Question about Microsoft Windows Vista Ultimate Edition
Vista 64bit loaded vista and pick the 64bit option for my hp 6710b,and made the recoveries cd's.I know have a printer problem as there is no driver for 64bit.How can i get computer reformated and select the 32bit option.thanks Johann
    Novelist:
    Scholar:
  • 160 Answers
You can't. The only way is the hard way - reinstall and wipe the disk. Sen your thanks to Bill Gates....
Posted on Jul 18, 2008
I need a recovery CD for a HP Compaq6710b
if your recovery partition is corrupted, and you have not already made recovery disks (CD/DVD), you must contact HP support. They may or not be able to help you, and may or may not charge you for them. Else, return your system to factory state using either of these two media. Find the general procedure (somewhere) on the HP website. Your nest best option is to seek advice on the HP Community forum, accessible through the HP website
4.May.2014
Mar 22, 2014 | HP Compaq 6710b Notebook
The pc will not detect the wireless card. Already updated driver, BIOS, and tried a new card. I did update from Vista to 7 Professional.
Did the wireless card ever work? If it did work I would check to see if there's a physical switch on the laptop. Try switching it off then on. I would also try a different driver. Sometimes I've used an older or newer driver to get a wireless card to work. So if the driver that's installed is for Vista I would try obtaining one for Win 7. You could also try a wireless driver fro XP 64bit. I've found that some Manufacture's Web sites have several drivers listed for "network card" you could have a installed a "network card driver from HP's site but it might not be the correct version or manufacturer. From HP's site I don't see Win7 listed as an option. So you could have an incompatible driver installed. http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?cc=us&lc=en&product=3376893
One other item to check. If you had Vista 32bit installed originally then went to Win 7 64bit you could try the Vista 64bit driver.
If all else fails you could purchase a USB wireless device to make your laptop wireless again. I picked up a Trendent
http://www.techpartswarehouse.com/product/TN-TBW107UB-TRENDnet-Micro-Bluetooth-USB-Adapter-5600.cfm?sid=google&gclid=COGH5NyNv7oCFe1aMgod93wAuA
Let me know if you have any other questions?
Brian
Oct 30, 2013 | HEWLETT-PACKARD HP Pavilion dv6324us...
Cd rom driver hp 6710b
Check hp website please
Jan 06, 2013 | HP Compaq 6710b Notebook
Set msi 171f to factory defaults
Normally, you would press F10 or F11 at Startup to commence the Recovery Process..
Another way I have seen on some models is to tap F8, and go to a list of Startup options, and start a Factory Standards Recovery from in there, by selecting the Repair computer option.
Also ask them if it is possible to make Recovery Disk/s from the Recovery Partition in case of Hard Drive failure or System Crash.
They will tell you how to do that.
Each Computer Manufacturer has their own way of making Recovery Disk/s.
Or borrow a proper Microsoft Vista DVD(not Dell, HP, etc).
A proper Vista DVD contains all Vista versions.
The Product Key determines which Vista version gets installed.
There are 2 Vista disks: one for 32bit Operating System, and one for 64bit Operating System.
If a clean install is required with a proper Vista DVD (not HP, Dell Recovery Disks):
Go into your Bios/Setup, or Boot Menu, at startup, and change the Boot Order to make the DVD/CD drive 1st in the Boot Order, then reboot with the disk in the Drive.
At startup/power on you should see at the bottom of the screen either F2 or DELETE, to go into Bios/Setup, or F12 for the Boot Menu
http://support.microsoft.com/default.aspx/kb/918884
MS advice on doing clean install.
http://www.theeldergeekvista.com/vista_clean_installation.htm
A Tutorial on doing a clean install
http://www.winsupersite.com/showcase/winvista_install_03.asp
Windows Vista Installation Super Guide
After installation > Go to your Laptop/Computer Manufacturer's website > Drivers and Downloads Section > Key in your Model number > Look for latest Vista Drivers for it > Download/install them.
Save all Data, as it will be lost during a clean install.
hope this helps
Jun 26, 2012 | MSI MS-171F (937-171F44-001) Barebone
Drivers for hp vista campaq 6710b
Here it is: http://www.laptopdrivers.net/download/hp_compaq_6710b_drivers_for_windows_vista_business_32bit.htm
If you have vista professional 32bit, these drivers will work for you. If you have 64bit system, comment it.
Mar 28, 2011 | Computers & Internet
I have cd for my printer but computer does not accept it
Hello
It may be the wrong driver CD for your PC system you are trying to install it on if you got the new windows vista or windows 7 you need the right driver for it so I have put vista and XP for you to download Vista will some times do for windows 7 as well so pick the one you want to download.
I not sure what one you wanted so I put the 2 there for you I also have the Windows-7-32Bit-64Bit and XP-32Bit-64Bit and Vista-32Bit-64Bit
I have put the software driver for you on my website you can download it from there all you got to do is click on the link I put for you, it may take time to download for you depending on the speed of your internet all the best.
Click Link= XP http://www.4all2sell.com/driver/Lexmark-X1270-XP-32Bit.exe
Click Link= Vista http://www.4all2sell.com/driver/Lexmark-X1270-Vista32Bit.exe
When download save it to your desktop so you can find it easy and then just double click on the icon and follow the instructions.
All I ask is to call back and just gave a vote, it will gave me some satisfaction to know am helping some one, so I will keep on helping.
All The Best: Pineworks
Feb 07, 2010 | Lexmark X1270 All-In-One InkJet Printer
32bit vista to 64bit win7
your recovery manager files should be on drive D or other partition. if not then its gone. but the operating system cd that goes with your laptop is still better than the factory default anyway but the thing is, youll need the cd everytime you want to reformat.
if i where you, il go for 32bit win 7 since your computer used to be a 32 bit vista. no worries about making the most out of your computer since win 7 eats less than vista anyway. and go for 32 bit since your laptop is made for 32 bit.
Dec 30, 2009 | HP Pavilion TX2510US Notebook
LBP2900B DRIVER CD
CANON LBP2900B DriversHere is the driver for Windows 2000/XP/Server 2003/Vista/Server 2008/Windows 7
Installation Procedure when Connecting USB Cable
Do not connect the USB cable until after you have loaded the downloaded files.
After all files have been loaded connect the USB cable to the back of the printer.
DRIVERS
Thanks & Regards
M. Nanda Kishore
Dec 29, 2009 | Canon LASER SHOT LBP-2900 Printer
I can't print from any program in Vista 64 to my HP 755cm plotter. HP said they no long support this plotter so I can't find a driver. Any suggestions to make this work?
If HP don't support it for Vista you will not be able to get a driver unless you are willing to pay a programmer several thousands of pounds to go into the Vista OS and findout what information it needs so that he can write the drivers. He would also need developer ststus from Microsoft for the source codes etc. Either bin Vista (it's being replaced later this year) or buy anther plotter.
Sorry to be the bearer of bad news. (HP ****!!)
Jul 29, 2009 | HP DesignJet 755cm InkJet Printer
Microsoft Windows Vista Ultimate Edition Logo
81 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
