Question about Philips PM-DVR8 Remote Control
Can't get volume on TV since installing converter box
Put a converter box on TV and now the volume is really low and can't get it to go up Helen Thiel, bucksgirl@udata.com
  • TMLP Jul 22, 2008
    I have the same problem as bucksgirl's. I installed the Magnavox converter box, and now I have to turn the volume to the highest level to even hear the TV.
    I have also lost a lot of channels, since installing. The channels that I can get usually lose its signal.
I just called the toll free customer service and they were able to fix this problem for me.
Briefly: You can go to Set-up, and then go to Initiate, then change the selection to RF Out. My sound is back to normal.
Posted on Jan 11, 2009
How to install digital TV via Free View Box
Put ur tv in channel 3,take the cable came with the converter box put it in tv antna hole in the tv ,the other to the converter box said tv.Take antena,portable or roof antena put it in the converter box said antena hole. Go to menu resacan channels u done.
Nov 15, 2009 | Televison & Video
Trouble with volume on certain channnels
If you get good audio on most and then low or very low audio on certain channels then call you cable company and have them inspect this problem. It is their business to get both good video and audio to you.
Sep 10, 2009 | Insignia Digital-to-Analog Converter for...
I bought the magnavox and all my channels are
Check the converter box. Many have a volume setting that is usually set very low at the factory. On the remote control for the converter check to see if there are volume buttons. If so, change the converter box volume higher, to a level that makes the TV audio level "normal", then use the volume control on the TV for adjustment as you watch. If you set the volume on the converter box too high, you may get some distortion in the audio from your TV. So adjust the converter box to find the proper output from your TV without distortion.
Jun 20, 2009 | Insignia Digital-to-Analog Converter for...
WHY DOES THE VOLUME GO DOWN WHEN I USE CONVERTER BOX?
You will need to adjust the volume on the tv when using the box. The digital sound is different then the sound coming across on analog signal thus do not expect them to be at the same level. The box is not so dreaded, the picture quality is much better then what you get with analog.
Jun 10, 2009 | Insignia Digital-to-Analog Converter for...
Dtv converter box - low sound
I work for Phillips/Magnavox tech support. If the volume is low like that unfortunately, there isn't anything you can do about it. Coby makes a converter box as well as Memorex, and their boxes had the same problems. The box should be returned to the store for an exchange, or sent in for warranty repair/exchange. There is nothing you can do to fix that problem.
I hope this information allows you to make an informed decision as to how to proceed.
Thank you for visiting FixYa.
May 30, 2009 | Philips Magnavox M61117 (DBM61117)
Sound problems with recording to vcr using converter box
If your TV has no scart connection, no HDMI connection, then to be honest I would get a new set. There are plenty of good second hand models around, which will be better than your old set and come with a digital tuner built in.
As for the VCR, that should have a scart socket and so should the converter box. Once connected via the scart socket you should be be able to record the shows easily. If the converter box comes with a volume control, you might need to set that up to get it right. If the VCR has two scart sockets use the second one to connect the box. Use the first to connect to the TV for viewing your recordings only.
If it has only one scart, then look around on Amazon for one of these scart switching boxers.
Mar 19, 2017 | Insignia Digital-to-Analog Converter for...
Tv + converter box = no sound
Try these steps: Turn the volume on your converter box all the way down. Turn the volume on your TV up to ½ way. Now turn up the volume on your converter box until it is at a comfortable level. More information at http://www.ezdigitaltv.com/index.html
Mar 31, 2009 | Sansui CDVD1310 13" TV/DVD
I recently hooked up my dtv box, tuned the antenna and have a great picture. On every channel I have background noise. Sounds like bacon frying, hissing noise. I also set up someone else's tv, very simple....
If there is a volume control on the remote that came with the converter box, use it to make sure the box volume is set to its maximum. Many models allow you to control the volume out from the box to the TV, and the levels are set about halfway. When you turn up the volume on the TV cause it's too low, you can get the kind of audio problem you describe. Make sure you turn the volume down on the TV first before starting with the box.
Feb 18, 2009 | Directv (R10) DTV Receiver / 70-Hours...
TV audio too low with converter box
leave the volume up on the tv to 50% - 80%, then adjust it from the volume on the box's remote control
Jan 09, 2009 | Televison & Video
Low Sound
Find out if there is a volume control for the converter box and adjust accordingly.
Nov 08, 2008 | Insignia Digital-to-Analog Converter for...
Philips PM-DVR8 Remote Control Logo
107 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
