Question about Singer 7462 Mechanical Sewing Machine
How is the top cover removed, there are no screws. I need to remove the top cover to attach a new spool pin because the original one broke off when the machine was being transported (it fell over).
  • Singer Master
  • 5,568 Answers
Many are held in place only by spring clips and can be removed by strong fingernails or a dull knife pushed into the **** of the cover and lifted.
Posted on Jul 17, 2008
How to take back off bernia 1090
It doesn't sound quite right to have to remove the back cover to replace the spool pin. Most metal pins just pull out or push in, although there are some that the pin has a screw thread. But my older Berninas have a smooth metal pin. Just a thought...
Oct 10, 2016 | Sewing Machines
How do I remove the back casing/cover so I can replace the spool pin?
Have you checked to be sure the spool pins do not pull out or are screwed in? Hard to diagnose without knowing the make & model.
Feb 01, 2016 | Sewing Machines
The upper part of the right spool pin broke off. I ordered a new pin but am unable to remove the old one to replace it. How do you remove the spool pin?
Depends on your machine brand and model. Some pins simply unscrew and others pull out. Probably best to look at the replacement pin you purchased.
Aug 25, 2015 | Sewing Machines
How do I replace the spool pin on XR65 sewing machine
http://www.fixya.com/support/t14293048-not_know_replace_spool_pin_spool_cap
Posted on Sep 11, 2012
This is from a Model 5160; might it work?
Two ways.. either put the new spool pin in the other extra hole to the left of the trap door on top
OR take out the two bigger screws on the top cover that hold it in, also take off the knobs on the front sliders (patterns selection) and remove the top cover. Push the old pin out from the inside with nail or something similar and replace. Posted on Feb 03, 2010
Parts diagram show on the left as # 10.
http www searspartsdirect com Brother Sewing machine Parts Model...
Feb 05, 2015 | Sewing Machines
I have a brother xl5012 and would like to change the spool pin..not sure if its broken? the one on top is silver and the spare is plastic..not sure what to do..the manual has no answers.. thank you
On most machines, the spool pin simply screws into a threaded hole. If it was welded on or attached in some other permanent way, changing it may need a service visit. Brother has one of the very best service departments of any company I know. But try to unscrew the old one.. it might be stuck, a drop of penetrating oil, or maybe some pliers, might assist. If it comes out, a new one should screw in easily enough, so long as it matches the size of the hole and the threading.
Nov 17, 2014 | Sewing Machines
Problem with spool pin
Doreen:
There are screws holding the top housing onto the machine. (The top housing is where the spool pin slid into). remove the screws on the top housing and pull the top housing up off of the machine. You will be able to reposition the spool pin to where it supposed to be. put the top housing back on and reinstall the screws.
Jul 04, 2014 | New Home HF-2022
I have a janone machine
Doreen:
use a screwdriver to remove the top housing (remove the screws holding the top housing on)... pull the top housing up off of the machine and reposition the spool pin and then reinstall the top housing.
How to remove back cover on bernina 830 record
.... there is no back cover - it is part of the metal frame 'housing'. You can remove the base, the top cover, the end cover (handwheel end), the cover on the freearm. You can access the spool pin fixing by taking off the top cover.
Mar 15, 2013 | Bernina Activa 130
How do i take the case off my brother xr-65 to replace my spool pin and spool cap
I don't have that particular Brother but I have on that is similar.
Start by taking all of the screws out of the back that you can find (they're in deep holes, so look carefully). Then look at the bobbin area and you'll probably find one more. Finally, take the feet off of the bottom of the machine (not the presser foot, the feet that sit on the table), you'll likely find that there is a screw through the middle of the foot that also holds the case in place.
Best of luck
Sep 10, 2012 | Brother Sewing Machines
How do i replace the spool pin on my singer sewing machine model # 3314?
Two ways.. either put the new spool pin in the other extra hole to the left of the trap door on top OR take out the two bigger screws on the top cover that hold it in, also take off the knobs on the front sliders (patters selection) and remove the top over. Push the old pin out from the inside with nail or something simila and replace.. simple. Do you have an extra spool pin you can share?
Nov 05, 2009 | Singer Sewing Machines
Singer 7462 Mechanical Sewing Machine Logo
175 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
