ReadyBoost Error I just got a new laptop with Windows Vista. I input a flash drive into the USB port and it asked me if I wanted to open the folder or speed up my system. I accidentally clicked on the speed up my system button and started ReadyBoost. I took out the flash drive and input it again into the laptop, and there is a tmp file on it that whenever I try to delete it, I get the error message that the disk is write-protected. When I right click on the drive, then click on properties, there is no "readyboost" tab to allow me to disable it. There is also no switch on the flash drive to turn write protection on/off. Is there someway to get rid of this file and remove the write protection so that I can add new stuff to this flash drive??
    Novelist:
    Scholar:
  • 160 Answers
In the future, always use the Safe Removal method before removing a USB drive. This prevents this kind of error in the first place.
If you haven't done so already, reboot, then insert the USB. Make sure there are no windows open which reference the USB device. Then use Safe Removal (right click in the lower right hand corner of the task bar. That should clear it.
If that doesn't work, right click the USB drive in My Computer, choose Properties. See if you can clear the Read Only setting.
Last resort - copy off the files you need from the USB, and format it.
Posted on Jul 18, 2008
Pen drive is slow
Slow Transfer on a USB Flash Drive b> Using a USB flash drive is a convenient way of transferring data and files from one device to another. However, sometimes you may find that your USB drive is slow to transfer files onto your laptop or PC. This lag may also cause your desktop or laptop to slow down while you use other programs. You do not need to replace your flash drive and buy a new one. You can fix a slow file transfer problem in just a few steps.
b>Plug your USB flash drive into your computer. Click the "Start" button and select "My Computer." Right-click the USB icon from the My Computer window and click "Properties" from the menu that comes up. Go to the "Hardware" tab and select your flash drive once you find it in the list of items. Then click the "Properties" option in this menu. Choose "Policies" tab within the Properties menu. Turn on the performance optimization option and click "OK." Click "OK" again to exit out of the Properties dialog box. Go back to the My Computer window and right-click on the USB icon. Select the "Format" option from the list of choices. Select the "NTFS" file system and choose "Quick Format." Press "OK" to confirm the choices and to initiate the formatting. Wait for the drive to finish formatting before ejecting it and removing it from the computer.
USB Flash That Is Slow and Damaged
b> USB flash drives are used to transport data between computer systems. Because it is essentially just a small hard drive, the USB device can become damaged and slow down in performance due to viruses or damaged files. To correct these problems and fix the USB flash drive, you must reformat the drive. This removes all data from the drive, returning it to its factory settings.
Plug the USB flash drive into a USB port on the computer system. Close any AutoPlay window that may load onto the screen. Click "Start" then "(My) Computer." Right-click the removable device icon that appears on the screen. Select "Format" from the pull-down menu. This loads a format options screen. Click "Yes" and the computer formats the USB flash drive, removing the damaged content and returning it to the factory settings.
ReadyBoost With a Slow Flash Drive
b>The ReadyBoost feature in Windows has the ability to increase the speed of low-RAM computers by caching program data on a flash memory device. However, the device must meet minimum performance characteristics in order for Windows to enable ReadyBoost, because ReadyBoost may not meet expectations when used on a slower device. If you still want to use ReadyBoost with your flash drive or memory card, you can make a change in the system registry to force Windows to use the device.
