Question about Teac CD-X8 CD Shelf System
Connector cable Where can I get a replacement cable? The little pins are all bent and I need a new one \
  • dsweet Oct 21, 2008
    Thanks, so much.
I too had this problem. The ONLY place I could find it, after extensive searching, was directly from the manufacturer. I was sure I could find it used or something somewhere cheaper, but could not find it anywhere. I emailed parts@teac.com and they replied as follows:
It's a little expensive, but I guess not as expensive as replacing the whole system! Good luck!
Dear Customer,
The cable, is available at $25.90 each. Please add $4 for postage/freight per order for UPS ground service within CONTINENTAL USA plus local and state sales taxes where applicable. Prices quoted are only for SHIPMENT WITHIN THE U.S. or its territories.
We are required to collect state sales tax for residents of Arizona, California, Connecticut, Florida, Georgia, Illinois, Virginia, Maryland, Massachusetts, Michigan, New Jersey, New York, North Carolina, Ohio, Pennsylvania, Texas, Tennessee, Washington, Minnesota and others, regardless of shipping point. If you do not want us to collect state sales tax by adding it to your order, we must have a COPY of your resale or tax exempt certificate at the time the order is placed.
Please, NO CODs or PERSONAL CHECKS, but we can accept Visa, MasterCard, American Express, or money orders. There is a $10 minimum for credit card orders.
When you place your order, please include a copy of this response, your name, a U.S. shipping address, and day-time telephone number.
Parts Department
TEAC America
7733 Telegraph Road
Montebello, CA 90640
Phone: 323-727-4840
Fax: 323-727-7632
E-Mail: parts@teac.com
http://www.teac.com
http://www.tascam.com
Posted on Aug 12, 2008
The cord is called a mini din 9 pin, male to male connector.
you can get from IEC (They'll make it how many inches or feet you want it (800-765-4432).
Posted on Jan 29, 2010
I picked up a second cdx8 for free from someone who was moving. Unfortunately the cable was missing. I'd like to find one too. Have you had any luck finding a new cable?
Posted on Jul 30, 2008
As of yet, no one has steered me in any directions.
My emachine monitor keep saying no singale
May be a bad pin (bent over or missing) on your monitor cable to the video jack on your computer. If a bent pin, you can straighten it with small needle nose pliers; VERY SLOWLY--fast moves can fracture the pin and break it. If a pin is missing (broken off), the connector must be replaced. If connector looks good, and is not a molded, but a soldered type, a broken solder joint can be repaired, If it is a molded cable, the entire cable must be replaced.
I focused on the cable because this is the most common cause of "no signal", and further troubleshooting would be 'involved', to say the least.
Mar 01, 2013 | Computers & Internet
Tip
How to troubleshoot a system that boots up but wont display
  • VGA cable replacement
  • Needle-nose pliers
  1. Power downthe computer. Check the VGA cable running from the computer to the monitor. If the cable is not snugly seated in both ports, the video signal will not reach the monitor.
  2. Check the connector on each end of the VGA cable. Examine the nine pins on each connector. If any of the pins are bent or broken, the video signal will not reach the monitor. If there are just a few bent pins, you maybe able to straighten them with a pair of needle-nose pliers. Be careful not to break off any of the pins. If any of the pins are broke nor missing, you will need to replace the VGA cable with a new one.
  3. Disconnect all cables and peripherals from the computer. Open the computer case by removing the Phillips screws along the side or back of the case. Remove the cover or side panel to expose the internal components. Locate the VGA card and make sure it is fully inserted into the PCI card slot. If the card is not installed correctly, the video signal will not reach the monitor.
  4. Close the case, reconnect the power cord and all cables, and power up the computer. The video signal should display on your monitor.
on Jan 17, 2011 | Computers & Internet
No signal on computer moniter
1. Check your cable
2. check your cable pins make sure there not bent.
3. Check your video card make sure its putting out the correct resolution for the monitor.
No signal is just what it is. You may have a bad cable,bent pin or video card is not operational.
Things you can try.
