Question about StarTech.com StarView SV211K 2-port KVM Switch
Inputting codes for sview 3 thebox
Can you tell me how to input codes into the remote please
    Scholar:
  • 135 Answers
Press menu on the remote
Ignore the menu, press the numbers 2007
Press OK on Nagravision
Choose your provider
Enter both keys 00 and 01, saving each key individually
Finished
It's important to have the latest update on your box as it will auto-update any key changes.
Posted on Jul 20, 2008
This is my universal remote control for the lg tv..i have tried all codes you have given but still the indicator red light blinks as i input the second number of the code.
HI NENITA, Did you try these codes--> 024, 040, 098
Setting Steps: Input Code
1.) Find out the 3-digit code for the TV that you need to control from the "Code list" In case there are several groups of codes available, please use the first group at first; in case that your TV brand has no matching code in the code list, please try the "Search For the Correct Code" mode described later.
2.) Press and hold the "Setting" button at first, then press the "Power" button. Release both buttons after the indicator light illuminates, indicating the status of code input; in case the indicator light is in other status, it indicates that it's yet to enter the code input status, and this step shall be repeated till the light illuminates.
3.) Input sequentially the 3-digit code that you have obtained. The indicator light flashes once when one digit is input. After the input of the code, the indicator light extinguishes; in case indicator light flashes twice successively, it indicates that your input is wrong and you need to input again.
Note: In case the indicator light keeps illuminating after two flashes, you only need to input the correct 3-digit code and do not repeat Step 2, otherwise Step shall be repeated for resetting.
4.) When the Indicator light extinguishes, the setting ends, then you can remotely control your TV with the remote controller.
Apr 17, 2016 | Universal Remote Control Televison & Video
Proscan tv input without remote
Without its remote control, you can't select the inputs. If you wish to buy its original remote control, contact the authorized service centre, or authorized dealer to your device brand.
To select a proper universal remote control, you should know about the number of digits to its set-up codes. There are 3 digit, 4 digit, 5 digit, 2 digit and even single digit codes, to some brand devices. After confirming this, check the sites linked here. Both the sites have set-up code list and set-up procedure to many popular brand remote controls. Check which brand remote control has set-up code/s to your device brand, and buy that one according to availability? Brand name of the remote control isn't a matter, but it should have set-up codes in its code list, to the device you have.
Please note: Every new universal remote control will have set-up code list, and set-up procedure along with its user manual. Never accept a remote control, that hasn't both of this. If you see the site by "MOSAIC" view, will make surf easier.
http://electrohelponline.blogspot.com/
Apr 03, 2014 | Durabrand DWT1905 TV
Kenwood ddx-7017 lock code
How to clear the Security Code
In adjusting K/R destination units, if the unit starts up with
Security ON, the Security Code can be cleared in the following
manner. (Other than in Test Mode)
1) In the e Security ON condition, after resetting or turning
power ON after backup OFF, then the session starts with
Security Code Input screen.
2) With the attached remote control in the Audio SW selected
condition, input the code with the following procedure.
Procedure 1: “K” input (Press Tenkey [5] 2 times)
Procedure 2: “C” input (Press Tenkey [2] 3 times)
Procedure 3: “A” input (Press Tenkey [2] once)
Procedure 4: “Q” input (Press Tenkey [7] 2 times)
Note: If a remote controller other than the attached is
used, Pressing Tenkey [7] twice will cause “R” to be input.
If a mistake is made during Procedure 1~4 above, input
other remote controller Key. Then, start inputting again
from Procedure 1.
3) Security Code is complete when the input screen for the
Security Code is cleared.
Aug 08, 2009 | Kenwood DDX7017 Car DVD Player
Can get all channels but there locked
rob, all the sview 4 usb boxes are down everything u have done is correct but chorus have comrimised this version of the box sview 1, 2 and 3 are still workin
May 29, 2009 | StarTech.com StarView SV211K 2-port KVM...
Eurovox codes dont know how to input them
press menu on your remote, then the yellow button. you will see at the bottom of your screen that it tells you how to imput letters that are in you code. once you have inputted your new code, press ok on remote, then exit and your channels will come back on. i have just done it and it is working ok.
cheers
pete (penguintigerlion)
Feb 01, 2009 | StarTech.com StarView SV211K 2-port KVM...
I have a kenwood kdc-mp7028 dont remmber the code
The procedure for clearing the code is below, but first you must understand that you must have the remote to do this procedure. Kenwood has designed these radios so that the only way to clear the code is by using the remote. I know this because I work at an authorized Kenwood service center and have done this procedure many times.
If you do not have a remote, or you can not buy or borrow one, the only other way to clear the code would be to take it to an authorized Kenwood service center and they will do it for a small fee. The shop I work at charges $25 for this, but it is up to each shop as to how much they want to charge.
Here is the procedure:
1. While “– – – –” is being displayed, press [ >>I ] key for at
least 3 seconds while pressing [AUTO] key.
This makes “– – – –” display disappear.