Insert the flash device that you would like to use for ReadyBoost. Open the Start menu, and click "Computer" to see the icon for the device. Right-click the icon for the flash device, and then click "Properties." Click the "ReadyBoost" tab at the top of the window. Clear the check from the "Stop retesting this device when I plug it in" box, and then click "OK." Remove the flash device. Open the Start menu again. Type "regedit" in the "Search programs and files" box at the bottom, and then press "Enter" to run the Registry Editor. Double-click the folders "HKEY_LOCAL_MACHINE," "SOFTWARE," "Microsoft," "Windows NT," "CurrentVersion." and "EMDMgmt." Locate and click the folder for your flash memory device under "EMDMgmt." In most cases, you can determine the correct folder because it contains the name of the device's manufacturer. Double-click the registry entry "DeviceStatus" on the right side of the window. Change the number under "Value Data" to "2" and click "OK." Double-click "ReadSpeedKBs" on the right side of the window. Change the value to "10000000" and click "OK." Repeat this process with the "WriteSpeedKBs" registry entry and close the Registry Editor. Reinsert the flash memory device, and return to the "Computer" window. Right-click the icon for the flash memory device, and then click "Properties." Click the "ReadyBoost" tab. Windows now displays an option to enable ReadyBoost on the device. You might install a usb 3 card the speeds are much faster cheap and easy to install. Hope this helps.
Jan 08, 2013 | Electronics - Others
Tip
Use ReadyBoost to Speed up Programs in Windows 7 To enable ReadyBoost: 1. Put...
1. Put your USB thumb drive into a USB port on your computer.
2. When the AutoPlay menu appears, click Speed up my System with Windows ReadyBoost.
3. Select your device and specify how much of the drive you want to use for ReadyBoost. I recommend using a full USB drive. (TIP: match the size of your drive to the amount of RAM you have in your computer. i.e., With 4GB RAM, use a 4GB thumb drive
4. Click OK. Don’t expect miracles—but stick with it and your computer will begin to perform more efficiently.
on Dec 10, 2009 | Computers & Internet
I got my PNY Attache 4g memory stick for backups and now its full. can I delete or what do i delete to make room? for newer ones? it has ready boost with 3,745,792 kb being used taking up most of the space...
If you want to use that flash drive for backing things up then I would suggest not using it for ReadyBoost. If you disable ReadyBoost on that flash drive you should have plenty of space on your flash drive for backups. Disabling it should not hurt your computer's performance at all. Here is how to disable ReadyBoost: http://windows.microsoft.com/en-US/windows-vista/Turn-ReadyBoost-on-or-off-for-a-storage-device.
May 12, 2011 | PNY 4GB USB 2.0 Flash Drive - Grey/Black
I recently bought a Toshiba Satalite laptop to replace the one I dropped which was also a Toshiba Satalite. I had taken out the old hard drive and installed it in the new one but now it wont do anything...
Yes it does matter. XP was configured for the old Toshiba and this will only work if both Toshiba laptops are exactly the same model.
To get your new Toshiba operating, put the new hard drive with the Vista operating system back in the Toshiba laptop.
To transfer your data from the old hard drive, purchase a USB adapter hard drive case and place the old hard drive inside this case. This will then be an external USB hard drive.
Plug this USB hard drive into the new Toshiba's USB port and it will detect it as an external storage/hard drive. You can then open the various folders and files and copy the data files to your new Toshiba.
To free up disk space on this USB hard drive, delete the Windows folder, Program Files folder and other folders that are no longer needed.
Use this hard drive as a backup hard drive etc.
Sep 11, 2010 | Toshiba Computers & Internet
Usb drive use
Most thumb drives are used like floppy or rewritable optical discs (excluding ReadyBoost and the bootable versions). They are most often formatted as FAT drives (under Windows). If the drive is good and the USB port is good, plugging the drive into the computer's port should trigger a "new hardware found" message from Windows.
In Windows, open My Computer or Computer (depending on the OS) and you will see it listed under Drives with Removable Storage. You can use the file explorer to navigate through your regular drive and copy files to the thumb drive or the reverse. (I usually open two different windows and drag the files with a right-click then select Copy.) Synch programs can let you keep the thumb drive and hard disc copy at the same version. Alternatively, you can save a file directly from the program that you are usng to edit the material. (File > Save As and chose the destination). You can also open the file from the thumb drive in a similar mode. To avoid lost data, always select the Safely Remove Hardware from the taskbar (or Eject from the File Explorer) before unplugging the drive from the port.
