Question about Lexmark Office Equipment & Supplies
Lexmark Z735 prints out green instead of black
5 Suggested Answers
ritamc101
  • 33 Answers
SOURCE: after my Z735 lexmark printer
The same thing happened to me once. Try looking near the cartridges, there might be an item stuck which makes it hard to print. When that happened to me, i noticed that there was a pencil stuck in mine. I ended taking it all apart in the end, but that is only because someone forced it in there. In the end, it worked!
Hope you get your working soon! =]
Posted on Dec 14, 2008
  • 2692 Answers
SOURCE: install lexmark z735 without cd using xp professional
http://downloads.lexmark.com/perl/downloads/downloads.cgi
Posted on Jan 07, 2009
billspeer
  • 180 Answers
http://downloads.lexmark.com/perl/downloads/downloads.cgi?ccs=229:1:0:0:0:0
This will take you to a webpage that will let you enter your model number. A few more clicks for your OS and you'll be taken to the option to download the file. Good luck. Let me know if you have any other needs or questions. Please rate me accordingly.
Posted on Feb 11, 2009
evolution210
  • 11 Answers
SOURCE: Epson Stylus Pro 4000 is printing green instead of black
Hi mariann346i am having the same problem with my EPSON RX 595 printer.
i can not print in black and white, it always prints in green.
i also notice something els, even after refilling my six cartridges
and only trying to print in black and white, my yellow ink is running out just as fast as my black so i guess they are somehow mixing together. you should check to make sure your yellow isn`t doing the same.
Posted on Sep 08, 2009
  • 8 Answers
SOURCE: lexmark z735 will not connect to my computer i
Try uninstalling and then reinstalling the printer.
Posted on Sep 11, 2009
Any black ink cartridges work on Lexmark z735 printer?
The cartridges compatible with this printer (at least within Europe) carry the code 18C0781 and are commonly know as the Lexmark 1 cartridge.
Dec 20, 2012 | Lexmark Z735 InkJet Printer
The blue light on my lexmark z735 printer is blinking. also when i go to print, it says there is a connection problem. any suggestions?
It could be a slight communication problem. Disconnect the printer from the pc. Reboot the pc. Open the printer cover and remove the cartridges. Close the cover. Unplug and replug the printer into the power source to reset it. When the printer turns on, reinsert the cartridges. Reconnect it to your computer. Try to print again.
May 25, 2011 | Lexmark Z735 InkJet Printer
When printing the black ink is too light.
hi
you may have to replace the black ink cartridge -- if thats not it, then you have to change the print properties, -- you have it set to DRAFT instead of FINE. set it to FINE and it will print with better resolution
hope this helps
Feb 02, 2011 | Lexmark Z735 InkJet Printer
Where can I find drivers for Lexmark z735?
Here's the link to the Lexmark Z735 drivers: http://bit.ly/bXI518. Available drivers are for Windows operating system only. If you're using Windows 7, you can use the Vista drivers. Thank you for choosing Lexmark.
Sep 15, 2010 | Lexmark Z735 InkJet Printer
Wats the cartrige number for lexmark Z735 printer
Follow this link to Lexmark's website. There is an extensive list of cartridges available for this printer and you gave no indication as to what you needed. http://www.lexmark.com/lexmark/product/home/725/0,6970,204816596_653399455_483733205_en,00.html?tabId=7 Don
Jun 12, 2009 | Lexmark Z735 InkJet Printer
After my Z735 lexmark printer prints the first line it showsan error message that "Something is blocking the catridge" .
Dec 14, 2008 | Lexmark Z735 InkJet Printer
Changing color
try your software setting for your printer... maybe options
Aug 13, 2008 | Lexmark Z735 InkJet Printer
click here to download vista version:
  • Download the above software.
  • Un-install your previous deriver.
  • Turn off your PC.
  • Remove all connection of printer from system.
  • Install new downloaded driver.
  • Don't connect the printer to PC untill setup says to connect or setup finished.
Thanks
Iqbal
Apr 29, 2008 | Lexmark Z735 InkJet Printer
91 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Roopesh S
Roopesh S
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
