Question about Vacuums
My dyson dc07 works fine for about 5 to 10 min then turns itself off leave it for 10 min or so then it will work again for a bit then does it all over again. help please thanks
Your machine is overheating. This is usually caused by the dust bin being too full, your filter is long overdue for a cleaning, or there is a clog in the machine. Usually a cheap fix regardless... Wash your filter, check the removeable parts for blockages, and empty your dust bin.
Posted on Jul 18, 2008
Swithes itself off after approximately 5 minutes?? is ready to use again approx 15 mins later but again only for 5 mins ? Angela
Sorry to hear you're having difficulties with your DC07. Like most Dyson cleaners, your DC07 is equipped with a safety device which shuts off the cleaner if it starts to overheat. This is often due to a blockage, or because the filters need a wash. The easiest way to check for and remove any blockages is to follow the steps shown in our online guide:
http://www.dyson.co.uk/support/help.asp?article=4&product=DC07-SY
The correct way to wash the filters is shown in the video embedded below. The filters should be washed in cold water at least once every 3-6 months. Always ensure they're totally dry before replacing them.
Hopefully this should resolve your issue. However, if you've followed these steps and are still concerned, it's probably best if you get in touch with us directly. You can call us free on 08002980298 (UK), or 1866MYDYSON (US). One of our experts will be happy to run through some troubleshooting over the phone with you and recommend the best course of action.
Kind regards,
Jack
Dyson Online Customer Support
Jun 17, 2011 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Stop working. brush was cloged. It there a reset button?
i had a similar thing happen and just got off the phone with dyson. there is a resettable switch on the handle. they told me to start the vacuum in the upright position, put it in the non upright position, then push and hold in the beater bar switch which is located next to the on/off button for 10 seconds and the beater bar should start to function once again
Jul 15, 2010 | Dyson DC07 Animal Bagless Upright Cyclonic...
Stops working after about 5 minutes. leave for 20 and it starts again for a while.
Sounds like your motor has had it, Its probably ruined your Post filter too.
If you visit http://www.sparesaver.com/help-and-support/dyson-section/dyson-technical-advice-450/ they have alot of info on repairing dyson cleaners AND they sell the parts, cheapest ive seen online.
Hope that helps
Jul 05, 2010 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Dyson dc07 works for a bit then switches off all the time
If you used a credit card with extended warranty or its within 1 year, take it back. You are correct about the overheating. We have the same unit and it works fine for over 3 years. I did see rebuilds at Big Lots which worried me for a $500 vacuum to have a reliability problem. Guess the recycled vacuums had bad motors?
Aug 21, 2009 | Dyson DC07 Bagless Upright Cyclonic Vacuum
My Dyson stops working after using it for a while!
You are probably experiencing a thermal cut-off which means that there is a blockage in the machine. Call the Dyson Helpline, they'll help you find it.
Jul 09, 2009 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Just stopped mid hoovering and now won't switch on!
It is probably a thermal cut-off which is caused by a blockage. The machine will turn itself off before it overheats if it is a thermal cut-off. Once it has cooled down, you will be able to turn it back on again (usually 30 mins - 1 hour).
If the machine doesn't turn on at all anymore, you may need to replace the power switch. Call the Dyson helpline, they will do a blockage troubleshoot and if it's not that, they will tell you where you can find an authorized Dyson repair dealer in your area.
Jul 07, 2009 | Dyson DC07 Bagless Upright Cyclonic Vacuum
The motor will not turn on. One minute it was
Called the phone number posted on the vaccum cleaner itself and my husband received technical support directly from Dyson. Problem solved at no cost to us. Vaccum is working fine.
Jun 03, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
My Dyson DC07 won't turn on!
you may have a broken belt. Bad news regarding all Dyson's. You can't replace just the belt your self. You have to purchase a new belt assembly which includes the gears. And it wont be cheap. I would call it a design flaw but i am sure that dyson calls it a profit scheme.
Jan 24, 2009 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Dyson dc07 animal
This is from the Dyson web page:
Get expert help Thermal cut out Most Dyson vacuums have a built in safety system that stops the machine if it begins to overheat. This usually happens because the filter needs washing or your machine is blocked. If your machine turns off on its own, unplug it and leave it for at least an hour to cool down. Remember to check the filter and look for blockages before re-starting.
Any non- domestic use may adversely affect the filter performance such as vacuuming up plaster dust.
Sounds like your vacuum is overheating. Check the above.
Lou
Aug 30, 2008 | Dyson DC07 Animal Bagless Upright Cyclonic...
Vacuums Logo
117 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
