Will it work on the 110 volt power supply ? If not then a new one is in order. Another source of a no start is the coin cell battery inside the laptop. I wouldn't think this is a problem on a new laptop.
you start on take the disc of windows & put in the laptop and you restart your laptop then you can start to intoll your windows on the laptop when you done you have to restart again then your laptop is goin to work.
computers and laptops are designed not to damaged the hardware from it..thats why its automatically off you laptop encounters error from your harware..check the temperature, and check the fans if they working properly..if not try to clean the fans..
If your laptop is out of warranty, then you can fix the problem by resoldering DC-IN ... Power LED and battery charge LED start flickering when you wiggle the power .... HP Pavilion dv7-4080us 17.3-inch Desktop Replacement Laptop PC... High-Capacity Battery For Hp Pavilion Zd8000 Series Laptops... www.articlesbase.com › Computers › Laptops
It is NOT Battery or Power Supply it is your laptop itself has gone faulty... You need to troubleshoot the Motherboard, hard Drive etc, to find the exact problem that will allow you laptop to start. A laptop, will go, with just the power supply, and NO battery, if it doesn't either Power Supply is faulty, regardless of lights, OR the laptop's motherboard or hard drive is faulty, you must isolate problem.
Hi I am a laptop technician, and it sounds like you have a power problem.
Try removing the main battery and starting the laptop on the mains cable only. If the laptop starts fine then you probably have a problem with either the battery or the power board in the laptop.
If the laptop doesn't start when doing this, remove the mains power lead from the laptop and put the main battery back on the laptop. Try starting the laptop off the main battery only and if the laptop starts normally then you most likely have a broken/loose socket that the power lead plugs into in the back of the laptop (a very common problem) or the power board in the laptop is faulty. If the laptop doesn't start or goes off very shortly after pressing the power button it could just be that the battery is flat as a broken power socket on the laptop often stops the main battery from charging.
I understand the urgency and also the importance of data stored in the laptop.
As the laptop is unable to start in normal mode let us try in safe mode.
Follow the steps below:
1. Turn the laptop off completely.
2. Press the power on button to turn it on and at the same time simultaneously keep tapping ' F8 ' key on key pad until you see a advanced boot options screen.
3. Select 'safe mode' and hit enter.
