Question about Goodman CKL49AR49 Air Conditioner
Back up system inadequate?
My house inspector for a potential home purchase in checking the Goodman A49-20 unit said it was too slow/inadequate heating. It's the middle of summer and the house has been vacant for a year. After checking the A/C for a while he set the thermostat to force the back-up (sub 30deg) heating system on and said it should rather quickly start putting out 90-95 degree air...and also that an initial smell from heating coils was likely. Well, there was no smell and the air flowing from the vents after 15 minutes was still only 80-85deg. Was my inspector correct in that the heating coils should have kicked in and blown 90+deg air or does this system "know" that it's 80deg outside and won't heat the coils no matter what? Also, if it is a problem, what is likely to be the cause and remedy?
  • 10,865 Answers
Your home inspector is bonded and required to stand behind his work. That being said, it appears that your heating unit is inadequate. Therefore, you should tell your realtor that you want a new heating system installed as part of the sale.
Call your inspector and ask him how you should proceed. You hired him to work for you and give you sound technical advise. If he is not doing these things for you, call an attorney.
Posted on Feb 14, 2009
New Bryant. Why isn't it heating home well?
The furnace capacity could be inadequate
Your home could have a serious cold air infiltration problem
Your home could have inadequate insulation
If the new furnace was installed and the old thermostat was not replaced, it may be the source of the slow heating
If the new furnace was connected to existing ducts, they may be inadequate. This could account for the loud fan
Dec 25, 2015 | Heating & Cooling
Cool air from home vents with central AC outdoor unit fan will not turn on. Inside home really loud when on!!
its look like blower problem , 1st check blower speed controller, check blower motor , check its ball bearing etc , its does not have any link to external unit .
Jun 15, 2014 | Goodman Heating & Cooling
Goodman Model # GMC070-4b
is the thermostat set for heat and you have power going to the unit correct
Jun 05, 2017 | Goodman GMS90703BXA Heater
I have a Goodman GSC130361DE it is too small for a 2100sq ft home
Well you have a 3 ton system, it might be a tick small depending on windows and insulation in the house. Make sure you set it at one temp and leave it. Zoneing would also help.
Jul 17, 2010 | Goodman CLQ30AR32 Air Conditioner
Goodman furnace model # GMNT100-4B On vacation neighbor checked house house filled with gas. He shut off main and furnace. Came home turned on gas to everything except furnace. All good. Furnace will not...
from my experience with goodman units ,it could have been a gas supply problem there are so many protective sensors that i dont think it is the unit by the way is it electronic ignitor or pilot
May 14, 2010 | Goodman GMS90703BXA Heater
Adjusting goodman propane burners
Yellow flame can also mean inadequate gas pressure. Do you have a manometer? If not, call your gas company for a check.
Oct 09, 2008 | Goodman GMS90703BXA Heater
Purchased Goodman 5 ton unit in 2007. The problem we are having is: When you turn the unit on and set it at 76deg. the temp states on the controller it set at 81 deg in the house, BUT it would not cool...
Your system could have lost its refrigerant charge through a leak. Check for visual signs of oil at any soldered joints. This would indicate a leak at a point where some oil is visible. Also check for frost on the big line that returns to the outside unit. If frost is present set you air circulation fan to the on position and turn the cooling to off. Allow the air to circulate for about an hour. Then return the system to the cooling mode. Operate the system when cooling with the fan in the on position in this case.
May 24, 2008 | Goodman Heating & Cooling
Ruud centeal electric
Is this an older gas heat unit? If so, you may have a burnt out heat exchanger, this can be dangerous.
Dec 10, 2007 | Heating & Cooling
Goodman CKL49AR49 Air Conditioner Logo
77 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
