Question about HHB Radius 50 Tube Amplifier
Crate G60XL The dirty channel A dose`nt work at all even the light don`t come on when I change the channel. The clean channel B works fine. So what`s up with that?
  • madmedia63
    madmedia63 Jul 17, 2008
    This is a G60xl crate amp
  • madmedia63
    madmedia63 Jul 19, 2008
    thanks to ya but I don`t know what to do so I put my amp in the shop so hopfuly problem solved if not I`ll let y`all know. Thanks for the help it let me know that I needed to put my amp in the shop.See Ya
  • 1,512 Answers
Hey madmedia63
Good old amps these. Fixed a few over the years. I would expect dry solder joints in and about the channel switching. If you got a mate with soldering experience, he da man to help you sort it. Hard to help you anymore without actually looking inside the amp to see what's going on. But that's were I would start at least. Way round it I guess is to use a distortion pedal. Go for a metalzone to get similar sort of distortion. \m/ riff out ;)
robotek
Posted on Jul 18, 2008
  • Graeme Ross
    Graeme Ross Jul 19, 2008
    hi, just wondering why you gave me a thanks for trying rating for my advice. This rating has a bad impact on pour overall rankings with FixYa. I have been repairing guitar amps for 25 years. I know I gave you good advice. Have you got the problem sorted. What was it?
    regards
    robotek
I have a crate vtx200s has very little volume everything else works whats the deal?
Hi, you hadnt mentioned how long you've had the amp, or how new it is, so I'm going to assume it's new to you. The Crate VTX200 has 3 channels, each with its own volume level. Let's check the simple things first:
1. Check to make sure you're adjusting the same volume knob volume knob to the same channel. The active channel will be lit with a green light.
2. Check the cables from the "Speaker Out" jacks on the amp (if you are using them). Are they plugged in all the way, or are they damaged?
3. Are you playing through a preset that you may have accidentally made "low", and may not be aware of or are stuck in it?
If none of these answers helps, there might be a problem with the input buffer in the circuit or possibly within the damping circuit of the speakers. I'd advise having the amp serviced to confirm an internal electrical problem also. If you don't have a manual for the amp, one can be found here:
http://www.manualguru.com/crate-amplifiers/vtx200/users-manual
Jan 22, 2016 | Crate Music
Sitting at light and its bumps forward like trans slips out of gear oil is clean an red drives fine dose not slip
If it has over one hundred and twenty thousand Klm I am wondering if the transmission filter is dirty. Our car was not shifting right and I changed the transmission fluid and filter and it ran good for many months after that.
Aug 03, 2015 | Cars & Trucks
Crate flexwave 120 head effects malfunctioning
That is probably a momentary switch that is dirty and sticking. These onboard effects on guitar amps are usually nothing more than a computer sound card and I've found bad connections going to and from them as well. I do think that switch is dirty and sticking, though.
Feb 19, 2013 | Crate FlexWave FW120H Guitar Amp Head with...
Hie, I Have got a crate tx 15 and, I have a sound problem, all time I have got a buzzzz... but there another thing too, the led for the battery recharge does'nt light and when I plug the electric...
Your symptoms would indicate the battery is defective. When a battery fails, its internal resistance goes up and they PROBABLY use this battery in place of having a separate filter capacitor so you will get hum or buzz as a result and no charging indication.
Sep 13, 2011 | Crate TX15 15W Guitar Amplifier
Solid State amplifier problems
I would look for crossed wires or shorts on the board itself as a result of overheating. They will look like toasted circles around the pins of the board. You may not have been the first to open the amp and make a repair.
Apr 30, 2009 | HHB Radius 50 Tube Amplifier
Intermittent shorts in a Crate Limo TX50DE Guitar
turn that ****** on and get a can of freeze spray. coming and going type issues is usually related to a failing electrolytic capacitor. there may also be a bad mosfet, rectifier, diode, etc. i would be suspect to caps. schematics probably only available thru crate and you have to pay a couple bucks, but trust me its worth the couple bucks spent and having it on its way than wasting hours online not getting anywhere. by the way i checked my sources and came up with nada.
yostamplifier.com
Feb 20, 2009 | Crate SPA1600 Power Amplifier - SPA Series...
Remote will not work
if the light is staying on this means that a button is stuck down on your remote. It might be defective I would contact the company about warranty.
Oct 31, 2007 | GE RM24925 Remote Control
HHB Radius 50 Tube Amplifier Logo
833 people viewed this question
Top HHB Audio Players & Recorders Experts
John
John
darren dillon
Level 1 Expert
Are you a HHB Audio Player and Recorder Expert? Answer questions, earn points and help others
