Question about Samsung HCP5252W 52 in. Rear Projection HDTV-Ready Television
Power Supply for TV
Hello, I am assuming that my power supply went out in my tv..it started sparking in hte back for no apparent reason and not it wont turn on it is only 4 yrs old how do I find that part # so I can replace it..is it easy to do?
thanks,
Pamela
  • SSexyAzz Jul 17, 2008
    WOW you guys ROCK...that was Quick....thanks I will give it a try....
    Pamela
  • Samsung Master
  • 8,617 Answers
You need the P59A power deflection board. You can get one at the foloowing link and they have free tech support with instant messageing to help you install the new board properly. Heres the link.
http://servicemanuals.vstore.ca/
Posted on Jul 17, 2008
  • Sonny Berry
    Sonny Berry Jul 17, 2008
    Glad I could help.
Hitachi hd 1080 tv
its seem to be a surge apparently at one time tv had gotten a voltage spike may have blown the fuse in the power supply or main board.
Aug 12, 2013 | Televison & Video
Tv went off won't come back on
Common problem with this TV is the power supply module.
Check the power supply; look for bad caps with leaking/bulging tops, check to see if you have standby +5vdc at the power supply connector, the front red indicator will not be on if you do not have this +5vdc standby voltage due to shorted out power transistor and zener diode, If otherwise you contact the manufacturer or a skilled qualified personnel to handle the fault..
Hoping that will help to solve the problem....
Jun 14, 2011 | Vizio L32 32 in. LCD HDTV
Switch on the iron infront of the TV and a large spark and bang came from the right hand bottom corner. POwer went off and the TV doesnt work. Not sure if its repairable or better to purchase another...
Now tv turn on,u still have power and LED power light indication flashes?Yes this tv is repairable the tv power supply board is the causes and problems,that the board where the power a/c cord plug into it,can u take things aparts and putting it back again?Try website like Ebay.com to buy a refurbish power supply board for the replacememt.
Jan 31, 2011 | Hitachi 42PD380TA 42 in. EDTV-Ready Plasma...
Samsung 58" plasma pop spark no picture
Hi
A common problem for these is bad capacitors in the power supply, Remove the back from your Tv and look at the power supply on the left hand side.
You will see roughly around 9 x capacitors that are bulged / domed shaped on top usually these are valued at 3300uf 10V any that have bulged or leaked a brown like substance should be changed.
This will cure the problem as they overheat being sat next to a heatsink that gets very hot!
Try and change them for the same 3300uf but a higher voltage.
Hope this helps
Jul 02, 2010 | Samsung PN58B650 TV
Polaroid went off and wont come back on
hello,
Power supply board have problems,just not dead yet.Replaced the power supply board,will solved this problems.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Good luck...
May 29, 2010 | Polaroid FLM-4201 42 in. LCD Television
When i turn on the tv the yellow logo turns white but nothing on screen
hello,
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} sounds like your vertical circuit was going bad then might have overheated and killed hte power supply, Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} tries websites like Shopjimmy.com,Ebay.com to buy a whole rerfurbish power supply board for the replacement
Good luck :)
May 25, 2010 | Vizio P2 42 in. HD-Ready Plasma Television
Image quality problem
Check the power supply part no. matching. If there is adjustment potentiometer for the supply voltages try adjusting to the required level of the voltage.
Apr 30, 2010 | Panasonic Viera TH-50PZ85U Plasma TV
50 inch Plasma problem
Most likely a capacitor in the power supply went out. otherwise it may be a bad relay if there happens to be one.
Most reason for a tv not turning on at all is bad power supply
Aug 01, 2009 | Sony Grand WEGA KDF-60WF655 60" Rear...
Tv does not turn on
When you are technically Qualified only then you shoul solve this problem. because this problem may be because of power supply. Ok you must check power output on diode rectifier if it is ok then check the mains chord,which is directely connected to AC supply. And Then check the VC i.e. Volume Controle wire. your TV Set may be on Good Day Friend. And BE councious when you work with AC /DC Power supply or after opening the TV Set.
Jun 10, 2008 | Televison & Video
Open Questions:
See all Samsung HCP5252W 52 in. Rear Projection HDTV-Ready Questions
Samsung HCP5252W 52 in. Rear Projection HDTV-Ready Television Logo
46 people viewed this question
Jerry Greenberg
Jerry Greenberg
