Maxon Cinema 4D R10.5 Full Version for PC  Logo
Posted on Jan 24, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
If my ram is 2 gb. and 256 built-in video .. ?? it is ok?
fanaudi
Level 3:
  • Master 1,381 Answers
  • Posted on Jan 24, 2011
fanaudi
Master
Level 3:
Answers
1381
Questions
0
Helped
294810
Points
4199
Hi ,
They don't tell us what the minimum requirements are for the CPU :
http://www.maxon.net/en/products.html
You seem to be fine with your machine but you need a powerfull PCU , at least a Pentium 4 at 3GHz regardless of the new I5 or I7 more reliable series .
I wish you lots of pleasure with your new software !
Best regards .
My ram is 256 and how to upgrade to one gb ecs p4vmm2 intel r celeron
Hello here is the homepage:
http://www.ecs.com.tw/ECSWebSite/Product/Product_Detail.aspx?CategoryID=1&DetailID=436&DetailName=Feature&MenuID=24&LanID=0
Your mainboard supports:
2 DDR DIMMs
Supports DDR266 / DDR200
Max. 2GB
You can easy add 2, 1gb modules.
I recommend 2 gb ram.
Good luck
Is there a way the memory in a toshiba satellite 1005-s157 be increased to more than 512MB?
Yes you can, at least to 1 Gb maybe possibly to 2 Gb.
There will be two memory slots in your laptop. To increase the RAM to 1 Gb install another 512 Mb RAM module in the empty 2nd memory slot. Make sure you use the same make and speed RAM as the one that is installed.
If you have two 256 Mb RAM modules installed in your laptop then you need to replace the two 256 Mb RAM modules with two 512 Mb RAM modules to get a total of 1 Gb RAM.
4answers
I upgraded my RAM to 1 Gig but it's still showing only 256 meg. Why?
Hi this model sopport 2Gig Memory Ram.
RAM Technology DDR SDRAM Installed RAM 512 MB Max Supported RAM 2 GB Number of Memory Slots 2 x DIMMs Supported RAM Speeds 400 MHz • 333 MHz Installed Cache Memory 256 KB
Please check in to your Bios system maybe share memory Video or capacity is setting
1helpful
I have AMD Sempron 140 on ASUS M2N68-AM SE2 motherboard, Strontium 1GB PC800 DDR2 RAM. But in system properties, the RAM is showing as 768 MB instead of 1024 MB (WinXP 32 bit). The dealer is saying the RAM...
Yes the dealer is correct that the 256 MB of your RAM is allocated to the video card of this computer since the unit has a built in NVIDIA GeForce 7025 Shared video memory (UMA)that uses 256 MB of your RAM , so if you like to maximize the use of your RAM you need to install a expansion video card.
Computer beeps six times after installing new game. Precision workstation 670. Ram sticks are a 1GB each. My old ram works fine with the computer.
You need the EXACT speed rated RAM.
Your support page states it needs.....
400-MHz DDR2 SDRAM
NOTE: Your computer supports only registered memory
Memory capacities
256-MB, 512-MB, 1-GB, 2-GB, and 4-GB ECC
256-MB, 512-MB, 1-GB, 2-GB, and 4-GB ECC modules to a max of 16GB
more info here
http://support.dell.com/support/edocs/systems/ws470/en/ug_en/about.htm
Big city rigs
first check if your computer answers the following requirements:
Windows® XP/Vista
Minimum Requirements:
  • Pentium® 1.7 GHz or similar processor
  • 512 MB RAM
  • DirectX® Compatible Video Card
  • 128 MB Video RAM
  • DirectX® 9.0c
  • 2 GB Hard Drive Space
  • Mouse
Recommended Requirements:
  • Pentium® IV 2 GHz or similar processor
  • 512 MB RAM
  • 3D Video Card with at least 256 MB Video RAM
  • DirectX® 9.0c
  • Mouse
if you do, please tell me exactly what happens when you try to install the game
Burned RAM
just remove the 256mb ram it is the main problem only insert equal memmory of rams in 2 slots, if u insert 1gb ram in one slot try to insert also 1gb ram in other slot, donot inser 2 unequal rams in one time
What kind of video card do I need for Jetfighter 2015?
you need video card that supports directx 9..You should be fine with having 256 RAM.
Ram Sharing
there is a hardware compatibility list for all pc, chances are your pc have exceeded its maximum allowance for any upgrade, even though you have installed a higher value or capacity of RAM.
try reinstaaling once again and make sure you have the right speed allocation on your RAM , make sure that the ols RAM and the new one has the same PC___
RAM
your laptop has:
PCs built for Windows XP normally can handle 1 GB to 2 GB of memory.
PCs built for Windows Vista normally can handle 2 GB to 4 GB of memory.
This is what you need and the pricing is there too.
http://www.ec.kingston.com/ecom/configurator_new/modelsinfo.asp?SysID=20209&mfr=HP%2FCompaq&model=Presario+Notebook+V2000+Series+%28CTO%29&root=us&LinkBack=http%3A%2F%2Fwww.kingston.com&Sys=20209-HP%2FCompaq-Presario+Notebook+V2000+Series+%28CTO%29&distributor=0&submit1=Search
Here is the service manual
http://h10032.www1.hp.com/ctg/Manual/c00568473.pdf
Let me know how you make out.
Top Maxon Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a Maxon Computer and Internet Expert? Answer questions, earn points and help others
