Question about Emerson EWD2004
Emerson EWD2004 - DVD Player
The dvd tray attempts to eject on it's on, but seems to get stuck about a quarter of an inch out. Can carefully pull the tray pass the "catch" and tray will automatically extend. Tray will retract all the way in automaticaly, but will then automatically attempt to eject which leads to getting stuck about a quarter inch out with door open. Please Help. Bill
simplemitch
  • 752 Answers
SOURCE: will not play my dvd-r
Is the media a compatable format? DVD player might play video cd's but not .WMV's for instance....
Posted on Sep 10, 2007
  • 6 Answers
SOURCE: door will not open or close
i ended up retrieving the dvd out of mine after it quit coming on by taking the top cover off and taking the cover off the dvd it just snaps in place by clipping on each side.
Posted on Dec 04, 2007
pincer
  • 377 Answers
SOURCE: dvd recorder stuck in Repairing Mode
I don't see any opening hole to retrive the CD inside the best option we can do is to open the the cover chasis and pull out the cd on the tray.
Thanks,
Posted on Mar 01, 2008
  • 416 Answers
SOURCE: replacing the DVD part of the Emerson EWD2202
You can buy the replaysment parts from Funai web site
Emerson is a one of tradmarks of Funai
Just follow this link
Good Luck
http://www.funai-corp.com/support/faq.aspx
Posted on Feb 03, 2009
  • 106 Answers
SOURCE: dvd stuck in player
  • unplug the system then take the screws out from bottom and try to open the whole thing then you will not only get the dvd out, you can clean the lens with a Q-tip and rubbing alcohol. or unplug then plug back in and see if dvd comes out after plugging in.
Posted on Mar 26, 2009
I bought an RCA RCR804BFDR UNIVERSAL REMOTE, I WAS ABLE TO PROGRAM THE TV, MY EMERSON VCR/DVD EWD2004 COMBO, I GOT THE VCR WORKING FINE,BUT THE DVD PLAYER WILL ONLY TURN OFF & ON. W/REMOTE. HELP PLZ!
Try to program the remoter for Emerson DVD too. code for DVD would be there in the manual you got. It will work.
If you wish to get some details; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Apr 13, 2016 | RCA Televison & Video
Tip
My 2910 player has similar issue. The tray gets stuck on eject. Started with not...
1)just open the player
2)remove the rubber belt connecting the dc motor
3)you can open the disc tray now
4)if there are any dust particles or obstacles in the door way just clear them up by using the cloth(dry cloth preferred)
5)if you have any greasy material like vaseline,oil,etc then just put that in the door for easy movement of the disc tray
6)if needed change the rubber belt which is connecting the dc motor
7) just reconnect the rubber belt again and then just fit all screws that s all
what s more your player s disc tray will start ejecting like the previous how you were using..
any doubts you can reply me
i am always here to assist you
thank you
bye
on Jan 06, 2009 | Samsung DVD-V4600 DVD Player/VCR
Program a original Magnavox remote to a Emerson DVD/VCR
If it is a programmable remote, select DVD to send code to the player
Jan 22, 2013 | Televison & Video
My sony dvp sr200p cannot eject the disk inside. i tried all the 4-digit code but i failed.
From www.sony.com
Unable to eject a disc.Solution
Follow the steps below to troubleshoot this issue.
IMPORTANT: If model-specific information is required to complete any of the steps in this solution, refer to the operating instructions supplied with the product. Manuals are available online through the Manuals/Specs/Warranty link on this page.
  1. Ensure the child lock feature is disabled.
  2. Attempt to open the disc tray.
  3. If the issue is not resolved, turn off the DVD player.
  4. Unplug the power cord from the electrical outlet for 30 seconds.
  5. Plug the power cord back into the electrical outlet.
  6. Attempt to open the disc tray.
  7. If the disc tray still does not open, simultaneously press the POWER + STOP + EJECT buttons.
  8. If the disc tray still does not open, simultaneously press the DISC1 + STOP + EJECT buttons.
    NOTE: This step may not apply to all models.DISC1 is not available on all DVD players.
Feb 29, 2012 | Sony DVP-SR200P DVD Player
Dvd player will not open disc, display lock
Sound like it either has one or two problems, the door is stuck and or the door eject motor has failed. Look in the front to the player for a small paperclip like hole, and use a paper clip to manual eject the and engage the loading mechanism usually located under the door for most cases. Check you manuals troubleshooting section for manually ejecting a CD..
Please leave comment.
Oct 12, 2009 | JVC XV-N312S DVD Player
Dvd recorder stuck in Repairing Mode
Thanks,
Mar 01, 2008 | Emerson EWD7003 DVD Player
Dvd tray wont eject
One way i have found is to (no joke) take the back panel off the TV BECAREFUL THERE IS HAZARDOUS VOLTAGE! Look to see if there is a DVD stuck in it, if so remove it. If this doesnt work let me know, i have other possible solutions
Dec 13, 2007 | Emerson EWC13D4 13 in. TV/DVD Combo
Eject tray belt broke
Opening the DVD player tray is not as hard as you would think.
1. Remove three black screws holding the outer cover on the unit (located on rear of unit)
2. Carefully remove front panel trim by gently prying six clips (3 on top, 3 on bottom) away from unit and pulling panel away from unit.
3. Locate opening at the front of the DVD player that houses a larger white gear.
4. Using a finger, gently move gear until DVD tray begins to move outward.
5. Continue until DVD is fully ejected.
6. Try plugging the unit back into AC outlet and attempt to Open/Close the tray using the provided button on the Front Panel Circuit Board.
7. Reverse steps above to put unit back together.
Nov 27, 2007 | Sony SLV-D350P DVD Player/VCR
Can't record on DVD's
I have a manual and it says it is a DVD player, not a DVD recorder, so that could be your problem - no recording fxn
Sep 09, 2007 | Emerson EWD2004
Emerson EWD2004 Logo
95 people viewed this question
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
