Question about Bosch 24 in. SHU43 Built-in Dishwasher
BOSH SHU43 dishwasher
I have a Bosh SHU43 dishwasher that has stopped draining for the second time. The first time I removed the control board to look for the famious bad solder joint, but all looked good. I reassembled the dishwasher & tried it & it worked after a fashion, that is to say it was very noisey while filling, suonded like a loud humming noise & the times were all longer then usual. Now it has stopped draining again & I want to fix it right. It is out of warrenty by 2 months. I called Bosh & they were very uncooperative, Told me to call a service center. When I called my local authorized service center they told me they never saw that problem before. I could use some advise & a wiring diagram. I am a master electrician so I can troubleshoot using diagrams. I would appreciate any help you can give. If I can't fix this lemon myself I'll replace it rether then pay a guy 70.00 to guess what parts are bad & probibly still not fix the problem
  • 54 Answers
From my experience.. usually when a motor is humming it could be something is stuck in your impeller.. if your can get to your drain pump to check it out.. and getting to your drain pump can be a pain.. good luck.. hopefully that works
Posted on Jul 28, 2008
Bosh dishwasher wont fill...also sink drains right intodiswasher.
sounds like your plumbing in your sink is going wrong way check pipes or your sink maybe have a clog in it
Nov 21, 2009 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
The water does not circulate throughout the washer. Is the pump bad? The full cycle will run without cleaning.
Before we jump to conclusions, you can try to clear element that discharges the water. The wholes in these units can become clog do to the detergent as well as food. Most Bosch units allow you to unscrew these pretty easily. Blow through them, or use a plastic tooth pick to clear any obstructions or both. Before you reattach, turn on dishwasher and listen to hear how much water is shooting out at the discharge points. Most Bosch have two discharge points one for the top and of course one for the bottom. Reattach units and Run dishwasher.
Should this fail it could very well be the circulating pump.
Oct 13, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosh Intergrated dishwasher not powering up...nothing at all
Check the circuit board in the control panel. Look for a burn mark on the relay board. This is the heater relay circuit. Push the tabs back around the connector areas, use a flat blade to pop the cover open.
Sep 07, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Dishwasher fills with water... stops...(when it should be washing) then drains. Seems like timed cycle is working. justdoes not wash.
you have a sensor and it is restricted behind the bottom panel you see a rubber hose about 1/4'' in size remove and blow through it unless it a Bosh unit some how water gotten into the motor area this is cause by a plugged drain hose
Aug 22, 2009 | Frigidaire Dishwashers
My dishwasher Bosh Model SHU43C06UC has the drain clog
first feel around the drain and see if there is something stuck inside the drain. then take a small amount of clorox2 powder and run it through a cycle. after that try jet dry. sometimes there is a grease build up or a lime build up that needs to be removed.
Apr 23, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosh shu43c never stops running.
If you have a Bosch shu4300...check this site.
http://fixitnow.com/wp/2006/06/09/bosch-dishwasher-takes-forever-to-complete-a-cycle/
My issue was a heater fault and fixed the problem by resoldering a bad joint. Works fine once this was fixed.
Nov 24, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Shu43 built in dishwasher
Running the hot water in the sink until you get the water hot then, make shore you are using jet dry. Bosh dishwasher dry with condensation. Let me know
Aug 02, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosch 24in SHU43, 3 years old
Un plug it for about an hour and  try it again.Its probably built a static problem on your circuit board.
May 25, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosh dishwasher shu3322uc/22
check for leaks where the the top rack plugs into the rear. it might not be sealing. If your unit has the ability to change the top rack height check in the other position and see if it works. In my Samsung (Bosch in disguise) model The tube to the top rack plugs into one of two holes in the rear, depending which rack position I use. Something covers the hole not in use. Bosch uses two seperate pumps for washing and draining. So I don't think the pump could go partially bad. (This happens in other brands when the solenoid gets stuck between pump out and recirculate)
May 17, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosch 24 in. SHU43 Built-in Dishwasher Logo
394 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
