Question about Epson Stylus C48 InkJet Printer
Flashing lights Is there a service sheet available/
  • 353 Answers
Yes I can - please respond if you still have it.
Posted on Feb 11, 2009
On my Whirlpool Gold the adaptive wash, rinse only, and start/resume lights are on. And the normal, hi temp wash, doorlock, and cancel/drain lights are flashing. Will not run a cycle.
This could be several things.
1. The heating coil in the bottom of the unit is bad.
2. The pump is plugged up with food.
3. The operating panel is bad.
If you take the kick panel off the front under the door, there should be a technicians service sheet. You can use that sheet to see what the exact problem is.
Apr 01, 2015 | Whirlpool Dishwashers
Start light flashing, wont wash
see this and fix it. if necessary replace it. God bless you
Main Control Module / CCU
The main control unit is the circuit board located behind the console. If the door switch tests good the main control is usually the problem. Check all connections for a goood tight fit. You will need to refer to the tech sheet or service manual to check this further. The main control is easy to replace.
Motor Control Module
The motor Control Module is located inside the cabinet down near the motor. This recieves the signals from the main control module then relays this information to the motor. Check all connections sometimes a communcation problem is just a loose connection. The Motor Control Module is easy to replace. To check this further you will need to refer to your tech sheet or service manual.
Sep 27, 2012 | Washing Machines
Hi i have just inherited a designjet 430,it is not connect to a computer as yet. i have loaded a roll of paper and ran some tests which seem to work ok except when i press the set up button the media light...
Either: the sheet you loaded is
Realign it again. See the Users Guide
for a short tutorial on loading media.
Or: it is an invalid size.
For supported media sizes, refer to the
Users Guide.
Or: the media lever is lowered.
Raise the lever.
Or: the cover is open when the printer is
Lower the cover
These are the trouble shooting suggestions from the HP service manual
May 01, 2011 | HP DesignJet 430 InkJet Printer
Duet washer is making a sounds like its running, but no lights are on and door is unlocked. I've trying pushing and holding buttons to no avail
Your tech sheet is below inside the service panel. Consult that tech sheet to see what errors are in diagnostics. Check the pump filter.
I have a manual HERE
Feb 12, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Just replaced ink and is barley printing regular letter
Your print head needs replacing:
Clean the print head then print a demo sheet.
  1. Verify that inkjet paper is loaded in the paper trays.
  2. On your desktop, start the KODAK All-in-One Home Center, then select the Help [?] icon.
  3. From the Help menu, select Maintenance, then select Print head Cleaning. The On/Off light flashes green during the cleaning procedure.
  4. When the On/Off light glows a steady green, press Photo and Copy simultaneously to print a demo sheet.
If the Demo print is bad- IE: no black, blurry print etc., then you may need to replace the print head:
Contact Kodak for a replacement:
Live phone support is available in English and Spanish at 1-800-421-6699, 9 A.M. to midnight Eastern time, 7 days a week.
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
Jan 29, 2011 | Kodak EASYSHARE 5100 All-In-One Printer
GU2300XTVT1 call for service light flashing (BRAND NEW)
Take off the kick panel on your dishwasher, inside the panel there should be a plastic pocket with a sheet of paper in it called a "tech sheet". This is a basic diagnostic tool for techs. It should tell you what the flashing green light is indicating. Every model is a little different so it's hard to say exactly what it is. The tech sheet will walk you through how to get it out of this mode.
Oct 03, 2009 | Whirlpool Dishwashers
Cleared a paper jam but E then 2 and alarm still flashing
Error code 2 is mean no paper present. Just put paper at the Auto Sheet Feeder.
Apr 01, 2009 | Canon MP140 PHOTO AIO All-In-One InkJet...
According to the service manual, that is an 'ASF (cam) sensor error' and solution being to replace the 'Sheet feed unit'.
Jan 18, 2008 | Canon PIXMA IP5200 InkJet Photo Printer
Whirlpool WTW6600SB
its under warrenty call for service if you attempt to fix it it will void the warrenty
Dec 05, 2007 | Whirlpool WTW6600SW Top Load
Epson Stylus C48 InkJet Printer Logo
48 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
