Question about Blendtec SpaceSaver Work Top Blender
Blendtec Model ICB-5
I have a problem with my blender which still has power but it works very slowly and you are able to see sparks from beneath it. Can it be a wiring issue? Shorting? Please help! Thanks!
5 Suggested Answers
  • 87 Answers
SOURCE: ICB-3 Blendtec unit is getting power but will not
check thermal fuse internally , one time blown fuse. need a test meter to check this component , can be bought @ Radio Shack apx $ 8.00us
Posted on Mar 14, 2010
  • 8 Answers
SOURCE: blendtec blender jug split
I wouldn't fix the jar, just buy a new one. A crack, though rare, could possibly harbor bacteria. You could try using heat and melting it, but it wouldn't work as well. Your jar may still be under warranty, call Blendtec at 801-222-0888
Posted on Jul 28, 2010
  • 8 Answers
SOURCE: BLENDTEC BLENDER WONT WORK WATCH DOG TIME OUT?
That is a motor issue, you need to contact Blendtec customer service. They will let you know if it is still under warranty. 1-800253-6383.
SOURCE: my blendtec blender is displaying
Mine too. There is a device on the circuit board called a 'rectifier' - this has most likely failed. If under warranty it should be replaced. Mine was not, so I removed the circuit board and wired in a speed control unit and Vita-mix switches. A bit complicated for my level of techno-wizardry, but in the end much nicer than the touch-button panel. Good luck.
Cxo.
Posted on Dec 18, 2010
SOURCE: after using there seems to be black liquid under
Early stages of bearing failure. Requires eventual replacement of carafe.
Get a manual for blendtec ES3
i have blendtec blender model ES3 they have problem always showing overload?
Apr 06, 2012 | Blendtec Extra Carafe / Jar for the Total...
I have an ICB 3. The LED display lights up and when you touch the buttons it beeps but, it will not spin.
I called blendtec and got it figured out. The unit was in some locked mode and so I had to push the buttons 4-1-3 in that order to get it to work. The confusing thing is there's two invisible buttons between 1,2 and low, high. So the buttons go 1, 2, 3(invisible), 4(invisible), 5 (low), 6 (high). It mentions these options in the manual on page 18.
Jun 25, 2011 | Blendtec ABC Work Top Blender
Does anyone know how to reset a Blendtec ICB-3 to factory settings?
ust removing all power from the machine for 15 secs or more should reset it.You can contact Blendtec here, Not a solution I know sorry. The manual is here http://www.blendtec.com/Resources/A3-31E-BHMV/Connoisseur%20Manual.pdf
you can contact them here
http://www.blendtec.com/contactus.aspx
Jan 03, 2011 | Blenders
Blendtec replacement jar
You can also go to http://veggiesensations.com to buy blendtec total blender parts. Hope this helps!
Jun 30, 2010 | Blendtec Extra Carafe / Jar for the Total...
How to change the blade
You can't. The Jars have perfectly balanced blades that cannot be changed. A replacement jar from Blendtec is cheaper than a replacement blade assembly from other manufacturers. 1-800-253-6383 is the customer service number.
Jun 04, 2010 | Blendtec Smoother Work Top Blender
ICB-3 Blendtec unit is getting power but will not turn on
Mar 13, 2010 | Blendtec ABC Work Top Blender
There is a leak in the caraffe(or jar). It is at
Common issue with all of these carafe's. Once the jar starts to leak the bearings are shot and it is time to replace the jar. The bearings are non-replacable. Bad design in my opinion. I was able to get my last jar (I have been through 3 before the 5 year warranty went out) to last by hand washing and not putting it in the dishwasher, but after 4 years of use on this jar it failed too.
Nov 29, 2009 | Blendtec Extra Carafe / Jar for the Total...
Oct 31, 2009 | Blendtec HP-611-FLP / HP-621-FLP Work Top...
Need insrtution booklet
#txtBoxGotoPage { MARGIN: 0px 6px; WIDTH: 36px; DISPLAY: inline; FLOAT: right } #btnGotoPage { WIDTH: 43px; DISPLAY: inline; FLOAT: right } function GotoPage(objButton) { var sUpdateUrl = ""; var input = objButton.parentNode.childNodes[1]; var sGotoPage = input.value; var sUrl = window.location.href; var sIndexEnd = sUrl.toString().indexOf("page-"); if (sIndexEnd Showing Page 1 out of 15 [1] 2 3 4 5 6 7 8 9 Next Hello there: You can go to the web site of the manufactures web site and download the users manual there. also you can do a yahoo search for your make and model and just put users manual at the end of it like this blendtec smoother work top blender users manual ok? best regards mike
Aug 18, 2009 | Blendtec Smoother Work Top Blender
Blendtec blender jug split
Feb 24, 2009 | Blendtec Extra Carafe / Jar for the Total...
Blendtec SpaceSaver Work Top Blender Logo
657 people viewed this question
Top Blendtec Blenders Experts
eyecam
Mike Cairns
Mike Cairns
jeff tilburn
jeff tilburn
Are you a Blendtec Blender Expert? Answer questions, earn points and help others
