Question about Frigidaire ATF6000ES Front Load Washer
My dishwasher how come my dishes are not coming clean?
  • sandy47 Jul 17, 2008
    i have already bought a water inlet valve for it.i put it on but it still not making the dishes clean.water temp. is ok. we have already checked that.what else can be causing this problem?
    Scholar:
  • 97 Answers
Hiya
you may be low on salt, or the filter/pipe is full of gunk, could even be a simple case of overloading the dishwasher (personal experience lol )
hope this helps
please dont frget to rate how helpfull this reply was, thanks kj
Posted on Aug 03, 2008
  • 876 Answers
Are the sprayers unimpeded? Have you checked for any debris in the bottom of the washer? Are you using the proper amount of detergent which means enough for 2 washes. . Hope some of this helps.
Posted on Aug 02, 2008
Dishwasher not cleaning dishes
DISHWASHER NOT CLEANING WELL??
Here are 5 common reasons why not.
Here are Improper Water Temperature
I can tell you from personal experience that water temperature has a direct impact on how well your family's dishwasher operates. If the water entering your dishwasher is not hot enough, your dishes are likely to come out coated with grease and dish detergent residue. As such, you will want to make sure that the temperature of the water inside your dishwasher is somewhere between the range of 120 degrees Fahrenheit and 140 degrees Fahrenheit. If it's not it could be a faulty heating element.
Dirty Pump
Based on my experience, a dirty dishwasher pump will also cause your dishwasher to produce less than stellar results. Therefore, you may want to consider cleaning your dishwasher's pump every six months. In many instances, it is an easy task to complete. In order to clean your dishwasher's pump, you'll most likely have to remove the dishwasher's spray arms. Once the spray arms are removed, you'll want to clean and inspect the pump's impellers, blades and pump guard. I should also mention that there are appliance companies that sell dishwasher pump repair kits should you notice that a part needs to be replaced. A basic dishwasher pump repair kit will tend to cost you $20 to $60 depending on your dishwasher's unique needs.
Dirty Spray Arm
Dirty spray arms may also be to blame. After all, if the spray arms' holes are clogged, the hot water won't be able to reach the dishes properly. A dishwasher's spray arms are very simple to clean. In order to clean them, you will need an old toothbrush and a bread twist tie that has been stripped of its paper. Use the toothbrush's bristles and the wire from the bread twist tie to unclog all the holes.
Broken Dish Detergent Dispenser
A broken dish detergent dispenser is another likely culprit when it comes to dish cleanliness problems. Sometimes the dish detergent dispenser's door will not open or shut properly, which prevents the dishes from getting nice and soapy. The good news is that most dish detergent dispenser problems may be solved relatively inexpensively. The cost of a replacement dish detergent dispenser will vary based on the make and model of your dishwasher. There are also instructional videos online that will help you with the installation of your dishwasher's new detergent dispenser.
Dirty Filter
A filter has an impact on a dishwasher's effectiveness as well. Hence, you will want to inspect your dishwasher's filter for obstructions. The location and type of filter will vary based on your dishwasher's make and model. I would recommend that you check out your dishwasher's operator's manual. It should contain instructions on how to clean your particular unit's filter as well as where you can order a replacement part if need be.
Dec 16, 2013 | Dishwashers
Tip
Dishs not coming out clean
It is a known fact that if you rince your dishs off before you place them in the dishwasher your dishs will come out alot cleaner. Stuck on foods can be baked on the dish causing the dish not to come out clean also by doing this it will exstend the life of your product because the passage ways for the sprayer will not get cloged giving a full pressure washing
on Dec 10, 2009 | Dishwashers
The top shelf of dishes in my CDA dishwasher isn't coming out clean any more
Look at you manual. How to remove the top spryer to clean it, re-install and presto. (I hope)
Jan 13, 2013 | Dishwashers
Dishes not coming out clean
Hello
There are some things you can try, however, if your Maytag dishwasher is not getting your dishes as clean as you would like. Maytag recommends several processes for fixing this issue with your dishwasher.
Do not run your Maytag dishwasher while hot water is being used in other parts of your home, such as washing clothes or showering. Hot water is needed for your Maytag dishwasher to properly clean dishes.
Run water in the sink in your kitchen until it gets very hot. Then, turn on your Maytag dishwasher. This will ensure that the water cleaning your dishes is the hottest possible temperature.
Clean your Maytag dishwasher to improve the cleaning results for dishes. Run your dishwasher on a short wash cycle and wait for it to fill up with water. Stop the cycle and add about 1/3 of a cup of rust remover to the dishwasher and finish the cycle. Run your Maytag dishwasher through one normal cycle with regular detergent to finish the cleaning process.
Check your detergent. Old detergent or those that have been exposed to moisture can be clumpy. This detergent will not clean your dishes as well when loaded into your Maytag dishwasher. Purchase fresh detergent.
Use extra detergent when washing dishes that have a lot of built-up grease or food particles. The extra amount of detergent is needed to get your dishes clean. Choose a long cleaning cycle to clean these dishes.
Fill your Maytag dishwasher properly. Dishes should not be stacked on top of each other or excessively crammed into your dishwasher. This will keep the dishwasher from adequately cleaning all areas of your dishes and from rinsing them thoroughly.
Sep 13, 2011 | Maytag Dishwashers
It' no longer cleaning my dishes
hello,
If your dishes are coming out of the dishwasher covered by a removable dirty film, your water may not be hot enough, or you could be using an inferior brand of automatic dishwashing detergent. If you have tested your hot water and find it is between 140 degrees and 160 degrees Fahrenheit, consider how long it takes for the hot water to reach the dirty dishes in the dishwasher. If the hot water has to travel a long distance to reach the dishwasher, chances are the water filling the dishwasher starts out cold. To alleviate this problem, run the hot water nearest to your dishwasher until the water coming out is hot. This will guarantee the water filling the dishwasher is as hot as it should be to properly clean dirty dishes.
To remove this type of film from dirty dishes, after running the dishes through a basic rinse cycle, set a bowl filled with a cup or two of white vinegar on the lowest rack of the dishwasher. Remove any metal pans or utensils, and with the vinegar on the bottom rack, wash the dishes as usual. Dirty dishes that were once covered in film should come out squeaky clean
thanks.
Oct 23, 2010 | Dishwashers
When we open dishwasher theres standing water in the drain area and it smells bad this is after washing aload dishs look clean but inside stinks
After you run a load of dishes put 1cup of CLR or vinegar (white) and run a quick wash.no dishes,after running dishes clean out spray arm and clean strainer,use a rinse agent like finish, and spray off dishes before loading.About 35yrs. ago I use to be a dishwasher as one of my first job's and if you did'nt spray the dishes and scrap them off before loading,the dishes would not come out clean,And after each shift the dish washer would be cleaned out.
Aug 04, 2010 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Dirty dishes and now a flashing light
dishes not coming out clean might be because u need to clean your dishwasher.. but with the electric shock aswell ... i think its done for .. go get a new one.
Jun 21, 2009 | Indesit 24 in. IDL500 Built-In Dishwasher
My dishes do not come clean at all, even the glasses come out with bits of food on them.
it may not be the dishwasher it may be that your water heater is set too low.  Also try a different dishwasher soap.
Mar 23, 2009 | Whirlpool 24 in. GU1500XTLS Stainless...
Top Dishes not coming clean
Clean ot replace circulation pump.
Clean or replce hoses
Jan 05, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Frigidaire ATF6000ES Front Load Washer Logo
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
