Question about Minolta DiALTA Di520 Laser Printer
Minolta di520 error code c 0072
Es el pote fraSCO DEL TONER
AT THE TONER WHERE IS
Posted on Sep 30, 2008
Minolta DiALTA Di520 Laser Printer code 13f1
Replace the print head the device that houses the machine LASER, or the J or A printed circuit boards. Go with the LASER first if you can find one the Di520/620 are legacy machines from Minolta now Konica Minolta. Reset is Power off the Power on.
Jan 22, 2013 | Minolta DiALTA Di520 Laser Printer
My copier minolta 520 was not working error code c13f1
sir/mam Replace the print head the device that houses the machine LASER, or the "J" or "A" printed circuit boards. Go with the LASER first if you can find one the Di520/620 are legacy machines from Minolta now Konica Minolta. Reset is Power off the Power on.
Nov 18, 2012 | Minolta DiALTA Di520 Laser Printer
Fault code C-of24 ? Minolta Di520 Laser Printer
Remove the drum cartridge then the drum and clean the sensor that monitors the drum. If not then replace the drum and or the sensor and board.
Sep 04, 2012 | Minolta DiALTA Di520 Laser Printer
Minolta di520 error code C0990
Large capacity draw bottom draw lift problem. gear might be bad or the cable snapped.
Aug 13, 2012 | Minolta DiALTA Di520 Laser Printer
I have a Minolta Dialta Di520 that shows an error code of c-0110. The machine was working fine before being moved. It may have been bumped along the way. Also, the FN3 finishing unit is not connected at...
Image Transfer/Paper Separator Wire Cleaning Motor M8's failure
to turn ยท Faulty Transfer/Separator Wire Cleaning Home Position Sensor PC17
would be in the middle section, under the drum assy that has to very fine wires a device that looks like it would clean them, will the cleaning device is jammed or the motor that run it is jammed burned out, or the control board is bad.
Aug 01, 2010 | Minolta DiALTA Di520 Laser Printer
Minolta di 520 MALFUNCTION
after nessage not apear error code,anymore specification?
Jul 17, 2009 | Minolta DiALTA Di520 Laser Printer
Minolta di520
COF 34 is a code to refer T/C recovery failure as detected by ATDC sensor.Change ATDC sensor,if problem persist,change developer(starter) and then run F8 and F5 function operation in that order.Developer change every 1000000 copies.
Nov 08, 2008 | Minolta DiALTA Di520 Laser Printer
Minolta dialta di520
problem code c1039  for d-i 620
May 10, 2008 | Minolta DiALTA Di520 Laser Printer
156 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
David Burkhart
David Burkhart
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
