Question about Samsung LE32R74BDX 32 in. HD-Ready LCD Television
Question? you Said : disconnect the AC power cord from the back of the tv for at least 3 minutes. Then re-connect the AC power cord and turn on the TV. I did this, but my question is does this reset the power supply? cuz i done this before and works fine for 20 minutes or so and turns on and off again. is there a bad connection on the power supply PCB? or just over heating?
    Master:
  • 497 Answers
It has to be the power supply board..contact ur service centre and tell them ur problem...if its under warranty,GREAT! but eitherwise u will have to ask them to replace the board.
Thanks for using Fixya
and plz do update me
Posted on Jul 19, 2008
Samsung 26" LCD TV
You can also try a hard reset: Unplug TV from AC mains and remove all cables from TV. Wait about 30 minutes and replug to AC power and redo the cabling. Switch on the TV and see if it works..
Jul 17, 2008 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
Power Light stays Yellow
sounds like you have a power issue, or maybe the power switch is faulty. check that.
Jul 17, 2008 | Vizio L32 32 in. LCD HDTV
Polaroid tv doesn't turn on
I have the same problem with a 37" Polaroid LCD... through some thorough research i discovered that it is a possible 3 things;
1: Blown Capacitors on the power board; Look for domed heads on capicitors
2: A Faulty AV board; I'm unaware on how to test this at present!
3: Faulty T-Con Board; Disconnect the AC power cord from the TV.
Disconnect one end of the LVDS cable that goes between the main board,
and the timing controller (TCON) board.
Connect the AC power cord to the TV and press the power button.
If the screen lights up dimly, then you have a defective TCON board.
If the symptoms didn't change, then you have either a defective main board or
power board (you should get them both, replace them one-at-a-time,
and send back the one you don't need). There are tuition video's for t-con and capacitors replacement on youtube
Feb 26, 2013 | Polaroid TDA-03211C 32 in. LCD HDTV
My 32inch lcd tv keeps flickering it started all the sudden
TRY THIS
    • 1 Turn the TV off with the front-mounted power button, not the remote. Unplug the TV's power cord from the wall outlet. Let an hour pass before plugging the cord back into the wall outlet. Turn the TV back on with the front-mounted power button and wait until it has fully restarted. Bring up a TV channel to see if the image being presented on the LCD screen is no longer flickering. A momentary power surge can cause the circuitry inside the LG-brand LCD TV to function erratically.
    • 2 Unplug the video cable from the video connection on the back or side panel of the LG TV. If more than one video cable is connected to the TV, disconnect all of them. Disconnect the other end of the video cable from the video source device that it's attached to -- a DVD or Blu-ray player, or a satellite receiver or cable box. Blow off the connections on the video source device and on the back or side panel of the TV with bursts of compressed air. Reinsert one end of the video cable into the video source device and the other end into the video input that it was connected to. Turn the TV back on with is remote to see if the picture is now free of flickering. A loose or partially connected video cable can cause the LCD TV's screen to flicker when presenting an image.
    • 3 Turn the TV off and unplug its power cord from the wall outlet. Place a power conditioner next to the wall outlet. Plug the power conditioner's power cord into the wall outlet. Plug the TV's power cord into one of the AC sockets on the power conditioner. Turn the power conditioner on. Turn the TV on to see if the picture is now free of flickering. The RF signals in the electric line that the LG TV is drawing power from can cause flicking through interference patterns being generated.
Oct 20, 2012 | Computers & Internet
My tv won't turn on anymore. The power light and the opc light blink twice at the same time and then the opc blinks once and it keeps doing that. Please help!
Hi
Make sure the AC cord is not loose or disconnected. Check to ensure the cord is firmly plugged into the outlet at one end, and firmly connected to your television at the other end. The AC cord connects to the television about midway across the back of the set, near the bottom of the back panel. The hole for the AC connection is shaped like a figure eight. Try powering up the TV with the cords firmly connected.
Check the "Main Power" to ensure it is on. Locate the button on the top of the television among the "Volume" and "Channel" buttons. Press the button to switch the television on. If the "Main Power" button is off the remote will not turn on the television. Wait to see if pressing "Main Power" will activate the TV.
Press "TV Power" on the remote control to power up the TV from stand-by mode. If the power light on the front of the television glows red when you press "TV Power" on the remote, press the "Main Power" button on top of the television to remove the TV from stand-by. If the TV is accidentally in stand-by mode it may not come on when pressing certain buttons.
Check the circuit board. If your set still won't turn on and you hear a clicking noise when you plug it in, you most likely have a defective circuit board.
Oct 23, 2010 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
The t.v powers on for just a second and clicks off. I can hear a click from the back and it recycles off/on over and over.
open the set remove all but the ac cord connectors from the power supply; label them first! turn on the tv if the power supply does not recycle turn off the set and, connect and, disconnect each cable one at a time going to the power supply turning the set on and, off each time as you test until the power supply cycles (fails) again then repair or, replace the circuit board that causes the power supply to fail. if the power supply cycles on and, off (fails) with all connectors but, the ac cord disconnected repair or, replace the power supply.
Jul 19, 2010 | LG 42PC3D 42 in. Plasma Television
TV will not power up, no lights blinking just a continuous beeping sound
Please follow the below troubleshooting steps: 1. If the Television is plugged into a surge protector, remove it from the surge protector and plug it directly into the wall outlet. 2. Try connecting the TV to a different AC wall outlet. 3. Try power resetting the TV. To Reset the TV, disconnect the power cord for a short period of time (approximately 1 minute), then reconnect the power cord and power ON the TV. 4. If the issue still persists, TV will require service.
Jan 23, 2010 | Sony FD Trinitron WEGA KD-36FS130 36" TV
Does not turn on, light flashes, it clicks once, the remote control will not even turn the light on
Jan 21, 2010 | Sony FD Trinitron WEGA KD-36FS130 36" TV
Philips magnavox won't turn off and stay in demontration mode
Hold both volume buttons at the same time for 6-10 seconds and that will reverse it. This has been proven to work!!!! YEAH
Mar 03, 2008 | Philips Magnavox 27MS343S 27" TV
Samsung LE32R74BDX 32 in. HD-Ready LCD Television Logo
Henry  Thomas
Henry Thomas
