Question about HP OfficeJet 4215 All-In-One InkJet Printer
Paper jam in HP 4255 office jet all in one printer
I am having paper jam in my HP office jet 4255 all in one printer. Crumbled paper was taken out but printer is not working. I received a fax and something was in front of the hp officejet 4215 all-in-one. the fax came through and was a little crunched up but was just a little wrinkled. It keeps saying to open door and take care of jam and then hit OK. I did many times. There is no jam what so ever. It keeps making noises and saying paper jam.
What do I do it will not work? It just keeps on that open Door/Jam hit OK.        Jackie  @ jmredd@sccoast.net
  • lanzalass Feb 19, 2009
    cleared paper jam but will still not print and states still paper jam
  • Julie77 Mar 03, 2009
    Will only print one page at a time...prints fine until the end of the paper where it seems to not clear the feeder properly...then jams!
  • 84 Answers
The paper path may have some jam. It may have some solid particle or paper that's causing disturbance.
If not the paper moving mechanism is having problem.
Better get your printer serviced.....
Posted on Feb 11, 2010
I have a 4500 office jet and the paper is severly jammed. can the printer be taken apart to fix this problem
Yes; there is a great (official HP !) video tutorial on how to take it apart properly here:
Jul 17, 2014 | HP Office Jet 4500 G510n
Head is making noise of printer hp officejet 4255
Hi.
That's problem noise head of printer hp office jet 4255.
some paper and dust there in the head mechanical area.
you need to cleaning using vacuum and check-up inside printer.
to get paper and dust covering printer censor.
if you already get-off paper and dust.checkup also ink cartridge's black and colored.
power on printer if same problem you need to replace main board.
Jun 14, 2011 | Office Equipment & Supplies
False paper jam on HP Office Jet V40
hp officejet v40 indicates a paper jam and it is cleared nothing
Apr 04, 2009 | HP OfficeJet V40 All-In-One InkJet Printer
Paper out jam in hp laserjet 1020
Please visit this below mentioned link to troubleshoot your printer problem.
HP LaserJet 1020 Series Printers - Clearing Paper Jams
Thank You
Oct 20, 2008 | HP LaserJet 1020 Printer
Clearing paper jams
Paper jams can be real or false. The unit may report a paper jam even when there is no jammed paper. The solution to a real paper jam or a false paper jam is the same.
CAUTION:
Jammed paper must be removed using the rear access door with the power cord disconnected to avoid mechanical damage. Do not remove jammed paper from the front of the unit.
  1. Turn off the HP product and turn it around so the back of the unit faces you.
  2. Disconnect the power cord from the back of the all-in-one. The power cord must be disconnected to allow the paper feed rollers to turn freely.
  3. Locate and open the rear access door by pressing in on the left side tab and then pulling the door toward you.
Figure 2: Removing the rear access door
  1. Inspect the pressure rollers on the rear access door and verify that they are clean and turn freely. Clean the rollers if needed with a soft towel lightly moistened with water. If the rollers do not turn freely, replace the rear access door. Click How to Buy on this page to order replacement parts.
  2. From the rear access door opening, remove the jammed paper.
  3. Remove the remaining paper from the paper supply tray. Discard any paper that is damaged or crumpled and then re-stack and reload the paper into the paper supply tray.
  4. Reinstall the rear access door.
  5. Reconnect the power cord to the unit and turn the unit on.
Preventing paper jams
The following information will help prevent paper jams from occurring:
  • Never use paper that is torn or wrinkled.
  • If you are having problems using paper that has already been printed on once (recycling), replace it with new paper.
  • Remove and then reinstall the rear access door. Verify that the access door is fully locked in place. The paper can skew if the rear access door is not locked.
  • Every six months to one year, clean the paper feed rollers with a rag lightly moistened with water. Over time the paper feed rollers accumulate dust and do not function as well as they once did.
  • When printing envelopes, tuck the flap into the envelope and crease the folds before printing.
Jun 10, 2008 | HP OfficeJet 4255 All-In-One InkJet...
Printer, fax ,scanner,copier hp officejet 4255
hi....
pls click this link below. this is a link where you can get the software to download and select your operating system first.
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=351125&lc=en&cc=us&dlc=en&lang=en&cc=us
May 10, 2008 | HP OfficeJet 4255 All-In-One InkJet...
HP OfficeJet 4215 All-In-One InkJet Printer Logo
523 people viewed this question
Ben Johnson
