Question about Vizio GV42L 42 in. LCD Television
The picture on my tv is too big
I have a vw42 l flat screen vizio t.v. we have had it for several months. recently the picture on it is too big for the screen. so i cant see any of the writing on the bottom of the screen. like for instance, when who want to be a millionaire is on, i can only see the first 2 answers and not the bottom ones. can you please help me as it is driving me nuts and i cant find my owners manual
  • 3 more comments
  • 50vizio Jul 19, 2008
    We have the same problem with 50 in. plasma, please let me know if you find an answer. tried every bottom on remote and menu.
  • Anonymous Aug 10, 2008
    Have same problem. With my Sharp tv is deals with the picture mode. It happend when you have a smaller non HD picture leaving black boxes on the sides. If you use the zoom feature to use the whole screen then you lose some at the top and bottom. I can't find the fix on the Vizio yet.
  • Anonymous Aug 13, 2008
    I have the same problem. The picture is too wide and cuts off right side.
  • medding Sep 14, 2008
    same here
  • corvettelady Nov 06, 2008
    Have the same problem notify can't get no one to help !
Take the remote for the TV...not the cable.
They usually have a RESET button.  Go through setting the TV back to factory settings.  This usually corrects this problem.
It did for us today!  john
Posted on Jan 01, 2009
  • Tim Brogdon Dec 10, 2011
    Didn't work for me. Any other solutions?
Screen seems stretched. How do I fix it?
60'' Vizio TV screen is stretched in 'normal' screen mode on HD ...
https://answers.yahoo.com/question/index?qid...
Jul 21, 2013 - Ive had this tv for almost a year and the screen has never given me problems, but just recently all the HD channels are stretched. ... If your Vizio is like my 47" it has 4 Picture Modes - Wide, Normal, Zoom and Panoramic. ... Why isnt my viziotv able to play full screen hd channels?
TV Problem: The picture on my television is stretched out on the ...
Aug 23, 2008 - It is a High Definition Vizio TV. The center of the screen is clear, but the television stretches the image out on the sides. Is there anyway to fix ...
How to Fix the Most Annoying Features of Your New HDTV ...
Dec 31, 2015 | Vizio VA Televison & Video
How do i get the picture to show on vizio tv screen i have hooked everything up am i setting the remote to vizio tv wrong
More info would be helpful; model number, signal source, etc.
You probably have not chosen the right 'source' yet.
This would be cable, satellite, or antenna-
Dec 27, 2014 | Vizio Televison & Video
When I turn on my Vizio, the picture is "squished" and the bottom 1/3rd of the screen is white static. The TV is only 6 months old.
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
Take it to a repair shop.
Apr 22, 2014 | Vizio Televison & Video
I have a 50" Vizio plasma tv that is about 5 years old. Recently when I turn it on it cuts off or blinks. I have to turn it off and back on several times in order to get the picture to come on. I am s
Yes it's. Just bring it 2the nearst electronic shop for repair. T power my be spoile or some insect get inside n make it burn. It's ever happen 2 my tv also.
Dec 04, 2012 | Vizio P50HDTV20A 50 in. Plasma HDTV
Vizio vt420m comes on then flickers and then doesn't show any picture, but the tv stays on
If you have not been using the TV for quite sometime, moisture would have developed some defects inside the TV when you switched on. Sometimes even insects and lizards might get in and cause short circuits. Anyhow this might require attention by a qualified service technician.
Jul 13, 2012 | Vizio VT Televison & Video
My Vizio VT420M LCD TV has for several months has changed to a dark screen while viewing without any other problems. We always hit "power/cable" on the HD cable box and it would immediately come...
Now the tv u turn on u have a flashes of a picture only few sec. and died have sound left only?Yes,than the 2 long boards call the LCD inverter boards are the causes and the problems.These 2 long LCD inverter boards help the LCD screen panel to have a backlight to produced a picture.Tries websites like Shopjimmy.com,Ebay.com to buy those 2 refurbishes long LCD inverter board for the replacement.
Jan 15, 2011 | Vizio VT420M LCD TV
Samsung big screen tv model pcl542r has a green or red tint to picture
This is for the 50" Vizio TV,
It sound like the control board has a problem. There is two way to fix this.
- Upgrade the firmware of the control board, If you can find the firmware upgrade device.
- Replace the control board (I think this the best solution)
Feb 08, 2009 | Vizio P50HDTV10A 50 in. Plasma HDTV
The other poster was right, there is a zoom button on my CABLE REMOTE and once I pressed that my problem was solved. It's funny none of the techs knew that, at either Vizio or Comcast.
Hope this helps.
Jan 15, 2009 | Vizio L32 32 in. LCD HDTV
Vizio GV42L 42 in. LCD Television Logo
1,384 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
