Question about Samsung SP-R4232 42 in. Plasma HDTV
Plasma tv sparkles on black background dark screen gets white spekles after been on around an hour then can sometimes go off
  • Cedric Hamilton May 11, 2010
    What is the normal voltage on those. I got almost 200 VDC. Is that
    right? I guess an oscilloscope would be the best way to make the
    adjustments but if you don't have that can you wait until it is
    happening on a regular basis and then adjust it off? Is the reason it
    is happening because of overheating due to the voltage being to high?
    Thanks,
    Ced
    Champion:
  • 217 Answers
Ned to adjust the VS-voltage or the VSCAN-voltage
Posted on Jul 20, 2008
Thin vertical lines on plasma tv
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to both Plasma display & LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Aug 21, 2015 | Samsung Televison & Video
Hi, I have a 50 inch Panasonic Viera TC-P50G25 Plasma TV. It worked great the first four months. Around the 5th month, white little blinking sparkles were all over the screen, and of course, they could be...
You are going in the right direction. Use that warranty to the MAX!
In a nutshell, the problem is probably related to the sets power supply.
I have answered quite a few plasma TV problems and most are centered around the power supply.
It takes a huge amount of current to "ignite" the plasma to get it to glow. Once it is lit, current is constantly fed by scanning through over a thousand "power" lines on one side of the screen and scanning over a thousand "address" lines on the other side. The sparkles and lines can be a secondary effect of its not being able to regulate voltages correctly.
The power supply in a plasma set has its work cut out for it and it is very important to make sure that it gets the ventilation you manual says it needs.... blocking the vents can quickly overheat a plasma set.
Some FYI stuff about plasma TV's....
1- due to their very nature, a plasma picture will dim over time. The materials that make up the power and address lines are slowly "sputtered" across the very thin gap between them and eventually darken the inside of the glass. This is slowed down some by coating the insides with a clear magnesium oxide film during manufacturing.
2- It is very easy to "burn" an image into a plasma TV screen, so avoid playing video games on it and don't let a "still" screen stay on more than a minute or so.
3- The screen itself is made of common "soda glass" - the same as window glass, and is usually 1/4" thick on each side (a little over 1/2" total) and this accounts for most of the sets weight. Between the two glass plates, there is a small gap that is made by fusing thin glass rods into the screen. In this gap is a vacuum, with a small amount of a rare gas mix added. Be careful not to hit the screen because if it cracks, vacuum integrity is compromised, the gas escapes, and your TV will be worthless.
Good Luck!
V.
Feb 13, 2011 | Panasonic Viera TH-42PZ80U Plasma TV
Magnavox 42"
You are correct=====Return it ! It's new, you should not have to have it repaired this soon.
Sep 23, 2009 | SNK Magnavox 42MF231D 42 in. Plasma TV
Dell W4201C, White screen on Power up (used to be Black).
Y SUS and Buffers are usual culprit.
You can get it from guy at
plasmatech@gmail.com
He has everything for Dell TVs!!!!
Apr 17, 2009 | Dell W4201C 42 in. Plasma HDTV
Toshiba plasma blank screen
your video card needs replacing, 75.00 plus labour
Jan 24, 2009 | Philips 42FD9954 42 in. Plasma HDTV
Zenith P42W34P Plasma Display Panel
Hello, My name is Dave and I can help you fix your Plasma TV. Do you have Black vertical 1.5 inch line or lines on your screen that come and go? Then give me a call. Please feel free to give me a call @ 1-503-432-9904 or message me at pleasefixitdave@yahoo.com
Thank you!
Dave,
Nov 20, 2008 | Akai PDP-4247 Television
Plasma tv
change the z-sus panel or control panel
Feb 28, 2008 | LG 42PX5D 42 in. Plasma HDTV
Lg 42pc1d plasma tv red sparkles
I had the same problem, LG came out and it turned out to be the board that filters out the interference around the screen. I pretty sure that was it, took them 10 mins to fix by replacing a few of the boards inside the screen. Sorry I can't be more specific but its not an unfixable problem, so nothing to worry about.
Nov 11, 2007 | LG 42PC1D 42 in. Plasma Television
My Samsung Plasma just got burned in!
I stupid friend of mine came over to feed my dogs when I was out. He watched my Plasme tv for a while and when he shut the system down he only turned the cable box off for opprox. 6 hours. I did have th Tv on pixal shift . Know my screen seams grainy in dark scenes . I does seem a little better after a rolling picture screen. How long do need to run the screen before it gets better?
Apr 02, 2006 | Samsung HP-R5072 50 in. Plasma HDTV
Samsung SP-R4232 42 in. Plasma HDTV Logo
498 people viewed this question
Henry  Thomas
Henry Thomas
