Question about Samsung Digimax A7 Digital Camera
Solution for lense stuck problem
What spray silicone did you use - it must be worth a try
  • Trancesgirl Aug 04, 2008
    hank you have tracked a supplier so will try it. Thanks
    Problem Solver:
  • 4 Answers
Hey there, I used pure silicone spray. You can find them in most DIY/electronic stores.
I think Maplins might sell it.
Posted on Aug 04, 2008
I have a 91 bravada. The drivers side window is stuck open about an inch. I can move the other windows up and down but only about 2 inches. How do I fix this?
Have you tried spraying the channels the glass slides in with Silicone spray lubricant? Do that but keep it off any plastic tor trim.
Sep 12, 2016 | 1991 Oldsmobile Bravada
Trunk door stuck
try spraying silicon lubricant spray in to your key hole. use the straw applicator that comes with the silicon liquid spray. Insert the key and pull the key out of the key hole. Repeat several times then try turning the key lock.
Dec 04, 2012 | 1999 Ford Expedition
I have an elna 1010. It seems to be stuck in reverse, and I can't get it to go forwards. Can you help me?
try spraying some wd-40 or silicon spray on the reverse button or lever & let it set for awhile & try to work it
Nov 23, 2010 | Elna 1010
Red pull hubs are stuck so I cannot adjust the rack to a different car. Any suggestions on getting those to loosen up.
I'm having the same problem! Did you ever find a solution? I was thinking of taking the whole rack apart.
May 30, 2010 | Yakima Little Joe 3 Bike Rack
Digital camera zoom error
I had this problem with my Fujifilm E900 under warranty, and Fuji replaced the zoom mechanism. Nine months later, this past weekend, the same problem occurred. I appear to have solved it by gently but persistently wiggling the lens into a fully zoomed-out position, applying silicone spray to the lens barrel such that some of it dripped down into the space between the lens and the camera body and between the two parts of the lens barrel, and then repeatedly turning the camera on and off, wiggling the lens barrel, until it began to move freely again. Then I zoomed in and out until the silicone spray appeared to be dry. So far, I've tried zooming it in and out about 50 times in a row, with no problems.
The clue, to me, that this might work is that the spray initially seeme to make the problem worse. That meant it was getting to the gear mechanism. Once the solvent part of the spray dried, it wall worked smoothly.
Aug 17, 2009 | Fuji FinePix A350 Digital Camera
Front lens shade hangs up when camera is turn on but closes properly when camera is turned off. DSC-W80
cover lense with toilet paper spray silicon oil on cover(you can buy at walmart in auto parts section)and mechanism,if you get on lense clean with rubbing alcohol and qtip and soft white t-shirt!!!! :)
Jul 06, 2009 | Sony Cyber-shot DSC-W80 Digital Camera
Power button
If it is the plastic button that is down and won't return, you might try using some silicone lubricant available from hardware or auto parts stores. Silicone is a dielectric so it won't bother the electronics and might free the button.  I wouldn't recommend spraying the pressurized lube into the button recess but rather into the spray can's cap and then using a denuded Q-tip to dab a few drops around the periphery of the button. The carrier of the lubricant may attack plastic but is very volatile so you can let that part evaporate leaving only the silicone.
Oct 01, 2008 | Compaq Presario X1000 Notebook
Camera lense/power
The following blog outlines some repair options for a lens error. They won't work for all cases, but they're worth a try if the camera's no longer under warranty:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
May 18, 2008 | Canon PowerShot A510 Digital Camera
Nikon Coolpix L3 51 megapixels lense error
You may not be able to... but may be worth a try.
See my posts on this problem.
Mar 27, 2008 | Nikon COOLPIX L3 Digital Camera
Samsung Digimax A7 Digital Camera Logo
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Samsung Camera Expert? Answer questions, earn points and help others