The biggest problem is that the FAT formatting limits the number of files you can put on the disc unless you keep them in folders. (The same number of folders can be in the home directory as files without using folders.)
Bootable thumb drives (as well as those that can run software directly from the USB drive) come with software that lets them do this. Then they act like any optical disc with Autorun and executable programs. Readyboost is dealt with completely by the OS and keeps the drive (or portion of the drive) separate from the area that will store files.
Sometimes these drives do fail. Getting the data off the flash memory takes a professional most of the time.
I hope this helps.
(You can copy all of the files from the thumb drive and reformat it at intervals. Then copy files back if you are concerned about file fragmentation.)
Jul 24, 2010 | Verbatim VER95327 USB Hard Drive
Error message states that there is not enough room
One possibility: you have too many files in the directory. USB flash drives are usually formatted in FAT32 and thus stuck with the limits of the standard. Try moving some of your files into folders.
Second check for a encrypted partition locking part of the disc. If ReadyBoost capable a section of the memory set aside to do ReadyBoost for Windows Vista or Win7 (you'll need to release the ReadyBoost on the computer that dedicated the space).
I hope this helps.
May 13, 2010 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
How do you use a flash drive on the computar
Hello
Install the USB Flash Drive:
Plug the USB flash drive into a free USB port on your laptop (it is an approximately 1/2" slot, either on the side or back of the laptop).
Windows XP operating system should recognize it. It may ask you what you want to do with it. Select "Open folder to view files using Windows Explorer" and click OK.
Operating system should assign it a drive letter (see the title of the Windows Explorer window that opens).
Use the USB Flash Drive:
In Windows Explorer, click Folders button on the menu bar to show the installed drives on the left pane of the screen.
To copy a file from c:\ (hard drive) to flash drive:
Find the file you wish to copy on the c:\ drive.
Right-click it and select Copy.
Right-click the location on the new drive where you wish to paste the file, and select Paste.
(File should now appear in desired location.)
Hope you find this useful, if you have any more questions, just leave a comment and i will get back to you as soon as possible.
Kind regards
Andrea
Nov 17, 2009 | SanDisk 1GB Cruzer Titanium USB Flash...
How do i transfer photos from my hp photosmart m537 camera to sandisk cruzer micro usb 2.0 flash drive 2gb.
Connect the HP camera to your windows pc using the usb cable provided. Open My Computer to ensure that the camera is being properly enumerated (given a hard disk letter). make note of the drive letter assigned.
If you have more than one USB port, insert your cruzer micro 2.0 stick into another USB port. Look in my computer again to determine what drive letter was assigned to the flash stick. Open a windows explorer window for each of the locations. One for the camera, the other for the flash stick. Its likely that the picture files are in a subfolder of a folder called DCIM.
Once you locate the files you want to transfer, you can highlight them using the mouse (click/drag a box around the files you want) and drag them to the other open window (flash stick folder)
If you don't have another available USB slot on the compter, you'll need to copy the files from the camera to a temporary location on your computer and then move them to the flash drive. In this case, make a new folder on the desktop and name it temporaryfiles. open that folder. open the drive letter assigned to the camera and copy whatever files you want from the camera to 'temporaryfiles'...
Then power off the camera and remove the usb cord from the computer. attach the flash disk to the newly free'd up usb port and open a windows explorer window to it. drag whatever files you want from 'temporaryfiles' folder into the folder for the flash stick.
I hope this helps!
-Ray
Mar 02, 2009 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Flash drive no longer can support readyboost
Hi
I need a bit more info to properly respond to your query regarding Microsoft ReadyBoast feature in Windows Vista and 2008 Server.
1. Has this particular Flash disk ever work?
2. How much free space is on the flash disk?
3. Is the Flash disk connect to an onboad port or a cabled port?
4. If this is a new device, does it support USB 2.0? What is the transfer spec from the manufacture?
Regards
Mike
Mar 22, 2008 | Computers & Internet
Computers & Internet Logo
549 people viewed this question
David Payne
David Payne