Hook it up to a diffrent computer
Check the pins on the cable.
Worse case would be the little board inside where the connector is could be bad.
Thanks I hope this helps
Dec 07, 2009 | Acer AL1715 17" LCD Monitor
Need a replacement screen, its cracked any chance on getting a replacement, is it worth replacing?
Hey how are you!!!
What is your unit? If your unit is a laptop ou need to follow this.
You replaced the broken LCD screen in your laptop with a new screen. Does this sound like your problem? Let’s find out what could be wrong and how you can fix it.
First of all, I assume that your new LCD screen is compatible with the old one. Different screens require different video cables. Make sure you new screen is compatible with your laptop.
OK, let’s say you accidentally damaged the LCD screen in your laptop. A part of the screen still works fine but you cannot use it like that so you decided to replace the screen yourself.
Her is some instructions to follow.
Before you start to panic, check all cable connections again. Check connection between the video cable, LCD screen and inverter board. Reconnect cables just in case.
Take a closer look at the connection between the video cable and LCD screen. It’s possible you accidentally pulled the video cable from the connector during the screen installation.
The video cable has to be seated properly, all the way down.
Also, on some older LCD screens there are very thin pins inside the connector. Take a look inside the connector, make sure there are no damaged (bent) pins.
You can straighten bent pins with a very small screwdriver but this procedure requires a lot of patience and concentration.
Fortunately, most newer LCD's have a different type of connector, without fragile pins inside.
OK, you have reseated all connectors and cannot see anything wrong but the new screen still is not working. What’s next?
Remove the new screen and connect the old one. If the old one works properly (except the damaged area) but the new one is dead, apparently the new screen is defective and has to be replaced.
Hopefully it has warranty.
Here’s another scenario. The new screen kinda works. You can see a very faint image but there is no back light.
If that’s the case, disconnect the new screen from the inverter board and plug in the old screen instead, as it shown on the picture below. If the back light inside the old screen lights up, apparently the new screen has defective back light lamp and has to be replaced.
Good luck
ICmanServer
Aug 14, 2009 | Memorex MM7000
Broken screen
Hey how are you!!!
screen-not-working-3.jpg Take a closer look at the connection between the video cable and LCD screen. It’s possible you accidentally pulled the video cable from the connector during the screen installation.
screen-not-working-4.jpg The video cable has to be seated properly, all the way down.
screen-not-working-5.jpg Also, on some older LCD screens there are very thin pins inside the connector. Take a look inside the connector, make sure there are no damaged (bent) pins.
Fortunately, most newer LCDs have a different type of connector, without fragile pins inside.
screen-not-working-6.jpg OK, you have reseated all connectors and cannot see anything wrong but the new screen still is not working. What’s next?
Here’s another scenario. The new screen kinda works. You can see a very faint image but there is no backlight.
If that’s the case, disconnect the new screen from the inverter board and plug in the old screen instead, as it shown on the picture below. If the backlight inside the old screen lights up, apparently the new screen has defective backlight lamp and has to be replaced.
Good luck
ICmanServer
Aug 01, 2009 | Acer Computers & Internet
Bent pin in USB connector
call sandisk technical support. :D if its the pin of the player not the cable call them if its the cable try purchasing a new one there are lots of electronic shops out there.
Jul 28, 2007 | SanDisk Sansa e250 MP3 Player
Monitor connector bent pin
It is quite easy to straighten these pins, however the pins are quite brittle, and do not suffer bending too many times (they just snap) Does this cable unscrew at the monitor end? if you have straightened the pin on the cable but are worried that it may be a little weak on that end, swap the ends of the cable round and use the other end to plug into your computer (as it will be stronger) Also if the cable unplugs at the monitor end it can be replaced with a cable of the same type, available from most computer stockists, just take the broken cable with you for comparison Gareth
Jul 26, 2007 | MPC Computers Envision EN 5100e 15" Flat...
Teac CD-X8 CD Shelf System Logo
934 people viewed this question
Top Teac Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Teac Audio Player and Recorder Expert? Answer questions, earn points and help others
