Question about Amana ABB2227DE Bottom Freezer Refrigerator
Bottom freezer handle
Hi, the handle on my Amana 25 cubic feet bottom freezer came off. How do I put it back on?
  • 1 more comment
  • jim buck Dec 07, 2008
    My amana (model ABB2224DEQ) has a lower freezer handle that is attached be screws from the inside. There aren't any access plugs for hidden screws on the handle. I started to take the door apart but found the insulating foam glues the inside panel and outside panels together. They cannot come apart for access to the screws without destroying the door or the foam. Has anybody found a solution to retighten the handle screws?
  • Anonymous Mar 25, 2014
    looking to find out the cubic feet of our amana fridge
  • Anonymous Mar 29, 2014
    what is the cubic feet of the amana BC21V1W Bottom Freezer Refrigerator
At both ends and actually inside the ends of the handle, are small metal brackets that are attached to the door face by a single screw.
You access the screws by pulling the plastic plugs, using a very small and thin flat bladed screw driver.
My handle was loose but hadn't come off on it's own. But I couldn't get the handle to fully tighten.
My fix was to wrap each end bracket with a couple layers of electrical tape (not covering the screw hole) and reattached the handle.
It is now very tight, as it should be.
Posted on Jul 30, 2008
How to calculate cubic feet ?
Calculating the cubic feet of a space requires multiplying the area of the bottom times the average height. You get the bottom area by multiplying the length times the width. Remember, to get cubic feet, you need all your measurements in feet to start with.
Here is your formula:
VOLUME (in cubic feet) = Length (in feet) X Width (in feet) X Height (in feet)
If it's a rectangular room you're working with, it is all straightforward. If there are irregular walls, it may be necessary to divide up the room into rectangular sections and then add together their individual volumes. If the ceiling is sloped, you need to use the height that has the same ceiling area above it as below it. Good luck! Truly.
Jul 25, 2014 | Building Materials
Do you know the capacity (cf) of the amana br22tw,please?
The capacity is given in cubic feet, yours is 22 cubic feet. Note the 22 in the model number that denotes this BR22TW.
Sep 16, 2011 | Amana BC21V1W Bottom Freezer Refrigerator
What are the cu in capacity of each of the freezer & refrig. for an Amana SCD25TW?
Hello, the cubic feet capicaty is 25 cubit feet. 1 cubic foot is 1728 cubic inches so 1728 times 25 is 43,200 cubic inches
Aug 17, 2011 | Refrigerators
My fridge(& freezer) started giving off a bad burnt odor then stopped cooling (amana 25 cubic/mod #afd2535fes). any suggestions as to what it might be?
You said it stopped cooling, does the compressor kick on, or is it dead? Is the condenser fan operating (the one that blows across the condenser grill by the compressor)?
Is your condenser grill clean? What indications are you getting specifically?
Jul 15, 2011 | Amana 25" Cu Ft French Doors Bottom...
I have an old Amana top freezer (model TH25TW). I cant find out how many cubic feet it is; so, that I have an idea of what size that I want to replace it with.How can I find the size?
Here is a tip that I wrote that tells you how to figure out how big yourrefrigerator and/or your freezer is...
New Refrigerator Size or Refrigerator Cubic Feet
Heatman101
Jul 12, 2011 | Amana Refrigerators
I have a Kenmore model 795.7731 fridge and need the cubic feet of the model. Thank you.
Heatman101
Sep 26, 2010 | Kenmore 73502 / 73504 / 73509 Bottom...
What is the cubic feet for a 1999 Amana chest freezer model #AC151KW/P1317803W
Here is a tip that I wrote that tells you how to figure out how big your refrigerator and/or your freezer is...
Heatman101
Sep 06, 2010 | Kitchen Ranges
I'm trying to find out what the interior cubic footage of my Amana TX21A3W is? How many feet of that are refrigerator and how many feet are freezer?
This is a tip that I wrote and a couple of paragraphs down it tells you how to figure the cubic feet of your unit...
http://www.fixya.com/support/r4326731-new_refrigerator_size_or_refrigerator
heatman101
Aug 07, 2010 | Amana Refrigerators
We have Maytag 25 cubic feet stainless steel double door fridge with pull our freezer on the bottom. The fridge as stop being cooled but the freezer works fine?
There is a defrost problem. Ice builds up between the ref and frz sections and wont allow coolo air through. You can also check to see if the damper is stuck closed
Jun 13, 2009 | Maytag MFD2560HES Bottom Freezer French...
Loose handle on fridge freezer door.
that handle is just pressure fit on the clips securing to the door. grab hold ad PULL.and i mean PULL the the right. it will snap off just make sure you really PULL it. after that you cantighten the brackets on refig and inside the handle as well
Mar 08, 2008 | Amana AFD2535DES French Door Refrigerator
Amana ABB2227DE Bottom Freezer Refrigerator Logo
286 people viewed this question
Top Amana Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
