Question about JVC AV-36950 TV
Jvc 36 inch av-36890
Replaced bad ic str 5708 in power sup.Now tv will not blow fuse any more,but soon as it is plug to power keeps starting and shuting!
  • 1 more comment
  • zemba5002 Jul 17, 2008
    Does not working!
    I left tv off for day still same problem
    I do not know need double chek board and let you know.Need some time!
  • 2,326 Answers
Do you have the service manual?
Have you measure the output voltage(s)?
If you are getting the voltages at the output, you should check and test the HOT.
Click here to download the data sheet for the STR-5708 IC.
Posted on Jul 17, 2008
  • 97 Answers
Sounds lke power connection failure, remove ac cord, leave for a while, try moving the tv around a bit just incase the cords touch in the tv. if error still persists. please call a technician do play with live wires. hope th works. bye
    Sergeant:
    Champion:
  • 417 Answers
Sounds Like Connection Failure
    Guru:
  • 1,894 Answers
If power keeps starting and shutting it means that you have some serious shorting problem
there is some place in your board where some two terminals are getting shorted.
please check it out
  • dewan nafees ahmed Jul 17, 2008
    in this condition it is advisable NOT TO TURN ON THE UNIT
    now open the unit and check for the shorting. it may be even in some small corner where any screw was left unnoticed. or else it can be any problem.
    but if you keep turning on the unit now it can lead to even worst repairs.
    so please solve the problem and then start the unit
    please don't forget to accept the solution.
    thank you
    have a great day
    Master:
  • 382 Answers
Try to hard reset which is, the set must be unplugged for 30 minutes then it can be turned back on again.This is the common case of history found in av-36890..Dont worry!!..If it doesnot work try to call a service person for further assistance!..
Please reply back for how things turned on and if you need further assistance..Thank you!!..Regards!!..
    Master:
  • 497 Answers
Remove the AC cord from the back of the tv for 3 mins and reconnect
hope this wrks
NEED AN OWNERS MANUAL FOR JVC MODEL AV-36890 TV, NO REMOTE
I've tried looking for an owner's manual for you, but to no avail. If you are looking for a replacement remote you can follow this link to http://ezremotefinder.com which will get you a list of remotes for sale that are compatible with the JVC AV-36890 TV. Here is a link to the search results for the JVC AV-36890 replacement remote:
Looking for that lost remote control
Best of luck to you!
Feb 29, 2016 | JVC Televison & Video
JVC AV-36D502 36
Check and replace the chroma IC.
Aug 13, 2012 | JVC AV-36D502 36" TV
In my tv fuse is blowing off immediately
Hello
If fuse blows off immediately, i means that there is a short circuit occured in your telivision. This can mainly due to some diodes or regulators inside your tv. An overvoltage, spikes, ie [sudden high rise and go low], in the supply votage in your home, could damage power supply regulator components inside your tv.
All Sony Tvs has high accuracy power regulating systems inside. It is an onboard assembly, usually take 1/4th of the area of the TV. In older Sony TVs, this section was built in with use of transistors of different types. But your tv is not so old, so its power supply system is built with an STR, an Ic meant only for power regulations. Normally it willb numbered STR S6707, STR S6703 etc; according th the working voltage of the main board, and screen size of the TV.
This STR may get shorted due to power fluctuations, or any other reasons. A I mentioned above this is an Ic look like small squuare biscut of about an inch in square, and will be black in colour.
The rectified main power supply is given to it via an SMPS transformer [Swiched Mode Transformer], and the Ic will swictch it on and off at the rate of sbout 25KHz or more, and this transformeres secondary voltage is used to power up the other part of the ciiruit board.
If the fuse is blowing as soon as the set is switched on, this Ic will be faulty [Shorted inside]. If you put an another fuse, it also will blow up due to short. It is not good to play with power supply system by doing this as it may harm to other components also.
You have done it I thinks. Here in India, we gets 220VAC as home power supply. Sony TVs used here have a fuse rateing of 250V 3.5Amps. If your household supply system voltage is also this you must put only this rated fuse. If it is 110 or 120VAC, the fuse rating may differ; and will go upto 6 to7 Amps. More than this rated fuse should not be used.
You just do one thing. Just open the back cover of the TV, locate the power regulator section, and chech whether any main rectifier diodes for leak. There may four of them. In some sony Tvs, rectifier stalks are used. Check it for leak. If thery are all good, measure the resistance across the main filter capacitor with a multimeter set in Ohms range. If the STR said above is short, the meter will give full scale deflection. Unsoder the STR and pick it out after loosing its fixing screws to the heat sink. Again check the resistance accross the main filter capacitor. It must sho a low deflection or no deflection at all. Never replace the STR with a new one as there may be some other faulty components in that section. Usually when STR fails, there are some Zener diodes, Wire wound resistor etc will also gets shrted. If you replce the STR before checking them for fault, the STR you puts in will get shorted as you swich on the set. It will take just 1/100 part of a second.
So check all the components related with power regulator system, and then only repace the regulator. Caution: Keep chlidren away from you while you open the tv. Never touch any part of the circuit board while power supply is there. Plug out from the wall socket each time you touch the printed circuit board. As your Tv screen size is 32", an approximate of 25KVDC [15,000VDC], will be present at the first anode of the picture tube while it is working. It is too dagerous to contact.
If you haven't through knoledge, skill and patience, never try to repair it. If you knows to follow its schematic digram, buy one book and follow the circuit.
Keep an adult beside you as you try to repair your set, as a precaution.
If you have any doubt, report to Fixya, they will give me alert. Ok
Oct 20, 2010 | Sony FD Trinitron WEGA KV-32FS120 32" TV
JVC AV-36D502: Input #3 doesn't work
Good day sir, its a different issue, about the capacitor, for as long as your replacement part is correct, it will work, now, there are several things you should check, the I/O device that controls the inputs of the TV, usually an IC, check your schematic diagram to trace the fault. check also the line from the input 3 to the controller IC on your diagram. Measure the voltage across the IC Vcc to ground if the IC is getting the right power, Low voltage can be cause by faulty capacitors, on the power supply line, or the IC itself is faulty, Circuit analysis and voltage measurements are needed to trace the faulty part. hope this helps thanks.
Oct 23, 2009 | JVC AV-36D502 36" TV
Symphonic WF 13 keeps blowing fuse as soon as I plug it in.
Probably your power supply circuit has shorted, check the rectifier diodes, STR IC, Transistor, and Degaussing circuit.
Jun 02, 2009 | Symphonic ST419E TV
JVC AV-36870- After watching for awhile, screen goes blue and sound squeals
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts.
Oct 14, 2017 | JVC AV-36890 36" TV
Tv wont turn on
This is a general failure indicator and can be anything from a blown fuse to a bad power supply/vertical IC/lightning strike.
There are 2 fuses, check/replace both. if they blow again, check for physical damage to the vertical IC LA7832. If its cracked or had a hole in it , you are going to need to take it in for service.
May 18, 2008 | JVC AV-27720 27" TV
Jvc av-48wp55
Replace the IC power STR.s6709 and
Nov 20, 2007 | JVC AV-48WP30 48" Rear Projection...
TV PICTURE DOES NOT COME ON, OR NO SOUND
check the bu transister in the horizantel stage and see if it has any voltage reaching there. if not. take the transister and check it out. I think it is needed to be replaced. good luck
Mar 22, 2007 | JVC AV-36890 36" TV
JVC AV-36950 TV Logo
140 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
