Question about Canon imageRUNNER 2270 Copier
Scanning problem scanned few papers and converted into pdf. I scanned and sent to my email and never received it. I went back to check and it gave me a code NG. Do not know what that means. Please help. Melinda
  • 47 Answers
In simplest terms "NG" means No Good. What that means is, for whatever reason, the machine was unable to send the email.
The first question I would ask a customer is: Has it ever worked? And if the answer is yes then the second question is : What has changed? Many things can change in the background without you ever knowing.
The usual cause is the SMTP settings on the copier are not set correctly. The easiest way to check them is to log into the copiers web page by plugging its IP address into the address bar of your favorite web browser. Go to Admin Mode (the password should be "admin" unless its been changed) and then network settings. (the wording might be different but you'll find it). Verify your SMTP settings against your own email client account settings. If you use SMTP authentication then the copier needs a user name and password, if you dont then leave those fields blank. The copier does need a valid 'looking' "reply to:" address (even if it is fake, as long as it is formated correctly). Also make sure that the DNS server address field is properly populated as well as the domain name field and the default gateway.
If all this sounds greek to you then hand it off to your IT person. They should know what I am talking about.
Posted on Jul 18, 2008
I can"t scan to PDF
Hi
Use the Scan to PDF software to direct convert your scan page to PDF, download the software to click hear
and simple to install to this software, after installing you get the shortcut in your desktop double click that one and open your scaner is automatic install there put the document in scanner and click scan after scanning click save to PDF and give the save file name and save.
Nice one may it is resolve you problem.
Cheer
Jun 23, 2011 | HP Scanjet G2710 Flatbed Scanner
How do you setup your scanned documents to show up on my desktop as a pdf file?
  1. You can use A-PDF Image to PDF (free download here) to scan a document into PDF format and email it with only 2 steps:
    Click the "Scan paper" icon to scan documents from scanner
    Click the "Build to One PDF And Mail" icon to create a PDF document contains all of the scanne
    d documents and email them.
Jun 20, 2010 | Office Equipment & Supplies
Scan to pdf preview out of alignment
hey what you did is the best way, you have to save it first in your pc then attached it in your email.
May 10, 2010 | HP Officejet Pro L7680 All-In-One Printer
I have an MFC-7440N. When I scan to email, the image is a jpg. Can I convert it to a pdf before sending? (email recipients report that the image comes across very fuzzy).
You need to open up Control Control Center.
CLick on start, all programs, brother, and then control center 3. Once the program has openned, click on configuration and chose scan then email, you can change the file type to PDF from here and can actually make any other change you wish. Make the same changes in the device button tab.
Now everytimw you scan to email it will be in PDF format
Apr 15, 2010 | Brother MFC-7440N Laser Printer
How do you scan a paper to a PDF file on dell
Scansoft (or Nuance) PDF Converter 3 is a useful utility for converting documents to PDF files
Mar 02, 2010 | Dell 1815dn All-In-One Laser Printer
I seem to have a problem scanning on the KM C351. When scanning a multiple page document I recieve 1 .pdf file per page. This happens whether or not Seperate Scan is selected. Right now the scan are sent...
the file type is set to single page
1.press the scan button on the control panel
2.select scan setting.
3.select file type.
4.select multi page to have the entire scan to be sent as a single file.
if you are sending jpegs they can only be sent as single page files on this machine. only pdf's and tiffs can be sent as multi page files
Nov 13, 2009 | Konica Minolta bizhub C351 All-In-One...
Canon MX860 Scan to PDF 10 times bigger than source PDF file
My suggestion would be to check your scanning software and change the quality of the scan. If it is a document - you really don't need a quality above 200 - maybe even lower if it's available. I would guess your scanning software is defaulting to a much higher quality.
Sep 21, 2009 | Canon PIXMA MX860 OFFICE AIO-2.5IN LCD...
I cannot scan a document to a single email
file type is probably set to single page. to set the file type to multi page do the following:
1.press the scan button on the op panel
3.select file type
4.select multi page multi page to have the entire scan job sent as a single file.
if you are scanning jpeg as file type they will only scan as single page docs only pdf and tiff can be sent as multi page files
Sep 18, 2009 | Konica Minolta bizhub C250 All-In-One...
Huge pdf files
Try scanning a "photo" to file and using the advanced scan options to set a lower DPI. Then from the Library view you can convert that 'photo' (of a document) to PDF.
Steve
Sep 05, 2008 | Lexmark X7350 All-In-One InkJet Printer
Editable forms with Adobe reader?
With adobe profesional you can make a PDF form, and send to the recipients. They can fill the form with Adobe reader and send it to you back, but only the data will be sent to you, not all with the pdf.
You can collect the data with your adobe profesional. Your programmer of medical paperless system can make the program to put that data in your database.
Here is the simple procedure:
1. Create form: Open adobe prof, menu advance --> Form --> create new form. You will go to Adobe design to create the form, there you can also retrieve your scanned document.
Don't forget to put "submit button" and your email address.
2. Then save as pdf form. It is ready to be send to your recipients.
3. The recipients will fill the data and send to you by pushing the "submit button".
4. You will receive the data in your mailbox, as an attachment of email. You can use adobe prof to collect it, example to put it in Microsoft Excel.
Go to menu advance --> form --> Create Spreadsheet from data files. A dialog box will come out, put in the files you received from your recipients. then go on, you will have the Excel data.
For put it in your database of your system, your programmer should create a program/ included in your system's program.
For Guest, to fill up is easy, just open the pdf form with Adobe REader, fill it and click the submit button.
Apr 15, 2008 | Adobe Acrobat Professional 7.0 for PC
Canon imageRUNNER 2270 Copier Logo
307 people viewed this question
old marine
old marine
