Question about InFocus Proxima DP6155 Multimedia Projector
Proxima dp6155 The projector works fine in the upside down position, and shows fine when the main screen is up from the table top position. When the laptop is connceted, the screen has red line on the left side of the screen and there are double images projected on the screen. There again, it does not do this when in the main screen, or when inverted.
5 Suggested Answers
nfandres
  • 168 Answers
SOURCE: Reverse Image
find the menu for saving the settings, for sure there is a menu saving all your desired settings. good luck!
Posted on Feb 12, 2007
wellss123
  • 4 Answers
SOURCE: Viewsonic PJ513DB DLP Projector projects upside down
Double check which menu item you are expecting to find the orientation. It might even be under 'image', 'settings', or its own button not in the menu, Jon.
Posted on Feb 24, 2009
SOURCE: Mutilpe projection images/yellow to the lf and blue to rt of main
You can fix this in the service menu
Posted on Mar 31, 2009
projdoc
  • 2237 Answers
SOURCE: my proxima dp6155 projector after any time looks
reset the settings to factory default. there may be a resolution issue. make sure it matches the source. if the line is straight and goes right along the pixel line, you may have an lcd issue. if it's blurred, it could be a bad polarizer.
Posted on Dec 21, 2009
Power button is flashing green, no image displayed
I had the power on and off cycling issue described in another post and when I reassembled the projector I forgot to plug the two wire plug back into the power board. The power light flashed. I removed the top cover and plugged it in and the projector is now working perfectly.
Nov 05, 2010 | InFocus Proxima DP6155 Multimedia...
It appears our remote has never worked correctly. is there a special set up to make it work?
the ir lenses may be blocked with dust. blow out the projector with canned air. if you need to, remove the top case and clean off the sensors yourself. and change the batteries in the remote.
Dec 07, 2009 | InFocus Proxima DP6155 Multimedia...
Shut down
maybe there is a things that cover the exhaust fan some kind of a book or your laptop, or something... then check also the air filter maybe it so very dusty.
Oct 28, 2009 | InFocus Proxima DP6155 Multimedia...
ALIGNMENT Problem - InFocus Proxima DP6155 Multimedia Projector
if the lcd panels have become misaligned, it is time for a new projector, the parts are no longer available for this unit, and it needs the most expensive part, the LCD block
Jul 19, 2008 | InFocus Proxima DP6155 Multimedia...
I have an alignment problem with colors and i've found a little mesh screen
yr previous buld is it burn out or explode ?
if explode might be the tiny glass neeed to service (cleaning)
please do a tilt correction
do manually
Mar 08, 2008 | InFocus Proxima DP6155 Multimedia...
Color Alignment
reset the settings to factory default. then re-solder the fingers on the edge of the power supply board where it goes into the main board edge connector.
Nov 14, 2007 | InFocus Proxima DP6155 Multimedia...
Hot to adjust the convergence on the DP6155
resolder the fingers on the edge of the power supply where it goes into the main board edge connector.
Oct 16, 2007 | InFocus Proxima DP6155 Multimedia...
InFocus Proxima DP6155 Multimedia Projector Logo
67 people viewed this question
Top InFocus Office Equipment & Supplies Experts
jasbo
jasbo
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