2. Using the remote controller, input “KCAR”.
Press remote controller [5] key 2 times (Input for “K”) and
then press [ >>I ] key.
Press remote controller [2] key 3 times (Input for “C”) and
Press remote controller [2] key once (Input for “A”) and then
press [ >>I ] key.
Press remote controller [7] key 2 times (Input for “R”) and
3. The security is released and the unit enters the STANDBY
mode.
4. If a wrong code is input, the unit goes into the Code Request
mode.
Since this is the only way and it is the correct way to clear the code, I would very much appreciate a FixYa! rating. It is the only reward we get for offering people like yourself this free information.
Let me know if you need any further help, like needing to know where you can buy a remote or whatever other questions you may have.
Dave
Nov 11, 2008 | Kenwood KDC-MP7028 CD Player
Unlock
You must have the remote to clear the security code. If you do not have a remote, this will not work and there is no other way to clear the code. If you do not have a remote you must either buy one or borrow one from a freind who has a kenwood radio. Most all of the remotes for the last 5 to 8 years will work. If you can not get a remote, you can take the radio's to a authorized Kenwood service center and they can clear the code for a reasonable cost. My shop charges $25, that should be about what other shops charge.
This first one is for the KDC-MP528
1. When you are requested to enter the security code, while
pressing down on [AUTO] key, use a long-press on >>I key
for 3 seconds. (----disappears.)
2. Using the remote controller, input “KCAR.”
Press remote controller [5] key 2 times and then press >>I
key. (Input for “K.”)
Press remote controller [2] key 3 times and then press >>I
key. (Input for “C.”)
Press remote controller [2] key once and then press >>I
key. (Input for “A.”)
Press remote controller [7] key 2 times and then press >>I
key. (Input for “R.”)
sourcing mode.
mode.
Now this is for the KDC-MP828
1. While “– – – –” is being displayed, press [>>I ] key for at
then press [>>I ] key.
press [>>I ] key.
mode.
mode.
A rating of "FixYa!" would be appreciated for this free information.
Thanks,
Dave
Jul 09, 2008 | Kenwood KDC-MP528 CD Player
Kenwood kdc-mp528
You must have the remote to clear the security code. It will not work by using the keys on the display. here is the method of clearing the code.
pressing down on [AUTO] key, use a long-press on "track forward >>I" key
Press remote controller [5] key 2 times and then press "track forward >>I" key. (Input for “K.”)
Press remote controller [2] key 3 times and then press "track forward >>I" key. (Input for “C.”)
Press remote controller [2] key once and then press "track forward >>I" key. (Input for “A.”)
Press remote controller [7] key 2 times and then press "track forward >>I" key. (Input for “R.”)
sourcing mode.
mode.
If you do not have a remote, you can take it to an authorized kenwood service center and they can do it for a small fee. My shop charges $25. Or you can order a remote from them and do it yourself, or borrow a remote from a friend who has a recent Kenwood model radio, they all work with it if the radio is new in the last 5 years or so.
Since this will clear the code if done properly, a rating of "FixYa" would be appreciated.
Thanks and let me know if you need any more help.
Dave
Jul 04, 2008 | Kenwood KDC-MP528 CD Player
Code Problem with a kenwood kdc-mp232 car audio
• How to clear the programmable security code (For models
of destination “K”)
∗ Operation 1
1. While “– – – –” is being displayed, press [->> ] key for 3
seconds or longer while pressing the [AUTO] key. This
makes the “– – – –” display disappear.
2. Input “KCAR”, using the remote controller.
Press [5] key of the remote controller twice (Input for “K”)
and press [->> ] key.
Press [2] key of the remote controller 3 times (Input for
“C”) and press [->> ] key.
Press [2] key of the remote controller once (Input for “A”)
Press [7] key of the remote controller twice (Input for “R”)
and press [ ->>] key.
3. The security is cleared and the unit enters STANDBY
source.
4. If wrong codes are input, “– – – –” will be displayed again.
Jan 03, 2008 | Kenwood KDC-516S CD Player
KCD-X590 is looking for a code that i never put in, and i bought the deck brand new
Method of clearing the programmable security
code (KDC-MP632U/X590)
1. While "– – – –" is being displayed, press [->> ] key for at
least 3 seconds while pressing [AUTO] or [TI] key.
This makes "– – – –" display disappear.
2. Using the remote controller, input "KCAR".
Press remote controller [5] key 2 times (Input for "K") and
then press [->> ] key.
Press remote controller [2] key 3 times (Input for "C") and
then press [ ->>] key.
Press remote controller [2] key once (Input for "A") and then
press [->> ] key.
Press remote controller [7] key 2 times (Input for "R") and
mode.
4. If a wrong code is input, the unit goes into the Code Re-quest
mode.
Oct 14, 2007 | Kenwood KDC-X590 CD Player
StarTech.com StarView SV211K 2-port KVM Switch Logo
71 people viewed this question
Top StarTech.com Computers & Internet Experts
Alun Cox
mbowen171
mbowen171
Are you a StarTech.com Computer and Internet Expert? Answer questions, earn points and help others
