Question about Linksys Wireless-G Broadband Router
Wireless network I have tivo and I use a UBS wireless adaptor from Linksys. It worked fine at my old house when it talked to my qwest wireless router. Now we've moved and I bought a Linksys G wireless router and they wont talk to eachother. I spent over an hour on the phone with Tivo and they say the problem has something to do with the settings on my router. Linksys wont help me because my adaptor is past it's warrentee. But I know my adaptor is working because my Tivo is finding my wireless network it just isn't getting access. I've tried just about everything both the Tivo tech and I could think of and still getting errors... Any more ideas
    Novelist:
  • 173 Answers
Do you remember your wireless network name and the wireless security password for your router, check if you are able view the wireless network, try connecting to it..if it asks for passworg type in your password and check if nor revert back..
Posted on Jul 18, 2008
I want to get the TIVO AG0100 wireless adapter. I do not have wifi in my house so will it still work? I'm not planning on getting wireless for my computer.
Dear,
Since it's an adapter and not a router, it will not work if you don't have a previously installed wireless network.
You might buy a wireless router and connect it to your computer and use Tivo at the same time.
Jul 22, 2011 | Tivo AG0100 Wireless G USB Network Adapter
Tip
Do you have a Tivo Premier and are you experiencing wireless communication...
Recenty, I discovered that devices were dropping off of my wireless network (Netgear N300 wireless N with DSL modem). After trial and error, the solution to the wireless communication problems was to create a wireless N bridge using the Tivo Wireless N adapters.
To use this feature, you will need two Tivo wireless N adapters. One wireless N adapter should be set to bridge and plugged into an available ethernet port into your router. The second adapter should be set to client and plugged into the ethernet port in the back of the Tivo Premier. Once the power has been applied to both wireless adapters and the Wireless adapter (connected to the router) has connected to an available address on your router, press and hold the button (on top of each adapter) to establish a secure wireless connection between both adapters.
Once each adapter has established communication, you will have a separate 5Ghz Wi Fi signal (as well as a channel )dedicated to you Tivo devices throughout the house. Each Tivo Premier added to the house should have the wireless N adapter and connected using the secure connection to the wireless bridge by pressing the button on each adapter (the one on the router as well as the one on the Tivo to install).
If sucessfully installed, you should be able to connect to all Tivos on the network for management as well as streaming. If communication between the Tivos isn't successful, you will have to restart each Tivo and establish a new connection to the Tivo service.
Another suggestion when using the wireless N adapters is to setup a static IP address on each Tivo that is higher than the IP address assigned to the wireless adapter. Each Tivo utilized two IP addresses for each device (one for the adapter and one for the Tivo). You may have to check the router administration screen to determine the IP addresses used for the wireless adapters before establishing a static IP address for the Tivos. If you assign static IP addresses to each Tivo, you will have to restart each Tivo and reconnect them to the Tivo service to establish proper network mapping.
With this wireless network configuration, you will ensure that your Tivos are connected to the service using high speed, dedicated wireless N communication for streaming purposes between the services offered while not impacting other computers, servers, video game machines, and tablets that are connected into your house.
Since the Roamio uses a built in wireless adapter, you may not have success in adding a Roamio to the wireless bridge created on your router unless you disable the built in wireless adapter and purchase the external wireless N model from Tivo.
Instructions on setting up wireless bridge can be found at this location:
http://support.tivo.com/app/answers/detail/a_id/1590/kw/wireless%20n%20adapter
on Oct 02, 2013 | Tivo Premiere 4
We have lost the original disc that came with the TIVO and I need to get the Tivo wireless network adaptor set up on our wireless network. How can I do that without the disc, is thee anyway around that ?
The disk us usually not necessary. If you are using a series 2 TiVo you just plug this in to the back of the TiVo and it will recognize it. In the TiVo menu find Network Settings. If you select change network settings it will ask you to select your wireless router and ask for the password to your router if you are using one.
Dec 31, 2010 | Tivo Wireless-G USB Network Adapter
Wrt400n connects via ethernet cable, but won't talk wireless
you said every thing that connects with the ethernet is working. that means the wired part of the router is working. check the wireless settings of the router. Open the set up page of the router on the main computer. connect the main computer to the router with the ethernet cable.
change the wireless settings of the router.
WRT400N is a dual band router ( 2.4 GHZ and 5 GHZ)
You can create 2 different wireless networks. Make sure that the names (SSID) will be different for both the networks. For 2.4 GHZ change the standard channel to 6 and save the settings.
Go to wireless security and set the security mode to WPA Personal. set up password for the wireless network. You can use the same password for both the networks. Make sure that the Wireless MAC address is disabled.
Now try to connect to the new wireless network. and see what happens.
Click here for more information about routers
Mar 12, 2010 | Linksys WRT400N Router
I am running qwest DSL through a Linksys wrt160N that is brand new. it will work next to the router, but not upstairs or in the basement which is less than 15 meters. The upstairs bedroom is directly above...
If you have concrete floor slabs the the wireless signal from the Linksys will have a difficult time penetrating the floor slabs.
The wireless card in the computers will show a low signal strength.
Try altering the Linksys aerial to a horizontal position and also positioning the Linksys to another location.
You could be getting interference form other wireless sources, check the wireless channels of other wireless router/access points in your area. If they are broadcasting on the same channel then configure your Linksys to broadcast on an unused channel or one that has the weakest signal strength.
If none of these methods work then I would suggest you run network cables from the Linksys to upstairs and downstairs and not use the wireless connection.
If network cabling option is not an option then consider extending the wireless range with wireless repeater access points.
Nov 07, 2009 | Linksys WRT160N Wireless Router
I need instructions for a Linksys Wireless G router to work
Call your internet provider they will walk you thru the process.
Jun 18, 2009 | Linksys Wireless-G WRT54GS Router...
Linksys Wireless-G Adaptor - downloaded driver but can't install
Please don't snap lol no really go to linksys.com and download all you need.RICHARDM69
Feb 04, 2009 | Linksys WPC54G Wireless-G Notebook Adapter...
Linksys router and Belkin wireless adaptor
Anne ,
I need to ask is the driver for wireless adaptor installed ?
Thank you ,
Styme = )
Jul 28, 2008 | Belkin N1 Wireless USB 2.0 Network Adapter...
TiVo/Linksys Compatability
The router should be fine.
Use a Compatible Wired or Wireless adapter.
Jun 19, 2008 | Tivo Series 2 80-Hours Video Recorder
Linksys Wireless-G Broadband Router Logo
176 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
