Question about Amana Refrigerators
Amana Refridgerator BR18VW; P1320703W; 1101010605; 0011145133. Temperature in upper portion (fresh food) section not cold enough; setting unchanged at 3-4: Freezer section OK setting unchanged at 6-7. Refrigerator still running BUT no other sounds, i.e. condenser fan, compressor, freezer control clicks, etc.
  • 382 Answers
Hey as far the Fridge is running it must not be a botheration that there is no other soounds of compressor or freezer control, as it is a feature of Amana Refridgerators..Also try to decrease the Temperature of the Upper portion less than the current temperature..Hope it helps you!..
Please reply back for how things turned on or for further assitance!..Thank you!!..Regards!..
Posted on Jul 17, 2008
  • 97 Answers
Need more information. whats exactly is the problem. let me know ill fix ya.
Amana ABC2037DES Bottom Freezer Refrigerator
3e0fb770-1a2b-4585-8792-01c3cc3b036a.jpgc051bc82-adf9-4252-bf89-7a54e5ee5bae.jpgYour fresh food section may be too cold and causing this problem by freezing the water reservoir and sections of the
water line going to dispenser. If you cannot set the temperature a little warmer this can be caused by a defective W10196393 Auto Damper This problem also can be caused by the fresh food section 12002355 Thermistor The thermistor is a electronic way of measuring temperatures in fresh food section, freezer and ice maker also have thermistors.
Here is a ABC2037DES Tech Sheet with the diagnostic's
for thermistor's and the auto damper, I will help you if you like so please let me know if you have questions, Thanks Sea Breeze
May 09, 2013 | Refrigerators
Side by Side ModelsIf foods, such as fruits and vegetables, in the refrigerator are freezing, it can be caused by several things. First, check the controls. They should be set at "C" and "5" or "5" and "5". The proper fresh food temperature is between 38 and 42 degrees Fahrenheit. The freezer should be between 0 and 8 degrees Fahrenheit.
  • If food in the bottom of the refrigerator is freezing, this could be caused by a refrigerator not having enough food to absorb the cold air.
  • If food in the door is freezing, move the door bins up or down so they are one notch away from freezer vents (Side by Side models only).
  • The fresh food control should be at the normal setting of 5.
Freezer on Top Models
First, check the controls. They should be set at "C" and "5" or "5" and "5". The proper fresh food temperature is between 38 and 42 degrees Fahrenehit. The freezer should be between 0 and 8 degrees Fahrenheit.
  • Since the cold air coming into the fresh food section originates in the freezer above, the rear of the top shelf will be the coldest spot in the fresh food area. Avoid placing delicate items that freeze easily on the back half of this shelf.
  • If food is freezing in the produce (fruits and vegetables) or meat pan, it may be that the temperature controls are not set high enough. Since cold air naturally falls, the pans can get too cold if the refrigerator is not running long enough to maintain good air circulation. Adjust both controls up one notch.
Nov 01, 2012 | GE CustomStyle PSC23NSTSS Stainless Steel...
Ge refer model psc25mstass fresh food section not cold enough freezer cooling fine
I realize this is an old post but information is always helpful if it is correct. I have a GE Model TFX22ZRB, Main tools needed are a refridgerator thermometer, a cheap multimeter, 1/4" hex driver, phillip screwdriver and regular blade scewdriver, above all, alow time for tempeture change when measuring tempeture. The freezer is running at -8 degrees C or aproximately 28 degrees F. I don't care about 1 or 2 degrees at this point in the freezer, the defrost system is working ok, The freezer is cold enough. The fresh food section is running at 48 degrees F, the damper is wide open between the freezer and cold food section, I manually removed the damper door and controls since I am only interested in seeing if I can drive the fresh food section colder. Looks like the fresh food thermostate controls the compressor and not the damper to shut off the cooling process when the tempeture gets cold enough. Since the fresh food section does not get cold enough (this should be in the uppers 30s F) there is no need to move the fresh food thermostate out of the normal range setting (mid point in my case) with the operator control. Defrost heaters ok, this unit uses 2 heaters hooked in series with a evaporator coil thermostate also in series with the heaters. Heaters aproximately 25 ohms total risistance, coil thermostate open at room temp and closed when below 32 degrees. Only other item in circuit is the defrost timer, this can be manually advance to open and close the defrost circuit, in my case, when in the defrost mode, the evaporator fan stops and the heaters heat up. The defrost timer in my case has a 12-16 hour cycle time and a 30 min defrost time, so in a 24 hour period I may get only one defrost cycle. One item of importance. make sure something has not fallen in the lower back or the fresh food section of the refridgerator to block the air flow return, this will effect the coo;ing process. Now with the damper wide open, the defrost circuit working ok I am going to look at the evaporator fan itself for speed, shifted blades or the air circulation between the freezer and the fresh food section, I have cleaned the condenser coils but I am leaving the condensor and compressor out of the equation since the freezer is cold enough but at this point I am considering the possibility, I may need to replace the fridge if the compressor is not working to par.
Jul 18, 2012 | Refrigerators
Freezer turns of in cold weather
Many residential refrigerator / freezers are designed to work at temperature considerably above above freezing. Most modern refrigerator / freezer have a single electric thermostat - located in the fresh food compartment. This lone thermostat will control the compressor to keep the fridge (fresh food) section at the desired temperature (usually between 34 - 38 degrees F). The freezer will get colder regardless of how cold it is already whenever the fridge thermostat turns the compressor on.
