cold water reservoir is actually in 2 pieces. One goes inside of the other, but there is no seal. It is a loose enough fit that some steam escapes, condenses on the inside top surface of the coffeemaker, and then finds its way down to add to the leaking. I completely disassembled my coffeemaker (3 of the screws in the upper compartment are hidden under small circular plugs that look like they are part of the plastic surface), and used high temperature automotive RTV sealer to help the rubber grommet seal better, and to seal the 2-piece hot water tube. Works great now! But I must say that I have seen better engineering in childs' toys!
Posted on Aug 12, 2008
  • lee rose Jun 21, 2013
    how does not disasseble. DGB 550.. 4 screws on bottom look like torx .. lee r. ( leerose17@hotmail.com) my unit will not turn off and grinder oscillates on/off
  • Janice Strickland
    Janice Strickland Mar 11, 2014
    OK; HOWEVER, I'M NO MECHANIC; BECAUSE OF POOR DESIGN I'M SUPPOSED TO JUST THROW IT AWAY?
How to fix the leak from the bottom of my cuisinart dgb-900bc
Re: Cuisinart grind and brew model DGB900BC leaking from the bottom. Finally fixed it before buying a new one. Remove the 4 torq screws (#10 bit check auto stores) from the bottom and remove the bottom. You will see a horse shoe shaped metal coil that heats the water from the resevoir. I found that the coil had a small hole in it. Cleaned it well and applied a coat of epoxy paste to the leaking area ( I used a product called PC11 from Ace) So far, no leaks, and the coffee maker is working like new.
Aug 10, 2012 | Cuisinart Dgb-900BC Grind & Brew Thermal...
I have a cuisinart grind & brew coffee pot that leaks when I put water in it. How can I open it to see where the water is coming from?
The Manual for your coffee maker can be found here:
http://www.cuisinart.ca/pdf/ibs/en/DGB-600BCC_en.pdf
'Leaks' are usually caused by overfilling either the water reservoir or the coffee basket or by coffee grounds interfering with a seal.
Make sure you perform a complete cleaning on your coffee maker making sure any contact points which need to seal are free of coffee grounds.
Instructions for removing the grinder and filter baskets are contained within your manual.
Feb 06, 2011 | Cuisinart DGB-600 Coffee Maker
Coffee maker is leaking water
6300mobile restriction code send
Apr 13, 2010 | Cuisinart DGB-600 Coffee Maker
Wattage of a Cuininart DGB-600
The consensus seems to be that it is 1025 Watts, although I have a hard time believing it - not even a stand mixer is 1025 watts.
Apr 01, 2009 | Cuisinart DGB-600BC 10-Cup Coffee Maker
Cuisinart dgb-600 brew pause feature doesn't work
Replace the filter basket - they can be had for around $6.00 plus shipping - you can even get them directly from Cuisinart.
Jan 23, 2009 | Cuisinart DGB-600 Coffee Maker
Taking apart a Cuisinart DGB-600
I pulled it almost all the way open- towards back and used a flat screwdriver (or small philips that can fit in space from behind) and I pushed up a bit towards center and it came right off- don't worry- shouldn't break if you just ease it out of it base on either side.
Nov 22, 2008 | Cuisinart DGB-600 Coffee Maker
Where do I purchase replacement charcoal water filters for my coffee maker?
Cuisinart DGB-600 replacement charcoal water filters is Cuisinart DCC-RWF 6 pack charcoal water filters, 12 filters.
Oct 17, 2008 | Cuisinart DGB-600 Coffee Maker
DGB-600 grind & brew thermal coffeemaker
Jul 21, 2008 | Cuisinart DGB-600 Coffee Maker
Water is leaking from bottom of base.
I just had good luck pulling the grinder bottom piece forward while pulling directly up on the blade mechanism. Hope this helps.
Dec 25, 2007 | Cuisinart DGB-600 Coffee Maker
Cuisinart DGB-600 Coffee Maker Logo
1,667 people viewed this question
Top Cuisinart Coffee Makers & Espresso Machines Experts
Greg Cann
Greg Cann
880runner
Level 1 Expert
Michael Galve
Michael Galve
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
