Question about Uniden Cordless Phone
New battery is not charging
Recently replaced our GE cordless phone battery with a new Radio Shack one. two new batteries later, it still has not recharged! no problems with phone before we replaced the battery
  • 1 more comment
  • mjclem Jul 17, 2008
    the package says 3.6v and two different employees say it is the correct
    one. unfortunately, I don't have the original as they recycled it.
  • mjclem Jul 18, 2008
    the lights are on on the charger, it looks like it is charging.
    am not sure what you are talking about, but you have given me an idea....
    we have another cordless, with similar battery, will switch and see if that 'charged' battery can get the charger going....
    thanks
    AlmostBob
    It worked! Although I didn't exactly understand what you were saying, I
    took the working battery from our other cordless to see if it would
    'jumpstart' the other phone. It worked...turned out that although they
    had looked up the battery in RadioShack's book, it had given them the
    wrong number. Took the one back today and exchanged for the one I knew
    worked and now have 2 working phones!!!!
    Thanks a bunch.
    mjc
  • 550 Answers
Size and shape of rechargeable battery packs are not an indicator of the voltage, it is possible that the identical looking battery has two cells in each tube so is 7.2v instead of 3.6v
do the specs match
not a solution yet, just a query
Posted on Jul 17, 2008
  • AlmostBob
    AlmostBob Jul 18, 2008
    the connectors are standard, not reversible +-, cant be that
    are the lights on on the charger,
    there might be a voltage sensor, if the battery were delivered DEAD flat, there may not be enough residual valtage to trigger the charger starting, supposedly a safety feature so you can touch the charger pins, not really important for a 3.6v system, but the same controlller chip is in 36V 300A forklift chargers
    a battery to the pins in parallel with the phone, when the phone is inserted in the cradle, to trick the voltage sensor might be enough to start it
    still not a solution
    grasping at straws,
    batteries are usually delivered part charged
  • AlmostBob
    woo, not gonna throw away any straws now,
    Congrats
    dos V'danye
Need to replace batteries in handheld
they are available at walmart, radio shack , target, and kmart. normally. take the bad battery out of the handset and match it up with your replacement unit..reinsert it and connect it in and let charge for half a day..home depot and lowes has them also..
Feb 02, 2014 | GE RCA DECT 6.0 Handset for 25255RE1...
I have a CTP8600 Cordless phone made by Coby in 2003. The battery pack for the handset is apparently no longer charging. Coby has stopped making (or supporting) this product. I would like to replace the...
Try taking the battery pack to your local radio shack store. They can usually match the original battery pack with a new, compatible one even if they no longer make the EXACT one that came with the phone. This recently happened to me with a panasonic phone bought around 2002. phone stopped charging, no longer make the phone, etc. I went down to radio shack and they fixed me up with a new battery (not exact brand/part number as original) and it worked. Hope this helps you.
May 20, 2011 | Coby CT-P8600 Cordless Phone (CTP8600)
My uniden cordless phone is not recharging, even tho i bought today a new battery at 17 dollars a pop at radio shack. the regular part of the phone unit with the answering machine on it works fine, help???
Your phone charger is shot. New batteries will not help if your battery heats up during charge or stays hot when left on charge. If the battery never gets warm and your charge light doesn't come on then it is a different problem. The phone manufacturer suggests you buy a new phone.
Sep 08, 2010 | Uniden Cordless Phone
Battery not staying charged on one of the two handsets
Replace the battery. They do go bad. Sometimes Radio Shack used to have replacements for some models of cordless phones.
To verify if battery is bad, swap between the phones and see if it follws the battery.
Nov 28, 2009 | Uniden Cordless Phone
Phone will not hold a charge
Almost certainly you will have to spend $50 or $60 on a new battery. Assuming it has a removable battery, which most cordless phones do. Take the phone to Radio Shack and see if they have the proper replacement battery.
Jul 12, 2009 | Vtech 5.8GHz Cordless Phone with Digital...
Need battery 5-2729 3.6v 600mAh
Try Radio Shack or www.batteriesplus.com You're sure to find a replacement battery at one of those two places. Good luck.
Apr 15, 2009 | Uniden Cordless Phone
Where can I get Batteries - 5-2770, 3.7v for GE 6.0 Slime Line Phone
Budget Batteries has them for $15.99.
http://www.budgetbatteries.com/ge-5-2762-and-5-2770-battery-cordless-phone-bb-044145.html
Dec 24, 2008 | Thomson GE-28115FE1 Cordless Phone
Low battery problem
Although your batteries are exhibiting a charge memory effect a little early, it doesn't surprise me too much after the phones are in use for two years.
You need to replace the batteries in your cordless phones. These you can find at any Radio Shack. Once yo have installed the new batteries you want to let both batteries go dead from use, keep them off the charger stand for this break in period. If you can do this your phones batteries will last longer.
For more information on rechargeable battery memory effect read this article.
Regards and thanks for using Fixya.
Jun 08, 2008 | GE 21018GE3 Cordless Phone
Uniden Cordless Phone Logo
243 people viewed this question
Top Uniden Lands Phones Experts
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
