Question about Amana ALG331RAW Gas Dryer
Buzzing noise, will not start
Makes a buzzing noise when I try to engage dryer, will not turn on.
  • Anonymous Jul 28, 2008
    i also have the same problem it acts like it will start when you push the start button but just makes small buzzing noise like there is power but it just wont run
  • 22 Answers
Your machine needs a new motor the start switch on the motor has worn out I have tried replacing the sart switch but the result is the same!
Posted on Aug 22, 2008
  • 868 Answers
SOURCE: Dryer will not start when start button is pressed, makes a buzzing noise
Mode land serial number?
Posted on Jun 02, 2008
  • 2694 Answers
SOURCE: Dryer won't start. Just makes a buzzing noise.
see if you can spin the drum by hand,if you can sounds like you have abad motor,or something could be stuck in the blower wheel jamming the motor and the belt broke but the sound is the motor,you need to get in there and look,let me know what you find and if i can help you with anything else
Posted on Apr 16, 2010
  • 1531 Answers
SOURCE: Drum won't turn after pushing Start
first thing to do is open the door hold the switch closed and try to turn it on at the same time turnong the drum by hand,if the drum turns there could be a couple of this wrong.
the first thing is the motor has alot of lint build up around and in it this can be clean with a vaccum,there will be a small access panel on the bottom left side of the dryer in the rear remove the pane and you can see the motor.if the motor is clean and free of lint then you might have a bad start winding in the motor and needs to be replace.if the motor still does not turn then you may need to replace the start switch.good luck with your dryer i hope this helps you out.
Posted on Jan 22, 2010
  • 145 Answers
SOURCE: whirlpool lgr4634eqo makes a buzzing noise when trying to start
Try holding the door switch lever in and turning the drum hard by hand. It sounds like you have a start switch out in the motor.
Posted on May 20, 2008
  • 43501 Answers
SOURCE: dryer does not start
Sounds like your motor has gone bad...
A dryer may not start for many reasons...
This tip that I wrote will help you to figure out what is happening...
Posted on Apr 17, 2010
Testimonial: "Thanks heatman. I appreciate the timely response and links. Will follow your advice to try to isolate the problem."
Dryer starts and runs fine but makes a loud buzzing noise from the motor that sounds a lot like the end of cycle signal
FIXED Dryer won't start. Makes electrical buzzing noise - model ...
Feb 12, 2007 - 10 posts - ‎1 author
It makes electrical buzzing noise when you press the start button. ... One would think that if it's the fuse that it wouldn't buzz at all but ... unplugged, re-assembled back, hooked back up to hose, turned on and running hot .... The belt was fine. ... Kenmore gas dryer 70 series is making very loud buzzing noise.
Troubleshooting Your Dryer Noises ' ...
? 4:32
Aug 26, 2011 - Uploaded by PartSelect
In this video you'll learn why your dryer may be making a variety of ... that is not only making a grinding noise but it also makes a loud banging noise. ... it's been drying about 15-20 min. it startsa loud humming sound. ... The dryer is working just fine, but I am concerned about the noise as it sounds electrical.
Dec 18, 2015 | Amana DLE330RAW Electric Dryer
My dryer motor comes on (you can hear a humming noise) but the drum does not turn.
GE dryer won't start. Makes buzzing noise... - YouTube
? 0:39
May 8, 2010 - Uploaded by maxicheong Anyone seen this before? When i tried to turn on the dryer, i get ahumming / buzzing sound and the drum ...
Oct 08, 2015 | GE WE12M22 Dryer
Drum doesnt turn dryer makes buzzing noise
Just fixed one with same problem for customer. Sorry to say but most likely faulty motor. One test you might perform, and this isn't full proof but, is to bypass door switch and attempt to turn drum by hand whilst engaging starter switch. If dryer starts it is most probably motor. Also If this usually occur after heavy usage, or has in the past, it's almost surely faulty motor.
Aug 20, 2013 | Dryers
Why does my GE 7 Cycle Dryer makes noise when I turn the start button, but does not run the dryer
The start button just engages it to run. See if the wires are still on it. Turn off your breaker, then back on. If still not working, then replace starter switch.
Mar 12, 2013 | Dryers
I turn the start knob and it just makes a buzzing sound
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
Jun 06, 2010 | GE DBSR453EBWW Electric Dryer
Dryer will not start up.
you have a bad motor or something is stuck in the blower housing connected to motor
Sep 15, 2009 | Dryers
Start switch makes a buzzing sound when pressed; but won't stay engaged and doesn't turn the dryer on.
I just had someone in today to look at my dryer that when I turned "on" switch made a funny noise and the dryer would not turn. Found rear bearing dry and sticking, applied bottle of Hitemp lube, and it works just fine now on test (I think, not run a load yet). He initially thought perhaps the motor, but thank goodness was honest and tried the most reasonable solution.
Apr 21, 2009 | Dryers
Dryer makes a loud buzzing noise then quits working.
Sounds like the motor's done. That thing is probably the start-run switch. Not worth trying to fix on an old motor. I've found dryer motors to be fairly generic, you should be able to find a replacement. I use when I can't get parts locally.
Nov 26, 2008 | Magic Chef CYE4000AWW Electric Dryer
Whirlpool lgr4634eqo makes a buzzing noise when trying to start
May 20, 2008 | Whirlpool LGV4634JQ Gas Dryer
Amana ALG331RAW Gas Dryer Logo
517 people viewed this question
Top Amana Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you an Amana Dryer Expert? Answer questions, earn points and help others