Now that you see how the thermostat works, let's look at what happens when the fridge is placed in an unheated space - like a garage. In winter time, the temperature can drop considerably below 38 degrees. If the outdoor temperature remains cold enough, for long enough - it will affect the thermostat in the fridge. The temperature inside the fridge could drop below 38 degrees, preventing the thermostat from telling the compressor to turn on. Meanwhile, the temperature in the freezer compartment slowly rises from the normal -10 to 0 F degrees. It will continue to rise until it is the same temperature as the fresh food compartment or until the thermostat in the fresh food compartment tells the compressor to turn on again. This means the freezer contents will thaw.
If the temperature in the garage is even in the 40 to 50 degree range, the loss of cold in the fridge may not happen often enough to keep the compressor coming on often enough to keep some freezer items frozen solid - such as ice cream. Remember, water freezes at 32 degrees F, other products may require lower temperatures to remain frozen, and could thaw at 28 or other temperature.
Feb 13, 2012 | Refrigerators
Amana AFI2538AES The refrigerator portion keeps freezing the fruits and vegetables. The chiller control is on the warmest setting and the refrigerator temp is set at 43. I have been raising every once...
Our Amana afi2538aes is doing the same thing. Had a repairman out. He called tech support at Amana. They had him adjust the "thermistors" but it is colder than ever running at 28-30degrees in the fresh food compartment despite being set at 46 degrees. Tech support also recommended installing some sort of "ice bin seal kit to take care of the problem" according to our invoice from repairman. Repairman was told that the ice bin in the fresh food compartment puts cold air out (to keep the ice frozen) which freezes the food in the fresh food compartment. I called Amana and the rep I spoke to said he couldn't find record of this being a problem with the model but tech support told our repairman "we've had a lot of problems with this happening."
Mar 31, 2011 | Amana AFI2538AES Stainless Steel (256 cu...
After a bottle of gin broke spilling it's contents in the upper portion of our bottom freezer Amana Model BRD18V2S, The refrigerator no longer gets cold, we have aired out the liquor fumes and although the...
My wife posted the information below and I would like to add more to the story: We have two identical Amana Bottom Freezer Refrigerators, Model:BRD18V2S installed in our Kitchen. Both fridges are in an alcove and stand next to each other. One fridge is used as the beverage fridge and othe other is used as a food fridge. At about 10pm she noticed that an entire bottle (600ml) of Gin had cracked and emptied into the refrigerator section of the fridge used for beverages. We do not know how long the spilled gin was in the fridge. She mopped it up and we went to bed. At 7am the next morning, the beverage fridge and its freezer were showing 71 Degrees F. and everythind including the ice had melted. (We have aftermarket external temperature gages that show the fridge/freesor temperatures) The food fridge uninvolved with the gin spill was reading 68 Degrees F
Sep 17, 2010 | Amana Refrigerators
Amana Refridgerator freezes in the refridgerated cavity.
Many Amana refrigerators have something called an auto damper. It has a thermostat coil on the side of it and as the temps get colder the damper door closes. If the thermostat on the side becomes defective then the damper door will remain open or shut. If it remains open the food in the fresh food compartment will get so cold that sections will freeze. If you could send the model number of your Amana I may find a service manual with instructions that tell you how to test by removing and dipping the thermostat into warm or cold water to see if it is working properly. I will be here in and out to my other websites but would be happy to assist you and resolve this problem. Thanks Sea Breeze
Jan 21, 2010 | Refrigerators
Refrigerator does not get cold - GE side by side
In my GE side-by-side refrigerator (model number GSS20IEMDWW), there is a motor-controlled flapper door between the freezer and fresh food side. Cold air from the freezer side cools the fresh food side when that flapper door is open.
It is located at the top of the fresh food side on the dividing wall between the fresh food side and the freezer. If this is blocked with something (large left-over container, soft drink bottles, etc), it _may_ be enough to prevent sufficient cooling of the fresh food side.
Of course, there may be a more serious problem with the flapper door mechanism or the control unit that signals the flapper door to open/close.
The vegetable and deli drawers may have a small opening (manually controlled with a wheel or a slider of some sort) that connects those drawers to the freezer side, thus explaining how those areas are still functioning as expected.
Jul 27, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Amana energy saver not keeping fridge section cool enough. HELP!
if there is frost build up on rear wall of freezer section the unit is not going through defrost cycle which builds up frost on evaporator and restricts cold air flow to the fresh food section. one of three things are bad. defrost heater, defrost thermostat or defrost timer. if no frost on rear wall you might be low of freon.
Jun 24, 2009 | Amana ABB1927DE Bottom Freezer...
Sub zero refrigerator freezes food
Hello. You need a new cabinet thermistor and while you are at it replace the evaporator thermistor. (The evaporator is the cooling coil behind the back wall of your fresh food section) . These sense the temperature in your frig. Both of them are behind the back wall of your fresh food compartment. You will need a wire crimper and a heat gun or lighter to heat shrink the wire connectors that come with the new ones.
Sep 20, 2008 | Sub-Zero 650 / O Bottom Freezer...
Refrigerators Logo
245 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
