Question about Canon imageRUNNER C3220 Printer
Dirty drum Hello, Someone in the office tried printing on glossy paper, but unfortunately the color didn't stick. Now subsequent prints have blotches on them. Is there a way to clean off the drum? Thanks, Al
    Problem Solver:
Change to thick paper in add function
Posted on Dec 08, 2011
Dirty print on printed or incoming fax
I think is a cartridge problem, try to change it.
It's possible the drum to be worn. For a precise response, i need a picture with an printed page.
All the best !
Dec 01, 2017 | Canon L120 Fax Laser Printer
Samsung CLP 510 - won't print on photo paper.
Have you changeed the PAPER type to (specialty or card stock) this always work for me. Your printer will have these setting
Aug 31, 2008 | Samsung Office Equipment & Supplies
When printing, if I select any other form of paper than "Plain Paper", e.g. "Photo Glossy Paper", the print (of a photo) comes out with a distinct Magenta overhue. The true colours are...
Hello Landscapeman ,
You need to specify the paper type when the print dialog box appears. Heavy glossy paper needs to spend more time in the fuser so that the toner is fixed.
Mar 25, 2008 | Computers & Internet
Faded color prints
* If your are printing color photos on a Glossy paper you must chose the paper type from Media Type in the Printing Properties while giving Print command. If you don't know what is the type of your glossy paper then just select other glossy paper from the given options. f91a3a39-5f37-45c6-9bca-21ac453f79ef.gif
May 06, 2014 | Brother MFC Office Equipment & Supplies
Hello I have an HP 2600n and would like to print on 5x7 paper, is this a possibility with this printer? it seems that it will pull the paper through but nothing is printed
Copied this from the specification on HP site.
It would appear not to take 5 x 7. It's the 7" is to small, 8.5 is the smallest.
Media sizes, std.
Letter, legal, executive, No. 10 envelopes, Monarch envelopes
Media sizes, custom
Tray 1, 2, 3: 3 x 5 to 8.5 x 14 in
Media types
Paper (plain, letterhead, prepunched, bond, color, rough, preprinted, recycled), HP Color Laser Glossy Photo Paper, HP Color Laser Glossy Brochure Paper, HP Color Laser Matte Brochure Paper, HP Color Laser Matte Photo & Imaging Paper, HP Color Laser Soft Gloss Presentation Paper, HP color laser transparencies, labels, envelopes, cardstock
Nov 30, 2010 | HP Color LaserJet 2600n Printer
Printing misaligned color blotches, little squares off to the
Are you using genuine inks or compatibles/refills? Have you cleaned / aligned the print heads recently? Does it only happen on the second print? Could be a case of excess ink getting onto the rollers which then get hot and deposit the ink on the next paper coming through.
Also make sure you've selected the correct paper type before printing.
Oct 29, 2009 | Epson Stylus Photo 1280 InkJet Printer
Printing on glossy 250 gr. paper, the full red...
It may be a yellow drum problem if is just doing it with yellow
Dec 02, 2017 | Konica Minolta magicolor 7450 Laser...
Messy print when using glossy paper.
ok. sometimes the ink for hp if its not photo ink will do that. go to your printing settings/preferences and adjust your ink out put to less and dry time to more. you may have to adjust a few times to get the right balance. if you dont want to set it up for all printing you can also change settings when your ready to print. . just follow same steps when you are going to print. but you have to do it everytime you want to print a photo. also make sure to set your paper selection to glossy photo paper
Apr 24, 2009 | HP Color LaserJet 2600n Printer
Gray background where printo on glossy paper 130g/m2
hello
this sounds like a bad black ink cart, or the fuser rolls built into the printer are dirty.
you can swap out a black cart to test that theory, you can also just print a single blank page (no text or graphics) onto a piece of glossy paper and see if there is anything there after its gone thru the printer.
if the piece of paper has stuff on it it had to come from the rollers inside the printer.
service required,unless your comfortable changing out parts in your printer.
norm
Nov 06, 2008 | HP Color LaserJet 2600n Printer
Glossy Paper descalibrates my Ilumina
suggestions...
first, make sure all your consumables are in good condition, run a configeration page and check the percentages....toners should be 10% or more.
drume should be 50% or more(depends on what weight stock u been running), but run the ID check print, to see drum results.
The transfer belt should be above 20%..
This will ensure your machine can deliver.
next, make sure you have the correct paper weight setting( both in front panel(web browser) and (application drivers) for the stock. If you have setting gtoo high, then over toning will occur.
also, stock must be suitable for laser printing, offset, or cheap paper will drive you nuts....
good luck
Oct 15, 2008 | Xante Ilumina Digital Color Press Printer
Canon imageRUNNER C3220 Printer Logo
67 people viewed this question
old marine
old marine
