Question about Philips Magnavox MWR20V6 DVD Recorder/VCR
Remote malfunction, magnavox dvd for mwd 2206
Can get power to turn on dvd/vcr ...........but can't control any of the functions. changed batteries; still won't work.
  • vaudeville Aug 08, 2008
    I have the same problem...and it just happened all of a sudden...i changed batteries and still doesn't work, I can use the buttons on the player though! any suggestions?
3 Suggested Answers
SOURCE: my vcr won't play back
I have a Magnavox zv457mg9 DVD&VCR combo ,and the vcr records for a short period(10minutes) and then cuts off. This happens each time I try to record on the VCR. Any suggestions??
Posted on Nov 09, 2008
konzzz
  • 255 Answers
SOURCE: Have a Magnavox DVD/VCR player Model MWD 2206A,
units like DVD's, have the tendency of malfunctioning if not used for quite sometimes.corrrect me if i'm wrong.but like automobiles needs tune-up, right?try power it on for some time, but not using it.if still not call a tech
Posted on May 14, 2009
I need code(s) for my DVD Video, Model #: NB093 remote control to program my Philips DVD Player/VCR, Model #: DVP3345V/17. Can you please help me? I would greatly appreciate it. Here is a picture of it.
http://remotecodelist.com/remotes/magnavox/magnavox.htm lists the code for your device as possibly being 1000, 1001, 1002, 1003, 1004, or 1005. Of course, you also have the option of using the remote controller's "Code Search" button. 25300580-iv4burzhkawezvl2jbah1xae-2-0.jpg With Codes:
Turn on the DVD/VCR unit directly. Continue to depress the remote controller's "Code Search" button for about ten seconds, release, & the light on the remote controller should stay on. Enter the four-digit code (1000, 1001, 1002, 1003, 1004, or 1005) for the DVD/VCR unit. The remote controller's light should go off. Press the remote controller's power button, & when the DVD/VCR unit turns off, then you will know that the remote controller has been correctly programmed.
Without Codes:
With the DVD/VCR unit on, continue to depress the remote controller's "Code Search" button for about ten seconds, release, & the light on the remote controller should stay on. Continue to tap the remote controller's UP or DOWN channel button ONLY UNTIL the DVD/VCR unit responds. Then, press the power button on the remote controller once the channel has changed. If the DVD/VCR unit shuts off, then press the power button again to turn it back on. If the DVD/VCR unit turns on, then the remote controller has been correctly programmed. Otherwise, repeat this whole process until the remote controller is correctly programmed.
Nov 29, 2014 | Televison & Video
Need code for magnavox tv urc-4021boo
Hi, the codes you have requested;
Magnavox - 0054, 0706, 0030, 1454, 1254
Instructions to program code:
1. Turn on a desired device (e.g.,VCR or DVD player) and, if applicable, insert media (e.g., cassette or disc). NOTE: Please read steps 2 through 4 completely before proceeding. Highlight or write down the codes and device you wish to program before starting step 2.
2. On the remote control,press a device key once (i.e., VCR/PVR, DVD, CBL/SAT,or TV).
NOTE: To program control of a VCR, PVR (or DVR),TV/VCR Combo, or TV/VCR/DVD Player Combo press VCR/PVR once.After programming a VCR Combo device, you will be able to control channel selection, volume, and VCR functions. NOTE: To program control of a DVD Player,DVD Player/VCR Combo, or TV/DVD Player Combo, press DVD once.After programming a DVD Combo device, you will be able to control channel selection, volume, and DVD functions. NOTE: To program control of a Cable Box, Cable Box/PVR (or DVR) Combo, Satellite Receiver, or a Satellite Receiver/PVR (or DVR) Combo, press CBL/SAT once.
3. Press and hold SET until the LED (red light) blinks twice,then release SET.
4. Use the Manufacturer's Codes (starting on page 18) to locate the type of device and brand name and then enter the first four-digit code for your device. If performed correctly,
the LED will blink twice. NOTE: If the LED did not blink twice, repeat steps 2 through 4 and enter
the same code again.
5. Aim the remote control at the device and press POWER once.The device should turn off. If it does not, repeat steps 2 through 5, trying each code for your brand until you find one that works.
Feb 12, 2011 | One For All URC-4021 Remote Control
Magnavox vcr/dvr. insert vc tape, machine loads and plays tape for about three seconds then stops and ejects tape. tape will not stay playing. thanks, larry
Mine does the same.It's basically junk.A new VCR/DVD player goes for around $80.If you were to call to ask about getting your VCR repaired,they would tell you that it is FAR cheaper to simply purchase a new one.Same Magnavox I bet almost too.model # for mine is MWD 2206.Labor alone is easily at least $60/hour and it would take that just to disassemble and reassemble the VCR section just to get at the problem.Greg
Feb 10, 2011 | Televison & Video
Need code for a magnavox dv220mwn dvd/vcr
The book don't have a code for a Magnavox DVD/VCR combo you can try Magnavox DVD 0503, 0675. or VCR 0035, 0039, 0081, 0000, 1781 you might be able to get some functions. Please give me a vote if this works.
Mar 03, 2010 | One For All URC-4021 Remote Control
May 13, 2009 | Philips Magnavox DVD/VCR Dual Player
Code for magnavox vcr/dvd player
I am going to assume you are talking about a code for a universal remote control.
It could be one of these:
434 934
The website with the most codes I have seen is http://dogbytecomputer.com/codes.htm#DVD CODES
Aug 13, 2008 | Philips Magnavox DVD/VCR Dual Player
My vcr won't play back
Feb 26, 2008 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Magnavox mwd 2206 dvd vcr player....shuts off with eject word across screen.
On a unit I checked with this same symptom, removing the top cover allows the unit to stay on and operate normally. There is some sort of sensor at the left middle of the chassis, which, when unblocked by any opaque object, allows the unit to remain on. A temporary fix (not advisable) would be to replace the top cover with a piece of clear plastic or taut saran wrap (no vent holes needed). It's unclear exactly where/what that sensor is from a cursory test. This is a work in progress on someone else's machine that I lack full access to.
Oct 27, 2007 | Audiovox VE1020 10.2 in. TV/DVD Combo
Philips Magnavox MWR20V6 DVD Recorder/VCR Logo
78 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
