Question about Dell Computers & Internet
Pages loading very slow ....like 3-4 minutes
I had AT&T out here to test my DSL box lines cables usb's and they couldnt figure the problem out on their end. I am stuck with pages that take forever and a day to load since July 15, 2008
    Problem Solver:
  • 14 Answers
**have you already called at&t tech support about this?
**before this issue happened.. do you remember downloading somehing from the web/ (ie. music, video, picture)
**also try to check the memory being used of your computer (especially if you just installed games or customized your operating system)
**optimize your browser..
what you can do is to go to helpme.att.net/dsl/speedtest/
that is there speedtest site.. as soon as yiou got the result call tech support and provide them with the info..
Posted on Jul 18, 2008
I am trying to access the internet wirelessly from a lap top through a D-Link DI-624 I went throught the steps 1. plugged up the router 2. unplugged the DSL box 3. plugged up the ethernet cable to the DSl...
Unplug the power cables from both your DSL modem and D-Link router.
Verify the Ethernet cable is plugged into both your DSL modem and the D-Link router.
Plug the DSL modem power cable back in and wait for the self-test to finish.
Plug the D-Link router power cable back in and wait for the self-test to finish.
Plug your laptop into the D-Link router using an Ethernet cable.
Can you access the D-Link configuration page now?
Check to see if your computer is getting an IP address from the D-Link router.
Here's how to do that, assuming you're using Windows.
Hold down the Windows key on your keyboard then press the letter R.
In the Run dialog box type 'cmd' (without the apostrophes).
Click OK.
In the command prompt window type 'ipconfig /all' (without the apostrophes).
Press Enter.
Look for the line that reads 'Ethernet adapter Local Area Connection'.
Verify that 'Dhcp Enabled' is set to 'Yes".
Mar 14, 2011 | Computers & Internet
I have tested my internet connection with my ISP and the connection is fine but the signal from my wireless router seems to be the problem. This just started out of the blue (no recent changes). Pages load...
Disconnect the router, and use an Ethernet cable to connect your computer's network-port directly to the cable-modem (or DSL-modem), and try the "performance" of Internet activity.
May 07, 2010 | Linksys Wireless-G WRT54G Router
Ethernet light flashing
Check your DSL Filters on your house phones or anything connected to the phone line EXCEPT the modem. The modem should not have a filter on it. If this doesnt help I would recommend getting your ISP out to test the line because sometimes the resisitors or hardware in the box goes bad or at the DSLAM.
Jul 20, 2009 | Efficient Networks SpeedStream 5667 Modem
HP Color LaserJet 2550N. Slow printing takes 16
http://www.hp.com/#Support
Follow the link and get the correct driver and get installed
Jun 30, 2009 | HP LaserJet 2550n Printer
DSL & Acer Aspire 9410
In your browser try going to tool and then click on options then goto advance. click network and then settings. check to see if your computer is trying to connect through a proxy server cause f it is then click on direct connection to the internet. I have the same problem that it changes without me knowing until I try to load a new web page. Not figured out how to solve completely but it's a start.
Hope this helps
Jan 08, 2008 | Acer Aspire 5100 Notebook
"fail: Test ADSL Line Sync" per AT&T Tech Readout
hi,there are a lot of possibilities y ur dsl light wont stop flashing red, 1.could be hardware failure,2.defective lead light for dsl,3.or line issue on the network...i strongly recommend that you contact your isp or att provider so that test would be done by their tech support,...basically you have checkd all inside wirings n as you have said you even tested the nid already...have you tried changing the dsl cable or phone cable? have you tried using another modem? were you using a filter for your dsl? you have to consider also other emi/rfi or electronic interference....but most probably you might try upgrading your modem n see if your gonna get a steady dsl light...the ethernet plugs has no effect on the dsl light...its just the cable connection or line issue or defective modem...i hope this will help, pls feel free to ask if you need further astnce...
Nov 29, 2007 | Siemens SpeedStream Modem (4100) (SS4100)
WRT54gs' internet link wont come up
Here's a couple of places to get started:-
1. If you're on the internal network, try logging into the router's admin page, and iff you can see link to the cable modem / DSL line "Internet Interface". Try Refreshing DHCP on that interface.
If it's not looking great, or it's not serving out DHCP, do a quick powercycle on the LinkSys and see if that clears it (I would guest you've tried this though!)
2. Check your cable modem / DSL line box and ensure that all its lights are as normal (Without Make / Model etc I can't help you in detail there.
3. Try powering off your cable modem / DSL box and then your link sys. Wait 10 minutes (Yes, that long, there are reasons for that involving the upstream network). Powerup you Cable Modem / Link Sys box, once that looks healthy (Maybe 2 minutes to boot with some models) power up your LinkSys and see how things look then.
If you're still not having luck, unplug the power from the LinkSys again. Press and hold the "Reset" button, keep it pressed, and reapply power. Count to 10 before letting go. Wait a second or two, then press and hold the rest button again for another 10 secs. See how it looks then.
4. If all of the above doesn't help, call up your ISP and ask them to run a diagnostic on your Cable Modem / DSL Modem.
5. If you CAN get to the web page on your LinkSys, and you KNOW the cables are good then you should try putting the original firmware back and see how things go then.
If you're still having issues after all of the above I'd suspect you have faulty hardware.
Nov 16, 2007 | Linksys WRT54GS Wireless Broadband Router...
Speed of computer
Try testing the speed, go to this website and see what results you get. It takes a couple of minute so so be a bit patient. http://www.bandwidthplace.com/speedtest/ If it's slow, report it to your DSL supplier.
Jun 14, 2007 | Internet KM-2501P Enhanced PS/2 Multimedia...
My problem is, that my laptop cannot work anymore its internet connection.
Some questions before we get started: -What operating system are you running? -Are you using DSL, cable or dial-up for Internet access? -If you?re using DSL or cable are you plugging your laptop directly into the Internet provider?s box? What is the manufacturer and model of it? -Have you tested your Internet connection to make sure its working? If it?s a phone line can you dial out, if its DSL or cable try connecting another computer to it. -When you plug your Internet cable into your PC does anything appear or change on your screen? Once you give us some more information to work with we can start figuring out what is going on.
Jan 20, 2007 | Dell Inspiron 1000 Notebook
Netscaping
Yes, Netscape 6.2 will work properly with the web page-based interface used in D-Link DSL routers, however, due to problems the browser has loading Java applets and working with Java scripts all of the features may not be visible. Netscape 4.7 does work with the interface, but is extremely slow in loading the various configuration pages. For these reasons, it is recommended to use Microsoft Internet Explorer 5.x or 6.0 to configure D-Link DSL routers. Internet Explorer loads the pages faster and Java applets work properly, as shown below. Note the tree in Fig. 1 (using Internet Explorer), representing the router´s various configuration pages and in Fig. 2, the PPP Connection information. Using Netscape 6.2 as shown in Fig. 3, the configuration tree is missing and in Fig. 4 the PPP Connection Information is not displayed.
Feb 16, 2006 | D-Link DSL 500 (DSL-500) Router
Computers & Internet Logo
128 people viewed this question
Alun Cox
