Question about Panasonic Televison & Video
Panasonic DVD and video recorder. If the unit has not been plugged in for over ten or fifteen minutes, it will power on when the power button is pushed. After about two times of that working, the unit will not power on until you press and hold the power button for approximately ten seconds, release it, and then push the power button. After that method working for several times, the unit has to be unplugged for ten or fifteen minutes to reset, at which time pushing the power button will turn the unit on. Then the above-detailed cycle repeats.
  • hrngffcr Aug 11, 2008
    It was not the power source, it was the microprocessor, according to a local repair shop. He said it would cost $80 or more to repair, IF he could even find the parts.
    Scholar:
  • 101 Answers
Interesting problem. It is probably caused by bad electrolytic capacitors in the power supply. Have you checked if it is still under warranty? If it's not, and if you are comfortable with soldering, you may be able to fix it by soldering in new electrolytic capacitors, looks for bulging or leaking capacitors near where the power cable comes into the unit. Otherwise you may just have to send it in the be repaired.
Here is the support site.
Hope this helps.
Posted on Jul 17, 2008
    Guru:
  • 1,894 Answers
This is a sign of bad capacitors getting dead in your power board.
please replace it as soon as possible.
else the problem cay get worse
    Master:
  • 497 Answers
Check if the front panel circuit board contacts and left and right chassis motherboard contacts are correctly aligned
  • Yaz  S
    Yaz S Jul 17, 2008
    and also turning off the EPG Auto Update in the menu is a temporary fix
    Thanks for using Fixya
    do update us
    Master:
  • 726 Answers
Seems like a power issue due to over heating for some reason
  • 97 Answers
You hav a power issue. replace the power box now while its cheap. hope that fixed ya.
Panasonic dmr-es40v
Ron, F60 is a general error code usually related to a failure on the video processing board. You could fix this by just replacing that board. Try to place it in standby mode first by unplugging it, wait a couple of minutes and then plug it back in. When the 000000's starts, hold down the power button for 15-20seconds. The unit should then be in standby mode. From this mode try to start it normally using the power button and see if it cleared the error. You could also try a complete reset by powering the unit off and press and hold the "Stop" and "Channel Up" buttons at the same time for a few seconds while powering the unit up. Hope this helps, good luck.
Jul 08, 2016 | Panasonic DMR-ES40VS DVD Recorder/VCR
I have a LVC-9016 combo..It does not record now..will give a protected content response regardless of disc.
Try unplugging power cord for ten or fifteen minutes, if this does not help try using a cleaner CD.
Sep 11, 2008 | Lite On Televison & Video
Panasonic 1080p DVD Recorder flashes "Hello" cannot turn off, eject DVD, play or anything
I just had this problem the other day. Unplug the unit for 2 minutes. When you plug it back in and get a the 000 press the power button for about 5 seconds and that will put it back in stand by mode. Hit the DVD open button instead of the power button. Hope this helps
Aug 03, 2015 | Panasonic Televison & Video
Ihave dmr-e55 it records advd for 5 minutes and it goes to self check
1) Press and keep [POWER] button on the unit for more than 10 seconds
to turn off the power of the unit.
2) Unplug power cord and wait for approx. 1 minute.
3) Plug power cord in.
4) The display shows [RECOVER] or [SELF CHECK] and it becomes under
recovery. Wait till the message on display disappears.
*When the unit does not recover after taking above procedures (1 to
4), it is needed to be checked and repaired.
Mar 25, 2010 | Panasonic DMR-E55 DVD Recorder
Panasonic dmr-es35v dvd/vcr recorder reads hello, then u61, then
Plug AC power cord to wall electric socket if it is plugged into a surge protector or extension, if not try a different socket, if issue still exist have unit service.
Sep 20, 2009 | Panasonic DMR-EZ47V DVD Recorder/VCR
PANASONIC DMR-ES35V have error code U61
From User guide:
U61 • There was a power failure or the AC plug was disconnected while the unit was on. The unit is carrying out its recovery process. This process restores the unit to normal operation. The unit is not broken. Wait until the message disappears.
If fail unplug and hold power button for a minute or two and turn it on and repeat.
Feb 26, 2009 | Panasonic DMRES15 DVD Recorder
F60 Error message on DMR-ES40V unit
Unplug the unit.
Plug back in and wait till you see 000000.
Press and hold the power button in at least ten seconds or until the clock shows up.
This worked to fix mine.
Jan 05, 2009 | Panasonic DMR-ES40V DVD-Video Recorder
Defect
Tarlach.
I had similar trouble & searched web & found answer. Caused by PSU (power supply unit) overheating. IC STR-G6353 was problem. Panasonic repair agent wanted $60 Aust. for one but found in electronic spare parts shop & cost $11 Aust. I replaced it myself & now works like new. Pls go to web site
http://www.avforums.com/forums/showthread.php?t=316972&page=9
This will show the problem & how to fix. regards
jhcollister@bigpond.com
May 05, 2008 | Panasonic DMR-E85H DVD Recorder
Remote control does not work at all.
The winner is....
SET 1 on the console; press and hold the ENTER button down and while holding Enter; press and hold "1" button for about ten seconds together. Your remote and console should be in sync again and try cutting off the dvd recorder with the remote and it should work.
THIS WORKED FOR ME!!!!
THANKS!
Feb 18, 2008 | Panasonic DMR-ES35VS
Televison & Video Logo
82 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
