Question about Whirlpool 21.0 cu. ft. Top Freezer Refrigerator with IceMagic Plus Ice Maker
Where does this part/piece go in the frig?
I have a 6.5...top load older refrigerator... I believe it's a Whirlpool ZITFA model, however not sure.
I removed the bottom (glass section) along with the supporting plastic casing (which holds two plastic humidity drawers) so that I could wash them and the side of the frig.
There is a white metal bar...which was attached to some one of those parts... which came out during the cleaning... and I don't know where to place it...
Can you help me please?
By process of elimination .....I finally figured it out...
Posted on Jul 18, 2008
I have Whirlpool frig. When it goes into defrost water drip inside the frig and collects at the bottom. The water appears to be coming into the frig through a channell in the center back of the freezer...
Hi Patrick, Looks like you have a drain hole that is plugged up with ice, there is a easy way to fix it, I will refer you to this video that shows you how to clear the drain. Take care Ryan http://www.youtube.com/watch?v=_ycWz_U_GDU
May 29, 2011 | Refrigerators
Water leaking from the freezer into the frig through the vent in top of frig Model#ETIPHKXPQ00
Check out these tips...they can help you figure out what is going wrong withyour refrigerator
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
May 21, 2011 | Whirlpool Refrigerators
Frig cools works great all day then trips the gfci
Hi Sturkle;
Does this happen say- every 6-8hrs? If so you may find the defrost element has a short, or defrost timer is faulty. Defrost element is located in the freezer compartment, Time located an back of fridge.. Use a qualified person when playing with electrics...Cheers
Mar 29, 2010 | Whirlpool ET8GHMXLQ / ET8GHMXLT Top...
Bottom frig is not cold enough. just connected after 1 yr
Ok do this. Boil some water in a pot then use that to defrost the freezer. This is caused by ice build up in the vent that is keeping the cold air from coming into the refrigerator. Make sure it is defrost completel though cause the ice that is built up is mostly inside and can't be seen. That will solve ur problem I guarantee. Then set the temperature to normal. Like half way. This keeps the frost from building up. Believe it or not as refrigerators get a bit older they actually get even colder and therefore frost build up is more likely. Since no refrigeration can be made completely leak proof, small amount of the freon has leaked out older fridge, and this actually cause it to get colder. You don't need a service technician just defrost then set to a lower setting thats it.
Feb 11, 2010 | LG LRTC19314ST Top Freezer Refrigerator
Water condenses on the ceiling of my frigerator.. and collects in the bottom of the frig, the shelves and drawers.. it does not drain outside the frig and the back of the frigerator doesn't appear to come...
Yes, you may have two problems. The seals around the door are defective or the drain to the pan below the refrigerator is blocked or both. I will need you to read a few things that may help you and I am here to help you get this solved. Now because the water is inside the fresh food compartment I believe the drain is blocked in sid the back and rear of the refrigerator. Look at the first link below and see if this applies to you. Then read the second link and ask me questions if you need. Please rate me and Thank You, Sea Breeze
http://appliancejunk.com/forums/index.php?topic=22.0
PART NUMBER AND MODEL SEARCH FEATURE
kitchenaid-top-mount-refrigerators/">http://fixitnow.com/wp/2009/05/26/the-permanent-cure-for-repeatedly-freezing-condensate-drains-in-whirlpool-roper-kitchenaid-top-mount-refrigerators/
Jul 15, 2009 | Amana ATB1832AR Top Freezer Refrigerator
TOP-MOUNT REFRIG, FREEZER ICES UP AND HAS TO BE MANUALLY DEFROSTE
I recommend you call me and i can really help you over the phone to get a good understanding Whirlpool Parts
Apr 26, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Annoying beeping of the Kenmore refrigerator!!!
I don't believe this model has an alarm in it. The beep you hear maybe the evaporator fan motor, also if there is an icemaker in the frig be sure it is turned off
Jan 24, 2009 | Whirlpool ET1FHTXM Top Freezer...
Water dripping from somewhere inside the refrigerator
I believe the problem is with the drain line when the frig goes into defrost mode
see if you can trace the drain line that oes into the evaporator pan at the bottom of the frig
facing the frig remove the bottom panel that goes across the front and pull out the evaporator tray to see if it is dry
take a flashlight and see if you can see a plastic tube that the water should be dripping into the pan
try to trace the tube up into the frig ther is some type of catch basin inside the frig on the back panel usually around middle area
If you are not able to find it you can call whrlpol customer service 1-800-253-1301
or call an appliance service enter and as them f they can walk you through the problem
Good Luck
Jan 02, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Whirlpool gold conquest refridgerator
if u find out let me know. when we turn both frig/freez switches off the frig light comes back on flashes to number 6. it still seems cold be like this 2-3 days the food still seems cold. good luck. jax, fl
Mar 16, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirlpool 21.0 cu. ft. Top Freezer Refrigerator with IceMagic Plus Ice Maker Logo
82 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
