Question about Emerson DTE315 TV
Emerson DTE315 One of my lovely kids set the parental password on this and now the TV is locked and we can't figure out what the password is. I called Emerson and was told to unplug the TV for 30 minutes. It has been unplugged for a week and that hasn't reset it. I repair computers for a living but once I opened the TV I couldn't find any way to reset it. Any ideas?
    Problem Solver:
  • 11 Answers
I would say somewhere it has to have a back up battery. That is the only I would think or a memory chip of some sort. All TV's should have a reset that gets them back to default settings. If you no longer have the manual you can go on-line and usually find, I have at least.
Posted on Sep 15, 2009
How do i unlock a old haier tv parental controls with out a remote
Once the lock is engaged with a password you can't override it, if you could the kids would have figured it out long ago.
Oct 18, 2016 | Haier Televison & Video
I need to know how to unlock the parental lock on my daughter's Spongebob television model number sb305
Either in the owner manual (if lost Google the model number with "manual" to try to locate one) are the instructions for this.
A harder way is call Emerson and have them step you thru the process.
Apr 10, 2012 | Emerson SpongeBob SquarePants TV
PARENTAL LOCK?
are you the parent or the kid if your the kid none of use are going to bea ble to help thats between you and your parents if you are the parent then...ther really is no way to get rid of it with out the password
Jan 08, 2009 | RCA F27625 27" TV
Channel block
#1 power off #2 hold the menu butin down and tren power on for 40 sen. #3 tren power off #4 do it 2times #5 tren power no all ok
it worked for me good luck
Aug 18, 2008 | Emerson DTE315 TV
Resetting parental controls
there seems that only 4 digits are the max but I could be mistaken, as far as reseting the password there is nothing listed on the Vizio website in the manuals ect for reseting the parental controls, probably due to security for the owner.
But there is a solution
if you call 877 MY V I Z I O
with you model number of your unit and make them aware of the parental lock issue there might be a way for them to explain the resting everything back to factory settings.
Aug 11, 2008 | Televison & Video
Parental lock
Child Lock
Combos
--Should have original remote. Press and hold the power button for 6 to 10 seconds
Combo Model T25208, V-Chip Forgotten Password
If you forget your password, simultaneously press VOLUME down on the TV/VCR front panel and the 0 number button on the remote for a few seconds. This resets the password and you can enter a new one.
Combo Model 13TVR62, V-Chip Forgotten Password
If you forget your password, press STOP/EJECT on the TV/VCR front panel and MENU on the remote simultaneously. This resets the password, but not the limits you’ve set.
Televisions with Parental Lock Feature
If you forgot your password for this feature, press the following buttons on the remote, one at a time. (Note: You must be in the password entry screen) Press, Mute, Display,Clear and Reset, this unlocks parental controls and you can now re-enter a new password.
OR TRY THIS..
Press and hold Menu on the TV AND volume down on the remote for 3 seconds. Nothing will appear on the screen, and the Parental Controls will unlock, and you can re-enter a new password with the LOCK PARENTAL CONTROLS
CTC169AU
Channels that have been locked can be viewed only when the PARENTAL CTRL function is set to OFF. This can only be done with the remote control-it can not be changed with the buttons on the front of the TV.
Therefore, after you turn on PARENTAL CTRL, you simply hide the remote control so that your children can not watch the locked channels. The locked-out channels will remain unviewable even if the TV is unplugged or the channels are autoprogrammed again. The only way to view locked channels is to use the supplied remote control to set the PARENTAL CTRL function to OFF.
The PARENTAL CTRL and the CHAN CTRL functions work hand-in-hand. The instructions below will first tell you how to turn parental control on or off with the PARENTAL CTRL function and then how to lock desired channels with the CHAN CTRL function.
1. Repeatedly press MENU to select SETUP MENU, and then press + or - to display setup functions. Repeatedly press MENU to select the PARENTAL CTRL function. . When this function is set to ON, PARENTAL CTRL is activated and any channels you locked with the CHAN CTRL function will not be viewable. . When this function is set to OFF, PARENTAL CTRL is deactivated and all channels are viewable.
2. To lock channels, press the MENU button to select the CHAN CTRL function. Select a channel you want to lock by pressing CHANNEL up or down. Then press +. The CHAN CTRL setting will change from NORMAL to LOCKED when that channel is locked. To return the channel to NORMAL, press the - button. Repeat step 2 for each channel you want to lock. If the PARENTAL CTRL function is set to ON while you are locking out channels, each channel will go blank as you lock it. When the PARENTAL CTRL function is set to ON and a channel which has been locked out is tuned, the TV will display the words PARENTAL CONTROL to let your kids know you have locked it.
CTC185's
If the front panel function buttons don't work, (menu, ch up/dn etc.) but the functions work normal with the remote, enter the "Channel" menu with the remote and turn "Parental Control" off.
CTC203's
In the event you have forgotten your password, perform the following procedure:
Press and hold for 3 seconds the TV button on the remote while pressing the menu button on the TV.
This procedure will turn off the parental lock and erase the previous password .
Another Possibility To Try For Various Models: If TV's in the Parental mode and askes for a password that's forgotten, Press menu on the TV, select Parental Lock #4 on menu, then with the remote press Mute, Display, Clear, and Reset buttons in sequence.
TX808 Chassis
If Parental Controls have been set and you don't know the password, do this:
Press and hold the volume down and the channel up buttons at the same time for 5 seconds.
Now you can reset the password to 0000, and using that password you can now access the V-Chip menus.
TV's (Made by Daewoo or possibly Apex, ie. GE model 24GP653)
The factory default pass code of 6688 is also the override code, in case the owner forgets their pass code. If that doesn't work, another place in the owners manual says to push Function and Mute on the remote at the same time. Function is the top right button.
Mar 26, 2008 | RCA TruFlat 27F520T 27" TV
DTE314
TECHNICAL SERVICE DATE
Mar 05, 2008 | Emerson DTE315 TV
Parental password unknown
Cindy, the code is 8888. My kid found it by trial and error. Good luck. Jose
Jan 03, 2008 | Emerson SpongeBob SquarePants TV
Emerson DTE315 TV Logo
319 people viewed this question
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
